Rendszer memóri bővítése
öreg0503 képe
Sziasztok.
Szerintetek érdemes lenne ebbe a lapiba még 4GB rendszer memóriát vennem? Kicsit nehézkes a kicsike, de szeretem. Nyaraláskor ez van velem, és otthon is használom az asztali mellett.
System:    Kernel: 5.4.0-122-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
           Desktop: Cinnamon 5.2.7 wm: muffin dm: LightDM Distro: Linux Mint 20.3 Una
           base: Ubuntu 20.04 focal
Machine:   Type: Laptop System: Dell product: Latitude E6230 v: 01 serial: <filter> Chassis:
           type: 9 serial: <filter>
           Mobo: Dell model: 0YW5N5 v: A00 serial: <filter> UEFI: Dell v: A10 date: 05/20/2013
Battery:   ID-1: BAT0 charge: 29.6 Wh condition: 29.6/66.6 Wh (44%) volts: 12.8/11.1
           model: SMP DELL Y61CV22 serial: <filter> status: Full
CPU:       Topology: Dual Core model: Intel Core i5-3340M bits: 64 type: MT MCP arch: Ivy Bridge
           rev: 9 L2 cache: 3072 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21528
           Speed: 3190 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 3189 2: 3298 3: 3189
           4: 3242
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:0166
           Display: x11 server: X.Org 1.20.13 driver: modesetting unloaded: fbdev,vesa
           resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.2.6
           compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
           Sound Server: ALSA v: k5.4.0-122-generic
Network:   Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e v: 3.2.6-k
           port: f080 bus ID: 00:19.0 chip ID: 8086:1502
           IF: eno1 state: down mac: <filter>
           Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi v: kernel
           port: f040 bus ID: 02:00.0 chip ID: 8086:0082
           IF: wlp2s0 state: up mac: <filter>
Drives:    Local Storage: total: 119.24 GiB used: 20.89 GiB (17.5%)
           ID-1: /dev/sda vendor: Samsung model: SSD 830 Series size: 119.24 GiB speed: 6.0 Gb/s
           serial: <filter>
RAID:      Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0
           bus ID: 00:1f.2 chip ID: 8086.282a
Partition: ID-1: / size: 116.32 GiB used: 20.88 GiB (18.0%) fs: ext4 dev: /dev/sda2
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
           chip ID: 8087:0024
           Device-1: 1-1.5:3 info: Microdia Dell Integrated HD Webcam type: Video driver: uvcvideo
           rev: 2.0 chip ID: 0c45:643f
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 chip ID: 1d6b:0002
           Hub: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
           chip ID: 8087:0024
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 chip ID: 1d6b:0002
           Device-2: 3-2:2 info: SHARKOON 2.4G Mouse type: Mouse driver: hid-generic,usbhid
           rev: 1.1 chip ID: 1ea7:0064
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 60.0 C mobo: 42.0 C sodimm: 37.0 C
           Fan Speeds (RPM): cpu: 0
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
           1: deb http: //packages.linuxmint.com una main upstream import backport #id:linuxmint_main
           2: deb http: //archive.ubuntu.com/ubuntu focal main restricted universe multiverse
           3: deb http: //archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
           4: deb http: //archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ focal partner
Info:      Processes: 216 Uptime: 27m Memory: 3.73 GiB used: 978.3 MiB (25.6%) Init: systemd
           v: 245 runlevel: 5 Compilers: gcc: 9.4.0 alt: 9 Client: Unknown python3.8 client
           inxi: 3.0.38
Szia !
Ha nincs különösebb baja, akkor szerintem még jópár évig kiszolgálhat ez a gép.
Egy RAM bővítés csak a hasznára válna.
öreg0503 képe
#1 Szia.
Nincs semmi baja, frankó kis gép. Köszi, akkor veszek bele még egy modult.
öreg0503 képe
Van hely a második modulnak?
#2 Szia.
Igen van.
öreg0503 képe
#2.1 Köszi, bövebb infó mint amit én írtam.
