médialejátszó
Kis segítséget szeretnék kérni. Mint 19 XFCE a delikvens, a probléma az, hogy ezen az oldalon, https://onlinestream.hu/tv a 2.oldal National Geographic az "erre a linkre kattintva" behozza a médialejátszót és... nem történik semmi. Ez azért érdeles, mert az Ubuntu 18.04 XFCE gond nélkül lejátssza. Valami megoldást tud valaki?
Nálam az eredeti Mint
Nálam az eredeti Mint telepitésü Xpalyer (médialejátszó) Kattintásra nem nyit meg semmit. Terminálban:
andandrea@andrea-350V5C-351V5C-3540VC-3440VC:~$ xplayer  https://onlinestream.hu/play.xspf?id=5936&ch=1&ext=.xspf
[1] 3047
[2] 3048
(xplayer:3047): Gtk-WARNING **: 20:04:47.251: GtkButton does not have a child property called expand
(xplayer:3047): Gtk-WARNING **: 20:04:47.251: GtkButton does not have a child property called fill
(xplayer:3047): Gtk-WARNING **: 20:04:47.251: GtkButton does not have a child property called position
(xplayer:3047): Gtk-WARNING **: 20:04:47.251: GtkToggleButton does not have a child property called expand
(xplayer:3047): Gtk-WARNING **: 20:04:47.252: GtkToggleButton does not have a child property called fill
(xplayer:3047): Gtk-WARNING **: 20:04:47.252: GtkToggleButton does not have a child property called position
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'continue_button_clicked_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'load_button_clicked_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'save_button_clicked_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'goto_button_clicked_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'remove_button_clicked_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'add_button_clicked_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'tree_view_button_press_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'tree_view_key_press_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'tree_view_row_activated_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'tree_view_popup_menu_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'popup_goto_action_cb'.  Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'popup_remove_action_cb'.  Did you compile with -rdynamic?
(xplayer:3047): GStreamer-CRITICAL **: 20:04:47.810: gst_tag_list_get_string_index: assertion 'GST_IS_TAG_LIST (list)' failed
(xplayer:3047): Gtk-WARNING **: 20:04:47.830: Calling org.xfce.Session.Manager.Inhibit failed: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Method "Inhibit" with signature "susu" on interface "org.xfce.Session.Manager" doesn't exist
** Message: 20:04:48.062: Missing plugin: gstreamer|1.0|xplayer|text/html dekódoló|decoder-text/html (text/html dekódoló)
** Message: 20:04:48.091: PackageKit: xid = 65011733
** Message: 20:04:48.091: PackageKit: desktop_id = (null)
** Message: 20:04:48.091: PackageKit: Codec nice name: text/html dek?dol?
** Message: 20:04:48.091: PackageKit: structure: gstreamer1(decoder-text/html)()(64bit)
** Message: 20:04:48.095: PackageKit: Did not install codec: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.PackageKit was not provided by any .service files
** Message: 20:04:48.096: No installation candidate for missing plugins found.
[1] 3047
[2] 3048
Megjelenik a médialejátszó
Megjelenik a médialejátszó egy üres fekete ablakkal és nem indul el a lejátszás. Inkább telepiteni kellene a Smplayer-t a Synapticból? Valami codec hiba nem lehet?
Firefox alkalmazások
Lemaradt a Firefox válasz:
XSPF-lejátszólista = médialejátszó használata (alapértelmezett)
Igazad lett. Az Smplayer
Igazad lett. Az Smplayer gyönyörűen megnyitja. Az xplayer pedig nagyon felejtős. Megoldva.
#2 Próbáld telepíteni ezt a csomagot: libquvi-0.9-*
https://packages.ubuntu.com/search?keywords=quvi&searchon=names&suite=al...
A Gsteamer1.0-ból mindegyik (base, good, bad, ugly ...) csomag telepítve van?
Talán: https://askubuntu.com/a/404636
Nálam a VLC megnyitja az URL-t (csak a böngészőből), de nincs hang az XPSF használatnál. Az ASX lejátszólistafájl használatánál van hang.
Az SMPlayer ezeket telepíti (Debian rendszerI:
  ffmpeg libavdevice57 libqt5script5 libqt5xml5 mpv rtmpdump smplayer-l10n
  smplayer-themes youtube-dl
A Firefox fájl társításokról (mellesleg):
http://kb.mozillazine.org/File_types_and_download_actions#Resetting_down...
