Samba_network_nem_látható
 Sziasztok,
segítségeteket kérem. Telepítettem Samba-t 17.3-ra Cinnamon, hogy majd file-okat osztok meg egy 17.2-es XFCE gép között. Azonban a megosztott könyvtár nem látható. A Workgroup sem. Íme az outputok:
$testparm -s
Load smb config files from /etc/samba/smb.conf
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
WARNING: The "syslog" option is deprecated
Processing section "[printers]"
Processing section "[print$]"
Processing section "[share]"
Loaded services file OK.
Server role: ROLE_STANDALONE
# Global parameters
[global]
workgroup = MYHOME
netbios name = ZOLCS
server string = %h server (Samba, Linux Mint)
server role = standalone server
map to guest = Bad User
obey pam restrictions = Yes
pam password change = Yes
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
unix password sync = Yes
syslog = 0
log file = /var/log/samba/log.%m
max log size = 1000
name resolve order = bcast host
preferred master = Yes
domain master = Yes
dns proxy = No
usershare allow guests = Yes
usershare owner only = No
panic action = /usr/share/samba/panic-action %d
idmap config * : backend = tdb
force user = zolcs
[printers]
comment = All Printers
path = /var/spool/samba
create mask = 0700
printable = Yes
browseable = No
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
[share]
path = /media/zolcs/dragon/share
valid users = zolcs
zolcs@zolcs-mint ~ $ smbtree -d3
lp_load_ex: refreshing parameters
Initialising global parameters
Processing section "[global]"
added interface eth0 ip=192.168.1.100 bcast=192.168.1.255 netmask=255.255.255.0
Enter zolcs's password:
tdb(/var/cache/samba/gencache.tdb): tdb_open_ex: could not open file /var/cache/samba/gencache.tdb: Permission denied
name_resolve_bcast: Attempting broadcast lookup for name MYHOME<0x1d>
name_resolve_bcast: Attempting broadcast lookup for name MYHOME<0x1b>
name_resolve_bcast: Attempting broadcast lookup for name __MSBROWSE__<0x1>
zolcs@zolcs-mint ~ $ net rap domain
Enumerating domains:
Domain name          Server name of Browse Master
zolcs@zolcs-mint ~ $ net usershare info --long
[share]
path=/media/zolcs/dragon/share
comment=
usershare_acl=Everyone:F,
1.Az smbtree és a net rap domain üreset dob. Az utolsó parancsban pedig hiányzik a browseable=YES, talán az kéne.
2. Ha megváltoztatom a workgroup nevét az smb.conf-ban WORKGROUP-ra akkor nem látszik a testparm-s parancsban
RE: Samba_network_nem_látható
@#0 Alapvetően nem értek a Samba megosztásokhoz. A 'browsable=yes'-t kipróbáltad (rendszer újraindítás utána)? A workgroup kis betűvel jó. Tulajdonképpen mit változtattál az alap Samba konfigurációs fájban, mik ezek a változtatások? A két gép hogyan kommunikál egymással, egy Router LAN portjára kötve, Switch-en keresztül vagy mi más módon, ezt leírnád pontosan? Jelszó használatban van? Ennek látható 'nyoma' a konfig fájlban?
Csak leírás
https://help.ubuntu.com/community/How%20to%20Create%20a%20Network%20Shar...(Command-line%20interface/Linux%20Terminal)%20-%20Uncomplicated,%20Simple%20and%20Brief%20Way!
valamint
'a fenti beállítások
http://sugo.ubuntu.hu/10.04/html/serverguide/hu/samba-fileserver.html
a helyi hálózat bármely kliensének teljes hozzáférést adnak. Biztonságosabb beállításokért olvassa el a „Samba fájl- és nyomtatókiszolgáló biztonságossá tétele” részt.'
Tipp: a 'create mask = 0700' vélhetően jó 'védelem, ha nem szertenél fájlokat létrehozni, szerkeszteni, futtatni engedni
'create mask: megadja az új fájlok által létrehozásukkor kapott jogosultságokat.'
de ez a sor lehet,
http://serverfault.com/questions/474830/how-does-samba-usershare-acl-par...
így kéne
usershare_acl=S-1-1-0:F
A példa
To get the SID of the a group use:
wbinfo -n "DOMAIN\group"
Melyik fájlkezelőt használod,
https://www.maketecheasier.com/install-and-configure-samba-in-ubuntu-for...
a megosztott könyvtár tulajdonságainál mi látszik?
https://ubuntuforums.org/showthread.php?t=1440664&page=3
Grafikus user hozzáadás?
http://ubuntuhandbook.org/index.php/2014/05/ubuntu1404-file-sharing-samba/
A két -a kliens és a szerver oldali- felhasználónál a
groups
parancs kimenete?
A #13 tipp bevált
https://bugs.launchpad.net/ubuntu/+source/samba/+bug/995817
és egy másik (vázlatban hasonló).
https://forums.linuxmint.com/viewtopic.php?t=224334
-- ezek tippek, én majd csak mostanában használom a Samba-t esetleg.
IG képe
@#04
Próbáld ezt: Írd be az /etc/samba/smb.conf [global] részéhez (egyből a [global] alá!! ):
client use spnego = no
Ezután
sudo service smbd restart.
Forrás:
http://askubuntu.com/questions/758860/samba-share-user-password-error-after-update/763436
https://linuxmint.hu/comment/7250#comment-7250
Hátha megoldja nálad is a problémát...
