Sziasztok.
Szerintetek érdemes lenne ebbe a lapiba még 4GB rendszer memóriát vennem? Kicsit nehézkes a kicsike, de szeretem. Nyaraláskor ez van velem, és otthon is használom az asztali mellett.
System: Kernel: 5.4.0-122-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: Cinnamon 5.2.7 wm: muffin dm: LightDM Distro: Linux Mint 20.3 Una
base: Ubuntu 20.04 focal
Machine: Type: Laptop System: Dell product: Latitude E6230 v: 01 serial: <filter> Chassis:
type: 9 serial: <filter>
Mobo: Dell model: 0YW5N5 v: A00 serial: <filter> UEFI: Dell v: A10 date: 05/20/2013
Battery: ID-1: BAT0 charge: 29.6 Wh condition: 29.6/66.6 Wh (44%) volts: 12.8/11.1
model: SMP DELL Y61CV22 serial: <filter> status: Full
CPU: Topology: Dual Core model: Intel Core i5-3340M bits: 64 type: MT MCP arch: Ivy Bridge
rev: 9 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21528
Speed: 3190 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 3189 2: 3298 3: 3189
4: 3242
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0166
Display: x11 server: X.Org 1.20.13 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.2.6
compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.4.0-122-generic
Network: Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e v: 3.2.6-k
port: f080 bus ID: 00:19.0 chip ID: 8086:1502
IF: eno1 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi v: kernel
port: f040 bus ID: 02:00.0 chip ID: 8086:0082
IF: wlp2s0 state: up mac: <filter>
Drives: Local Storage: total: 119.24 GiB used: 20.89 GiB (17.5%)
ID-1: /dev/sda vendor: Samsung model: SSD 830 Series size: 119.24 GiB speed: 6.0 Gb/s
serial: <filter>
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0
bus ID: 00:1f.2 chip ID: 8086.282a
Partition: ID-1: / size: 116.32 GiB used: 20.88 GiB (18.0%) fs: ext4 dev: /dev/sda2
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
chip ID: 8087:0024
Device-1: 1-1.5:3 info: Microdia Dell Integrated HD Webcam type: Video driver: uvcvideo
rev: 2.0 chip ID: 0c45:643f
Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
Hub: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
chip ID: 8087:0024
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 chip ID: 1d6b:0002
Device-2: 3-2:2 info: SHARKOON 2.4G Mouse type: Mouse driver: hid-generic,usbhid
rev: 1.1 chip ID: 1ea7:0064
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 60.0 C mobo: 42.0 C sodimm: 37.0 C
Fan Speeds (RPM): cpu: 0
Repos: No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http: //packages.linuxmint.com una main upstream import backport #id:linuxmint_main
2: deb http: //archive.ubuntu.com/ubuntu focal main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
6: deb http: //archive.canonical.com/ubuntu/ focal partner
Info: Processes: 216 Uptime: 27m Memory: 3.73 GiB used: 978.3 MiB (25.6%) Init: systemd
v: 245 runlevel: 5 Compilers: gcc: 9.4.0 alt: 9 Client: Unknown python3.8 client
inxi: 3.0.38
Rendszer memóri bővítése
Szia !
Ha nincs különösebb baja, akkor szerintem még jópár évig kiszolgálhat ez a gép.
Egy RAM bővítés csak a hasznára válna.
Beküldte öreg0503 -
Nincs semmi baja, frankó kis gép. Köszi, akkor veszek bele még egy modult.
Van hely a második modulnak?
Beküldte mumorec -
"Memory7 Options DDR3 SDRAM (1600MHz ) 2 slots supporting 2G, 4GB, 8GB7 DIMMs"
https://i.dell.com/sites/csdocuments/Shared-Content_data-Sheets_Document...
Beküldte öreg0503 -
Beküldte öreg0503 -
Igen van.