#7
Szerintem meg nem az xplayer volt a gondod, hanem sejtésem szerint az, hogy a telepítéskor nem jelölted be a zárt szoftverek telepítését.
Mivel gyanítottam, hogy valami nem stimmel itt, feltelepítettem virtualboxba  a 19XFCE-s Linuxmintet és a rendszer frissítése után elnavigáltam a linkelt oldalra és gond nélkül megnyitotta az xplayer.
imgur.com/a/BLxsr3o
https://imgur.com/a/BLxsr3o
#10 Vélhetően a *buntu-restricted-extras vagy a *buntu-restricted-addons csomagok kellenek.
Szerk.: Linux Mint 19 Tara Mate alatt az XPlayer gyönyörűen nyitja a linket. A nem szabad csomagok be lettek jelölve a telepítéskor.
#11
Ezekkel nem megy, de a
sudo apt install gstreamer1.0-libav gstreamer1.0-plugins-bad
telepítés megoldja a gondot.
#14 Erre gyanakodtam én is, mert az XPlayer a Totem médialejátszó forkja, és utóbbi GStreamer-t használ. Másrészt az említett bad plugint és a libav csomagot említik a neten is, hasonló vonatkozásban. A gstreamer1.0-plugins-bad csomag régebben más OS alatt sem volt mindig telepítve, elemei:
https://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-plugins-ba...
A Libav, egy házon belüli FFMpeg elágazás (fork), itt Gstreamer beépülő, elemei:
https://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-libav-plug... | https://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-libav-plug...
Jó neked, tudsz angolul.  Én
Jó neked, tudsz angolul.  Én meg csak empirikus hibakeresésekkel operálok. Ezzel is jól meg kellett küzdenem, mert a tippjeim nem jöttek be. végül azt csináltam, hogy virtuálboxba csináltam két szűz LinuxMint 19XFCE telepítést, egyiknél bejelöltem a harmadik féltől származó szoftverek telepítését, a másiknál nem. Amelyiknél bejelőltem, az megnyitotta xplayerrel a streamet, amelyiknél nem, az nem nyitotta meg. Mindkét rendszerről csináltam egy csomaglista fájlt.
dpkg --get-selections > LM19XFCE_free
dpkg --get-selections > LM19XFCE_nonfree
Majd a két csomaglista különbségét vettem:
diff LM19XFCE_free LM19XFCE_nonfree
Az erdményből már én is egyből a GStreamerre gyanakodtam, elkezdtem ezeket a csomagokat egyesével telepíteni, és a két fenti csomag telepítése után már lejátszotta az xplayer a streamet.
@kinarite:A Gsteamer1.0-ból
@kinarite:A Gsteamer1.0-ból mindegyik (base, good, bad, ugly ...) csomag telepítve van?
@aperten:a telepítéskor nem jelölted be a zárt szoftverek telepítését.
Lehetséges, nem emlékszem még a bétából lett telepítve
@kinarite:Vélhetően a *buntu-restricted-extras vagy a *buntu-restricted-addons csomagok kellenek.
xubuntu-restricted-extras xubuntu-restricted-addons telepitve
https://paste.ubuntu.com/p/qyCXDYQQrb/
#16 Hát igen, a diff néha (sokszor) hasznos tud lenni. :-)
Tanulgatok angolul.
