Kis segítséget szeretnék kérni. Mint 19 XFCE a delikvens, a probléma az, hogy ezen az oldalon, https://onlinestream.hu/tv a 2.oldal National Geographic az "erre a linkre kattintva" behozza a médialejátszót és... nem történik semmi. Ez azért érdeles, mert az Ubuntu 18.04 XFCE gond nélkül lejátssza. Valami megoldást tud valaki?
Nálam az eredeti Mint
Nálam az eredeti Mint telepitésü Xpalyer (médialejátszó) Kattintásra nem nyit meg semmit. Terminálban:
andandrea@andrea-350V5C-351V5C-3540VC-3440VC:~$ xplayer https://onlinestream.hu/play.xspf?id=5936&ch=1&ext=.xspf
[1] 3047
[2] 3048
(xplayer:3047): Gtk-WARNING **: 20:04:47.251: GtkButton does not have a child property called expand
(xplayer:3047): Gtk-WARNING **: 20:04:47.251: GtkButton does not have a child property called fill
(xplayer:3047): Gtk-WARNING **: 20:04:47.251: GtkButton does not have a child property called position
(xplayer:3047): Gtk-WARNING **: 20:04:47.251: GtkToggleButton does not have a child property called expand
(xplayer:3047): Gtk-WARNING **: 20:04:47.252: GtkToggleButton does not have a child property called fill
(xplayer:3047): Gtk-WARNING **: 20:04:47.252: GtkToggleButton does not have a child property called position
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'continue_button_clicked_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'load_button_clicked_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'save_button_clicked_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'goto_button_clicked_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'remove_button_clicked_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'add_button_clicked_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'tree_view_button_press_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'tree_view_key_press_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'tree_view_row_activated_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'tree_view_popup_menu_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'popup_goto_action_cb'. Did you compile with -rdynamic?
(xplayer:3047): Gtk-WARNING **: 20:04:47.437: Could not find signal handler 'popup_remove_action_cb'. Did you compile with -rdynamic?
(xplayer:3047): GStreamer-CRITICAL **: 20:04:47.810: gst_tag_list_get_string_index: assertion 'GST_IS_TAG_LIST (list)' failed
(xplayer:3047): Gtk-WARNING **: 20:04:47.830: Calling org.xfce.Session.Manager.Inhibit failed: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Method "Inhibit" with signature "susu" on interface "org.xfce.Session.Manager" doesn't exist
** Message: 20:04:48.062: Missing plugin: gstreamer|1.0|xplayer|text/html dekódoló|decoder-text/html (text/html dekódoló)
** Message: 20:04:48.091: PackageKit: xid = 65011733
** Message: 20:04:48.091: PackageKit: desktop_id = (null)
** Message: 20:04:48.091: PackageKit: Codec nice name: text/html dek?dol?
** Message: 20:04:48.091: PackageKit: structure: gstreamer1(decoder-text/html)()(64bit)
** Message: 20:04:48.095: PackageKit: Did not install codec: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.PackageKit was not provided by any .service files
** Message: 20:04:48.096: No installation candidate for missing plugins found.
[1] 3047
[2] 3048
Megjelenik a médialejátszó
Megjelenik a médialejátszó egy üres fekete ablakkal és nem indul el a lejátszás. Inkább telepiteni kellene a Smplayer-t a Synapticból? Valami codec hiba nem lehet?
Firefox alkalmazások
Lemaradt a Firefox válasz:
XSPF-lejátszólista = médialejátszó használata (alapértelmezett)
Igazad lett. Az Smplayer
Igazad lett. Az Smplayer gyönyörűen megnyitja. Az xplayer pedig nagyon felejtős. Megoldva.
https://packages.ubuntu.com/search?keywords=quvi&searchon=names&suite=al...
A Gsteamer1.0-ból mindegyik (base, good, bad, ugly ...) csomag telepítve van?
Talán: https://askubuntu.com/a/404636
Nálam a VLC megnyitja az URL-t (csak a böngészőből), de nincs hang az XPSF használatnál. Az ASX lejátszólistafájl használatánál van hang.
Az SMPlayer ezeket telepíti (Debian rendszerI:
A Firefox fájl társításokról (mellesleg):
http://kb.mozillazine.org/File_types_and_download_actions#Resetting_down...
Beküldte aperten -
Szerintem meg nem az xplayer volt a gondod, hanem sejtésem szerint az, hogy a telepítéskor nem jelölted be a zárt szoftverek telepítését.
Mivel gyanítottam, hogy valami nem stimmel itt, feltelepítettem virtualboxba a 19XFCE-s Linuxmintet és a rendszer frissítése után elnavigáltam a linkelt oldalra és gond nélkül megnyitotta az xplayer.
imgur.com/a/BLxsr3o
https://imgur.com/a/BLxsr3o
Szerk.: Linux Mint 19 Tara Mate alatt az XPlayer gyönyörűen nyitja a linket. A nem szabad csomagok be lettek jelölve a telepítéskor.
