Upgrade után sikertelen belépés
Üdv,
van egy laptopom, amin egy 18.2-es Mint volt (titkosított /home-al). Ezt először upgradeltem 18.3-ra, restart, ekkor minden ok volt. Utána upgrade 19-re, restart - és most nem tudok belépni.
Belépés után azonnal kidob, és újraindul a DM.
Konzolon be tudok lépni, SSH-n is, a logban az alábbi sorokat látom:
Nov 17 23:23:28 sebulba udev-acl.ck[4200]: g_slice_set_config: assertion 'sys_page_size == 0' failed
Nov 17 23:23:31 sebulba lightdm: pam_ecryptfs: pam_sm_authenticate: /home/airween is already mounted
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4111 (lightdm) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4127 (gnome-keyring-d) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4130 (lightdm-greeter) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4135 (dbus-daemon) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4136 (slick-greeter) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4142 (dconf-service) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4156 (at-spi-bus-laun) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4161 (dbus-daemon) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4167 (at-spi2-registr) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4169 (gvfsd) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: session-c9.scope: Killing process 4176 (gvfsd-fuse) with signal SIGTERM.
Nov 17 23:23:31 sebulba systemd[1]: Stopping Session c9 of user lightdm.
Nov 17 23:23:31 sebulba systemd[1]: Started Session c10 of user airween.
Nov 17 23:23:31 sebulba systemd[1]: Stopped Session c9 of user lightdm.
Nov 17 23:23:31 sebulba systemd[1]: Stopping User Manager for UID 128...
Nov 17 23:23:31 sebulba systemd[4114]: Stopped target Default.
Nov 17 23:23:31 sebulba systemd[4114]: Stopped target Basic System.
Nov 17 23:23:31 sebulba systemd[4114]: Stopped target Paths.
Nov 17 23:23:31 sebulba systemd[4114]: Stopped target Sockets.
Nov 17 23:23:31 sebulba systemd[4114]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Nov 17 23:23:31 sebulba systemd[4114]: Closed GnuPG network certificate management daemon.
Nov 17 23:23:31 sebulba systemd[4114]: Closed GnuPG cryptographic agent and passphrase cache.
Nov 17 23:23:31 sebulba systemd[4114]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Nov 17 23:23:31 sebulba systemd[4114]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Nov 17 23:23:31 sebulba systemd[4114]: Reached target Shutdown.
Nov 17 23:23:31 sebulba systemd[4114]: Starting Exit the Session...
Nov 17 23:23:31 sebulba systemd[4114]: Stopped target Timers.
Nov 17 23:23:31 sebulba systemd[4114]: Started Exit the Session.
Nov 17 23:23:31 sebulba systemd[4114]: Received SIGRTMIN+24 from PID 4212 (n/a).
Nov 17 23:23:31 sebulba systemd[1]: Stopped User Manager for UID 128.
Nov 17 23:23:31 sebulba systemd[1]: Removed slice User Slice of lightdm.
Keresgéltem a neten, de nem találtam semmi használhatót.
Van valakinek ötlete, hogy lehet innen továbbmenni?
Köszi,
a.
Az ilyen grafikus felületen
Az ilyen grafikus felületen lévő belépési hibáknak egyik forrása az szokott lenni, hogy elfogy a hely vagy a home vagy a root alatt. Upgrade közben, után nem fogyott el a hely?
A .xsession-errors fájlban
A .xsession-errors fájlban találtam egy ilyet:
mate-session[5502]: GLib-GIO-ERROR: Settings schema 'org.gnome.Vino' does not contain a key named 'enabled'
Valszeg ez okozta a hibát, erre rákeresve ezt találtam:
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=762691
Az oldal alján ott a megoldás: le kellett törölni a /etc/xdm/autostart/vino.desktop fájlt.
Ezek szerint a frissítés után fent marad a vino, ami az új rendszernek nem tetszik...
Most be tudok lépni, de eltűnt minden beállításom: én a tálcára pakolok minden fontosabb alkalmazást, most semmi nincs - de olyanok sem, hogy pl. hálózati kapcsolatok (Network-manager), hangerő, frisstés ...
Hogy lehet ezt a legegyszerűbben visszahozni, vagy egy alapértelmezett asztallal elindulni?