@kimarite:A Gsteamer1.0-ból
#17 A LibreOffice-set, már én telepítettem, de ezek vannak:
dpkg -l *gst* | grep ii
ii  gir1.2-gst-plugins-base-1.0           1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GObject introspection data for the GStreamer Plugins Base library
ii  gir1.2-gstreamer-1.0                  1.14.1-1~ubuntu18.04.1        amd64        GObject introspection data for the GStreamer library
ii  gstreamer1.0-alsa:amd64               1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer plugin for ALSA
ii  gstreamer1.0-clutter-3.0:amd64        3.0.26-1                      amd64        Clutter PLugin for GStreamer 1.0
ii  gstreamer1.0-gl:amd64                 1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer plugins for GL
ii  gstreamer1.0-libav:amd64              1.14.1-1~ubuntu18.04.1        amd64        libav plugin for GStreamer
ii  gstreamer1.0-packagekit               1.1.9-1ubuntu2.18.04.1        amd64        GStreamer plugin to install codecs using PackageKit
ii  gstreamer1.0-plugins-bad:amd64        1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer plugins from the "bad" set
ii  gstreamer1.0-plugins-base:amd64       1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer plugins from the "base" set
ii  gstreamer1.0-plugins-base-apps        1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer helper programs from the "base" set
ii  gstreamer1.0-plugins-good:amd64       1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer plugins from the "good" set
ii  gstreamer1.0-plugins-ugly:amd64       1.14.1-1~ubuntu18.04.1        amd64        GStreamer plugins from the "ugly" set
ii  gstreamer1.0-pulseaudio:amd64         1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer plugin for PulseAudio
ii  gstreamer1.0-tools                    1.14.1-1~ubuntu18.04.1        amd64        Tools for use with GStreamer
ii  gstreamer1.0-vaapi:amd64              1.14.1-1~ubuntu18.04.1        amd64        VA-API plugins for GStreamer
ii  gstreamer1.0-x:amd64                  1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer plugins for X11 and Pango
ii  libclutter-gst-3.0-0:amd64            3.0.26-1                      amd64        Open GL based interactive canvas library GStreamer elements
ii  libgstreamer-gl1.0-0:amd64            1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer GL libraries
ii  libgstreamer-plugins-bad1.0-0:amd64   1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer libraries from the "bad" set
ii  libgstreamer-plugins-base1.0-0:amd64  1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer libraries from the "base" set
ii  libgstreamer-plugins-good1.0-0:amd64  1.14.1-1ubuntu1~ubuntu18.04.1 amd64        GStreamer development files for libraries from the "good" set
ii  libgstreamer1.0-0:amd64               1.14.1-1~ubuntu18.04.1        amd64        Core GStreamer libraries and elements
ii  libreoffice-avmedia-backend-gstreamer 1:6.0.3-0ubuntu1              amd64        GStreamer backend for LibreOffice
taramate@taramate-VirtualBox:~$
Összehasonlitottam az
Összehasonlitottam az enyémmel, egy hiányzott, gstreamer1.0-vaapi:amd64. Telepitettem, de továbbra sem jó, mi hiányozhat? A smplayer kitünően működik.
@#8Üdv.Mindenki! SMPlayert tartom én is a legjobbnak. LMDE 3 Cindy-t használok, telepítés után letöröltem a régi fentlévő SMPlayert. A honlapjáról https://www.smplayer.info/downloads/ letöltöttem smplayer-18.9.0.tar.bz2
smplayer-themes-18.6.0.tar.bz2
smplayer-skins-15.2.0.tar.bz2 kibontottam a letöltések mappába és megnyitás Terminálban
sudo apt-get install smplayer parancs után feltette  a régi 16.11.0 verziót eredeti angol nyelvűt. A szoftverkezelőből is ezt húzza le, míg a honlapján lévő legújabb 18.9.0 magyar nyelvű és kicsit újabb a kezelőfelülete. Miért nem ez települ LMDE3-ra? Ha tudtok rá választ kérlek írjátok meg.(Windowsra gond nélkül felment ez a verzió, azon már lecseréltem a VLC-t, de minden nap az LMDE Cindy-t használom)
#25 Miért nem .deb formátumban töltöd le ?
https://software.opensuse.org/download.html?project=home%3Asmplayerdev&p...
https://ibb.co/hvb6Rp
Ez annyival jobb a 16.11.0-ás verziónál hogy érdemes vele foglalkozni ?
OK köszönöm!
OK !  Sikerült hálás köszönet!!
OK köszönöm!
#29 Igazad van ! Én tévelyedtem el ! :( Az LMDE3 az Debian alapú.
De ha az Ubuntus csomag is települt, és működőképes, akkor szerencsénk volt ! :)
Igen ezért néztem először a
Igen ezért néztem először a Debian ikonnál, mert Deb alapú és nem kompatibilis a PPA tárolókkal sem. De az Ubuntus csomag felment, semmi gond nagyon köszönöm a segítségedet hasznos volt.
Nem ajánlom senkinek, hogy
Nem ajánlom senkinek, hogy kövessen. A fentiek alapján telepítettem az SMPlayert de nem nyitotta meg a szokásos m3u és egyéb hasonló fájlokat arra hivatkozva, hogy hiányzik az mpv Media Player. Igen a Windowsos verzió már nélküle települ (18.9.0) hiányoltam is de ott működik annak hiányában is. Itt maradni kell a régebbi a hivatalos (home page) oldalról, vagy a szoftverkezelőből letölthetőnél. Az működik megnyit mindent.
#25 https://linuxmint.hu/comment/10592#comment-10592
