Az OpenTTD 12.2 hivatalosan is megjelent! Ez egy hibajavító kiadás a 12.0-s verzióhoz, amely az alábbi javításokat tartalmazza:
- Feature: Remember the last-used signal between games (#9792)
- Change: [MacOS] Allow touchbar usage on all supported OS versions (#9776)
- Change: Add a timestamp in name of crash files (#9761)
- Fix #9736: Duplicate multiplayer window opens upon canceling password entry (#9842)
- Fix: Removing long roads doesn't prioritise refusal of local authority over other errors (#9831)
- Fix #9020: Glitchy station coverage highlight when changing selection (#9825)
- Fix: Correct some Romanian town names (#9819)
- Fix: Original music playback rate was slightly too fast (#9814)
- Fix #9811: Use the NewGRF-defined vehicle center when dragging ships and aircraft (#9812)
- Fix: Do not let shares in the company taking over another company disappear (#9808)
- Fix #9802: Crash when using lots of NewGRF waypoint types (#9803)
- Fix #9766: Don't write uninitialised data in config file (#9767)
- Fix #9743: [MacOS] Don't try to render touchbar sprites with invalid zoom level (#9776)
- Fix #9774: Building roadstop in estimation mode updates station acceptance (#9775)
- Fix: If vehicles only refit to cargo-slots >= 32, the default cargo was wrong (#9744)
- Fix #9735: Possible desync when replacing a depot on same tile (#9738)
- Fix #9730: [Network] Connections can use an invalid socket due to a race condition (#9731)
- Fix: Don't show sign edit window for GS-owned signs (#9716)
- Fix #9702: Display order window for vehicle group on ctrl-click only when using shared orders (#9704)
- Fix #9680: Crash when loading really old savegames with aircraft in certain places (#9699)
- Fix: Update last servicing dates when using the date cheat (#9694)
- Fix: Error message shows about missing glyphs while suitable fallback font is found (#9692)
Próbáljátok ki, szeretni fogjátok!
Az OpenTTD egy nyílt forráskódú szimulációs játék, amely a Chris Sawyer által írt népszerű Microprose „Transport Tycoon Deluxe” játékon alapul. Megpróbálja a lehető legjobban utánozni az eredeti játékot, miközben új funkciókkal bővíti azt.
Az OpenTTD a GNU General Public License 2.0 verziója alatt érhető el.
Az OpenTTD futtatásához külön alap grafikus készletre van szükség, amely a telepítőn keresztül (Windows) vagy az első futtatáskor (Windows, Linux) letölthető. Abban az esetben, ha manuálisan szeretné letölteni és telepíteni, néhány lehetőség:
- OpenGFX (grafika)
- A Transport Tycoon Deluxe adatfájljai használhatók alap grafikai készletként. A Transport Tycoon Deluxe egy verziójával kell rendelkeznie; nem tölthetőek le.
A hang- és zenei készletek ajánlott (de nem szükségesek). Az OpenSFX (hang), és az OpenMSX (zene) telepíthető a telepítőprogramon keresztül, vagy - ha rendelkezik CD-vel - a Transport Tycoon Deluxe hang- és zenecsomagok is használhatóak
További grafikai, hang- és zenei készletek letölthetők az játékon belüli tartalom letöltéskezelőn keresztül.
További információkért kérjük, olvassa el a readme-t.
Minden általunk hivatalosan kiadott bináris programhoz közzétesszük az MD5, SHA1 és SHA256 ellenőrző összegeket. Ezen ellenőrző összegek segítségével ellenőrizheti, hogy a letöltött fájl nem módosult-e. Mindhárom ellenőrző összegnek meg kell egyeznie a letöltött fájllal; ha ez nem így van, az azt jelenti, hogy a fájl vagy nem tőlünk származik, vagy a szállítás során elromlott. Akárhogy is, a fájl esetleg veszélyes módosításokat tartalmazhat, ezért nem szabad megbízni benne!
Klasszik
Beküldte Balazs_B -
Na igen a Tycoon. Időről-időre elő szoktam venni és meglepődöm mennyire sokat fejlesztgetnek rajta.
Amióta meg már a legtöbb nagy játék platformon is elérhető még tovább nőtt a népszerűsége.
Klasszik
Beküldte kami911 -