Ok, közben ez is meglett: a
Ok, közben ez is meglett: a tálcán jobb gomb -> Tálca visszaállítása -> megerősítés -> új tálca, rajta a főmenü, alkalmazások (terminál, Firefox, ...), upgrade manager, hálózatok - bár spec a hálózatok ikonja nem látszik, csak ha vakon odakattintok, akkor látom a kapcsolatokat, és tudom szerkeszteni, amit kell. A hálózatok ikon "csak" a Mint-X témában nem látszik, a Mint-Y-ban igen.
A könyvjelzők nincsenek meg, a beállított VPN-ek és egyéb hálózati kapcsolatok igen.
Eddig picit csalódás az upgrade, valszeg full mentés lesz, és újratelepítek egy frisebb verziót.
#1
De, sajnos egyszer igen - a / alatt, pedig csináltam bőven helyet, és a mintupgrade is ellenőrízte.
A csomagokat már letöltötte, egyszer szólt, hogy megállt, mert elfogyott a hely. Az
apt-get clean
után aztán folytatta a csomagok beállításával. Ezek szerint ennyi elég volt a sikertelen upgrade-hez?
(20G a /, ebből kb 14-15G foglalt volt az upgrade megkezdése előtt)
#4 Nagyobb frissítéskor van az, hogy a letöltött csomagok is hatalmas - több gigányi helyet esznek. Szerintem ez kavart be most neked is.
#5 Ok, láttam, hogy sok csomagot tölt le, de gondoltam a mintupgrade van annyira "intelligens", hogy tudja, mennyi kell a telepítés befejezéséhez.
Mindegy, most épp fut minden, a könyvjelzőkön és a tálcán levő alkalmazásokon kívül minden megvan.
#6 Böngésző könyvjelzőket keresed? Melyik böngésző?
Az egyik régebbi rendszeremél volt hasonló (?) probléma. (MIután felújítottam a gépet UEFI-s alaplapúra.)
Az új vasamon a régi Legacy telepítésű rendszer indításakor a jelszó beírása után sem indult.
Viszont, tty-ről (konzolról) beengedett.
Nálam az lett a megoldás. hogy a LighDM-et kicseréltem GDM2(?)-re.
Indítsd a rendszert - nézd meg a synapticban hogy melyik gdm verzió van a tárolókban (2-es, vagy 3-as ?)
És ennek megfelelően telepítsd
sudo apt install gdm?
majd
sudo dpkg-reconfigure gdm?
https://askubuntu.com/questions/152256/how-do-i-switch-from-lightdm-to-gdm
#7 Nem, egyáltalán nem használok könyvjelzőt a böngészőkben :).
A Caja könyvjelzői tűntek el: elég sok FTP, SMB, DAV, ... kötet volt beállítva - ezek most nincsenek ott.
(Angolul "shortcut", így talán egyértelműbb, mire gondolok)
#8 A 18.2-es Mint-ben még mdm volt, az összes frissítési doksi azt írta, hogy szedjem le és tegyem fel a lightdm-et. Ezt meg is tettem.
Közben meglett a hiba: a lightdm egyébként elindult, de belépés után crash-elt. Az ok pedig az volt, hogy telepítve maradt a "vino", de nem tudott elindulni. A /etc/xdm/autostart/vino.desktop letörlése megszüntette a hibát.
Megnéztem az asztali gépen (19.3), ott nincs is telepítve a vino, ezért itt is leszedtem az egész csomagot.
#9 Értek mindent. :)
Körbe kéne nézni, a Caja rendetlenkedik-e, ha egyébként a jogokkal, beállításokkal minden rendben.
#4 Az nagyon kicsi.
Nem tudom mekkora lemezekkel vagy megáldva de a terák korába legalább 40GB egy OS lemezterülete.
Az XP mindennel felcsicsázva, .net, java egyebek kért 12 gigát.
Egy mostani desktopnak a 20 szerintem kevés. Az oké hogy letölti az upgrade-t de valahova ki is kell bontani.
A Mint telepítő sem tudja bitre kiszámolni ha nagyon ki van centizve.
Vagy véletlenül egyszer rányomsz egy flatpak installra  és elfogyott a területed.
A mostani hiba bár nem erre vezethető vissza de én mindenképp megnövelném a /-t.
#12 Igen, a / növelése mindenképp tervben van, a tegnapi/mai upgrade sikerességének megállapításától függetlenül :).
