Nem érzékeli a mikrofont a Linux Mint
Nem érzékeli a mikrofont a Linux Mint. HP márkájú a laptop. Mellékelek egy képernyőképet.
Kép:
Nem érzékelt mikrofon
inxi -F
adam@adam-HP-Laptop-17-cp2xxx:~$ inxi -F
System:
Host: adam-HP-Laptop-17-cp2xxx Kernel: 6.8.0-55-generic arch: x86_64
bits: 64
Desktop: Cinnamon v: 6.4.8 Distro: Linux Mint 22.1 Xia
Machine:
Type: Laptop System: HP product: HP Laptop 17-cp2xxx v: Type1ProductConfigId
serial:
Mobo: HP model: 8A81 v: 41.23 serial: UEFI: Insyde
v: F.16 date: 05/16/2024
Battery:
ID-1: BAT0 charge: 40.9 Wh (100.0%) condition: 40.9/40.9 Wh (100.0%)
CPU:
Info: quad core model: AMD Ryzen 3 7320U with Radeon Graphics bits: 64
type: MT MCP cache: L2: 2 MiB
Speed (MHz): avg: 523 min/max: 400/4150 cores: 1: 400 2: 400 3: 400
4: 1388 5: 400 6: 400 7: 400 8: 400
Graphics:
Device-1: AMD Mendocino driver: amdgpu v: kernel
Device-2: Chicony HP True Vision HD Camera driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: amdgpu unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa
v: 24.2.8-1ubuntu1~24.04.1 renderer: AMD Radeon 610M (radeonsi
raphael_mendocino LLVM 19.1.1 DRM 3.57 6.8.0-55-generic)
Audio:
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp6x
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
API: ALSA v: k6.8.0-55-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Network:
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ce
IF: wlo1 state: up mac: 1c:ce:51:69:90:19
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb type: USB
Report: hciconfig ID: hci0 state: up address: 1C:CE:51:69:90:18 bt-v: 4.2
Drives:
Local Storage: total: 476.94 GiB used: 12.49 GiB (2.6%)
ID-1: /dev/nvme0n1 vendor: Phison model: PSEJN512GA87EC0 size: 476.94 GiB
Partition:
ID-1: / size: 467.89 GiB used: 12.49 GiB (2.7%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
System Temperatures: cpu: 24.6 C mobo: N/A gpu: amdgpu temp: 24.0 C
Fan Speeds (rpm): N/A
Info:
Memory: total: 8 GiB note: est. available: 7 GiB used: 2.09 GiB (29.9%)
Processes: 321 Uptime: 2h 53m Shell: Bash inxi: 3.3.34
Mivel nem válaszol senki
Gondolom, ha lenne fizikai kapcsoló, arról tudnál. Vagy esetleg egy Fn+valamilyen gomb.
Nyiss egy terminált, és írd be ezt:
alsamixer
És nézd meg a mikrofon csúszkáját, nincs-e némítva.
Ebben látszania kellene a mikrofonnak:
arecord -l
Nézd meg a kernel üzeneteit:
dmesg | grep -i audio
Ezt is megnézheted:
cat /proc/asound/cards
Most nezem. ... Full Inteles regi laptop. Mint 21.3 Cinna. -> mukodik a mikrofon. Mint 22.1 Cinna. telepito livekent inditva -> mukodik a mikrofon. Naprakeszre frissitett Mint 22.1 Cinna, -> nem mukodik/inaktiv a mikrofon. :(
Szerkesztve: Nalam meglett a hiba oka.
A "pavucontrol"-ban (PulseAudio hangeroszabalyzo) "Analog sztereo kimenet"-rol "Analog sztereo ketiranyu"-ra
valtva valt aktivva a mikrofon. https://ibb.co/B2z6Wk10 (Valoszinu valamikor en allitottam el :()
Ööö izé
Hogy kerül a pavucontrol (PulseAudio hangeroszabalyzo) a Mint 22.1 alá?
Mert Mint 22 már pipewire-ra váltott. Kettő hangszerver nyilván ütközéseket okozhat.
Ööö izé
"Hogy kerül a pavucontrol (PulseAudio hangeroszabalyzo) a Mint 22.1 alá?"
Telepitettem. :)
pactl info kimenete:
$ pactl info
Kiszolgáló karakterlánc: /run/user/1000/pulse/native
Programkönyvtár protokollverzió: 35
Kiszolgáló protokollverzió: 35
Helyi: igen
Kliensindex: 68
Csempeméret: 65472
Felhasználónév: ci
Számítógépnév: ci
Kiszolgálónév: PulseAudio (on PipeWire 1.0.5)
Kiszolgáló verzió: 15.0.0
Alapértelmezett mintavételi meghatározás: float32le 2ch 48000Hz
Alapértelmezett csatornaleképzés: front-left,front-right
Alapértelmezett nyelő: alsa_output.pci-0000_00_1b.0.analog-stereo
Alapértelmezett forrás: alsa_input.pci-0000_00_1b.0.analog-stereo
Süti: 247f:23df
Ööö izé
#5 Mi köze van egy hangerőszabályozónak ahhoz, hogy milyen a hangrendszer?
Ööö izé
#7 pavucontrol a pulseaudio-t szabályozza, nem általános célú hangerőszabályzó.
Ööö izé
Ez nem azt jelenti, hogy a PulseAudio a PipeWire "tetején" van?
Ööö izé
A pavucontrol egy hangerőszabályzó. Amivel te kevered, az a pulseaudio, ami egy hangszerver.
Évtizede az első dolgom a semmire sem használható Hang beállító mellé telepíteni a pavucontrolt, ami PipeWire-on is használható.
Állítsd be a Hang beállítóval, hogy melyik bemenet, melyik kimenetre kerüljön, ha van egy BT fejhallgatód, és mondjuk a EasyEffecst, vagy a PulseEffects.
adam@adam-HP-Laptop-17-cp2xxx:~/Dokumentumok$ arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: Generic_1 [HD-Audio Generic], device 0: ALC236 Analog [ALC236 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
adam@adam-HP-Laptop-17-cp2xxx:~/Dokumentumok$ dmesg | grep -i audio
[    3.284417] snd_hda_intel 0000:03:00.1: Handle vga_switcheroo audio client
[    3.315993] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:03:00.1/sound/card0/input12
[    3.318599] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC236: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    3.318613] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.318616] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    3.318620] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    3.318622] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[    3.318625] snd_hda_codec_realtek hdaudioC1D0:      Mic=0x19
[    3.433627] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:03:00.6/sound/card1/input13
[    3.433718] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:03:00.6/sound/card1/input14
[    6.273873] snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
adam@adam-HP-Laptop-17-cp2xxx:~/Dokumentumok$ cat /proc/asound/cards
 0 [Generic        ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xc04c8000 irq 87
 1 [Generic_1      ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xc04c0000 irq 88