SMPlayer | Xt7-player
@#12 Van egy ilyen is: https://addons.videolan.org/p/1131036/
Beküldte aperten -
Ezekkel nem megy, de a
telepítés megoldja a gondot.
az XPlayer a Totem médialejátszó forkja, és utóbbi GStreamer-t használ. Másrészt az említett bad plugint és a libav csomagot említik a neten is, hasonló vonatkozásban. A gstreamer1.0-plugins-bad csomag régebben más OS alatt sem volt mindig telepítve, elemei:
Erre gyanakodtam én is, merthttps://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-plugins-ba...
A Libav, egy házon belüli FFMpeg elágazás (fork), itt Gstreamer beépülő, elemei:
https://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-libav-plug... | https://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-libav-plug...
Jó neked, tudsz angolul. Én
Beküldte aperten -
Jó neked, tudsz angolul. Én meg csak empirikus hibakeresésekkel operálok. Ezzel is jól meg kellett küzdenem, mert a tippjeim nem jöttek be. végül azt csináltam, hogy virtuálboxba csináltam két szűz LinuxMint 19XFCE telepítést, egyiknél bejelöltem a harmadik féltől származó szoftverek telepítését, a másiknál nem. Amelyiknél bejelőltem, az megnyitotta xplayerrel a streamet, amelyiknél nem, az nem nyitotta meg. Mindkét rendszerről csináltam egy csomaglista fájlt.
Majd a két csomaglista különbségét vettem:
Az erdményből már én is egyből a GStreamerre gyanakodtam, elkezdtem ezeket a csomagokat egyesével telepíteni, és a két fenti csomag telepítése után már lejátszotta az xplayer a streamet.
@kinarite:A Gsteamer1.0-ból
@kinarite:A Gsteamer1.0-ból mindegyik (base, good, bad, ugly ...) csomag telepítve van?
@aperten:a telepítéskor nem jelölted be a zárt szoftverek telepítését.
Lehetséges, nem emlékszem még a bétából lett telepítve
@kinarite:Vélhetően a *buntu-restricted-extras vagy a *buntu-restricted-addons csomagok kellenek.
xubuntu-restricted-extras xubuntu-restricted-addons telepitve
https://paste.ubuntu.com/p/qyCXDYQQrb/
Bocs, csak beillesztettem, a
Bocs, csak beillesztettem, a fene gondolta hogy ilyen hosszú lesz. Tudom, pastebin...Elnézést
Tanulgatok angolul.
@kimarite:A Gsteamer1.0-ból
Összehasonlitottam az
Összehasonlitottam az enyémmel, egy hiányzott, gstreamer1.0-vaapi:amd64. Telepitettem, de továbbra sem jó, mi hiányozhat? A smplayer kitünően működik.
Beküldte gyenes -
@#8Üdv.Mindenki! SMPlayert tartom én is a legjobbnak. LMDE 3 Cindy-t használok, telepítés után letöröltem a régi fentlévő SMPlayert. A honlapjáról https://www.smplayer.info/downloads/ letöltöttem smplayer-18.9.0.tar.bz2
smplayer-themes-18.6.0.tar.bz2
smplayer-skins-15.2.0.tar.bz2 kibontottam a letöltések mappába és megnyitás Terminálban
https://software.opensuse.org/download.html?project=home%3Asmplayerdev&p...
https://ibb.co/hvb6Rp
Ez annyival jobb a 16.11.0-ás verziónál hogy érdemes vele foglalkozni ?
Ez még régebbi ,Verzió 18.6.0
Beküldte gyenes -
Erre gondoltál? https://software.opensuse.org/download.html?project=home%3Asmplayerdev&p...
és megjelennek a letöltési lehetőségek - ahogy a linkelt képen is látható.
OK köszönöm!
Beküldte gyenes -
OK ! Sikerült hálás köszönet!!
OK köszönöm!
De ha az Ubuntus csomag is települt, és működőképes, akkor szerencsénk volt ! :)
Igen ezért néztem először a
Beküldte gyenes -
Igen ezért néztem először a Debian ikonnál, mert Deb alapú és nem kompatibilis a PPA tárolókkal sem. De az Ubuntus csomag felment, semmi gond nagyon köszönöm a segítségedet hasznos volt.
Nem ajánlom senkinek, hogy
Beküldte gyenes -
Nem ajánlom senkinek, hogy kövessen. A fentiek alapján telepítettem az SMPlayert de nem nyitotta meg a szokásos m3u és egyéb hasonló fájlokat arra hivatkozva, hogy hiányzik az mpv Media Player. Igen a Windowsos verzió már nélküle települ (18.9.0) hiányoltam is de ott működik annak hiányában is. Itt maradni kell a régebbi a hivatalos (home page) oldalról, vagy a szoftverkezelőből letölthetőnél. Az működik megnyit mindent.
https://linuxmint.hu/comment/10592#comment-10592