Szeretnék felmenni a 20-as verzióra.
#9 A Caja könyvjelzői tűntek el: elég sok FTP, SMB, DAV, ... kötet volt beállítva - ezek most nincsenek ott.
Amúgy timeshift futott a régi rendszeren? Felhasználói fájlokra be volt állítva? Mert ha igen, annak a mappáiban meg lehetnek...
#13 Frissítéshez csak pár szót.
Én is upgradeltem a 18.04 Ubuntut a 20.04-re de pár hét után visszaálltam a régebbire Timeshift mentésből. Lámlám igaz a mondás hogy menteni smiley
Pár apró de számomra bosszantó grafikus bug volt benne, pl. a gtk-nocsd nem úgy működik, rondák az ablakok,  valamint pár szoftverem sem úgy működik rajta mint eddig, pl. Smplayerre ha Yutubról küldök videót, nem jön fel a player ablaka a panelről csak villog.
És mégegy, az igaz hogy relatíve harmatgyenge gépekkel nyomulok de a 20.04 nekem kevésbé tűnt gyorsnak. Magyarán néha tetűassú volt bizonyos helyzetekben a régebbihez képest.
Neked sok sikert kívánok az upgrade-hez.
#14 Van egy mentés a régi rendszerről, de szerintem csak magáról a rendszerről készítettem mentést, a HOME nem lett lementve.
Kb. ugyanazok a könyvjelzők vannak az asztali gépen is, így megoldható az átvitel, de itt inkább az elv a fontos: meg tudom-e valahogy csinálni, ill miért tűnt el. :)
Anno találtam valami scriptet, amivel a keychain-ről lehet mentést készíteni, és át lehet vinni az egyes kapcsolatokat (VPN, WiFI, ...), abban ezek a könyvjelző jelszavak is benne voltak.
Ha van egy kis időm, ránézek a gépre, valamit mindig tudok fixálni - pl. a login képernyő valami ronda Ubuntus volt, már jó az is.
#15 Igen, a mentés fontos.
De jelen esetben a HOME adatok között kevés olyan van, ami pótolhatatlan. Nyilván ezek a beállítások pont olyanok :), ezért próbálkoztam meg az upgrade-el. (Amúgy elvből nem szoktam upgradelni, mindig szűz install, és mentésből vissza minden, ami kell, itt csak a kalandvágy dolgozott bennem.)
Ami nálam bugként jelentkezik, de minden Mint-en, ami a kezem között volt (18.2, 19.3, Intel GPU/Nvidia), hogy a tálcán az ablakok néha "összekeverednek". Azaz kiválasztok lent egy terminált, de nem az lesz elől, és hiába gépelek, nem látom, hogy mi az...
Ez velem van kb 4-5 éve, mióta Mint-et használok - de ez majd egy külön topic.
#17 Ami nálam bugként jelentkezik, de minden Mint-en, ami a kezem között volt (18.2, 19.3, Intel GPU/Nvidia), hogy a tálcán az ablakok néha "összekeverednek". Azaz kiválasztok lent egy terminált, de nem az lesz elől, és hiába gépelek, nem látom, hogy mi az...
Érdekes, amit írsz. Én konkrétan ilyennel nem találkoztam semelyik Linux alatt. Hanem Windows alatt a melóban nagyon is gyakori. Leginkább Excellel kapcsolatban jön elő, de szerintem azért mert, az nagyon gyakran van használva (azaz lehet más esetben is előjön, csak az még nem volt használva). Ott úgy néz ki, hogy 2-3 táblázat meg van nyitva, és elkezdesz beírni valamit az előtérben levőbe, de mintha le lenne fagyva, nem történik semmi. Holott nem, hanem a hátul levő, eltakart táblába íródik a dolog. Amikor mérgedben bezárod az excelt, megkérdi akarod-e menteni, és igen, akkor elmenti a háttérben levő táblázatot a beleírt szöveggel.
Mint alatt hasonlóval csak FF-en belül találkoztam, de nem tudtam nyakon csípni a dolgot, hogy mi okozza. Itt úgy néz ki, hogy nem az a link lesz aktív amire kattintasz. Pl. itt rábökök a Friss bejegyzések menüpontra, és az FF az Ismertető oldalt nyitja meg. És ez csak random esetben van.
Nem találkoztam ilyennel.
#18 #19
Készítek majd valami videót :)
