Kis hardver igényű linux telepítés
öreg0503 képe
Sziasztok.
Erre a DELL Latitude lapira keresnék kicsi, gyors oprendszert. Köszönöm ha segítesz választani.
System:
  Kernel: 5.15.0-94-generic x86_64 bits: 64 compiler: gcc v: 11.4.0 Desktop: Xfce 4.18.1
    tk: Gtk 3.24.33 info: xfce4-panel wm: xfwm 4.18.0 vt: 7 dm: LightDM 1.30.0
    Distro: Linux Mint 21.3 Virginia base: Ubuntu 22.04 jammy
Machine:
  Type: Laptop System: Dell product: Latitude E6230 v: 01 serial: <superuser required> Chassis:
    type: 9 serial: <superuser required>
  Mobo: Dell model: 0YW5N5 v: A00 serial: <superuser required> UEFI: Dell v: A10
    date: 05/20/2013
Battery:
  ID-1: BAT0 charge: 4.3 Wh (34.4%) condition: 12.5/66.6 Wh (18.8%) volts: 13.0 min: 11.1
    model: SMP DELL Y61CV22 type: Li-ion serial: <filter> status: Charging
CPU:
  Info: dual core model: Intel Core i5-3340M bits: 64 type: MT MCP smt: enabled arch: Ivy Bridge
    rev: 9 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 3265 high: 3357 min/max: 1200/3400 cores: 1: 3190 2: 3326 3: 3190 4: 3357
    bogomips: 21529
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915 v: kernel ports:
    active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0166 class-ID: 0300
  Device-2: Microdia Dell Integrated HD Webcam type: USB driver: uvcvideo bus-ID: 1-1.5:3
    chip-ID: 0c45:643f class-ID: 0e02
  Display: x11 server: X.Org v: 1.21.1.4 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting unloaded: fbdev,vesa gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
  Monitor-1: LVDS-1 model: LG res: 1366x768 hz: 60 dpi: 125 size: 277x156mm (10.9x6.1")
    diag: 318mm (12.5") modes: 1366x768
  OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 23.2.1-1ubuntu3.1~22.04.2
    direct render: Yes
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.0-94-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e v: kernel port: f080
    bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
  IF: eno1 state: down mac: <filter>
  Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: speed: 2.5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 8086:08b1 class-ID: 0280
  IF: wlp2s0 state: up mac: <filter>
Bluetooth:
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 2-1.5:3
    chip-ID: 8087:07dc class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 2.1 lmp-v: 4.0
    sub-v: 500 hci-v: 4.0 rev: 500
RAID:
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
    bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Drives:
  Local Storage: total: 126.71 GiB used: 11.69 GiB (9.2%)
  ID-1: /dev/sda vendor: Samsung model: SSD 830 Series size: 119.24 GiB speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 3B1Q scheme: GPT
  ID-2: /dev/sdb type: USB model: General USB Flash Disk size: 7.47 GiB type: SSD
    serial: <filter> rev: 1100 scheme: MBR
Partition:
  ID-1: / size: 116.32 GiB used: 11.68 GiB (10.0%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 511 MiB used: 11.9 MiB (2.3%) fs: vfat dev: /dev/sda1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
USB:
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
    class-ID: 0900
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
    chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.5:3 info: Microdia Dell Integrated HD Webcam type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0c45:643f class-ID: 0e02
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
    class-ID: 0900
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s
  Device-1: 2-1.5:3 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:07dc class-ID: e001
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s
    chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 3-1:2 info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 090c:1000
    class-ID: 0806 serial: <filter>
  Device-2: 3-2:3 info: SHARKOON GmbH 2.4GHz Wireless rechargeable vertical mouse [More&Better]
    type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 100mA
    chip-ID: 1ea7:0064 class-ID: 0301
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003
    class-ID: 0900
Sensors:
  System Temperatures: cpu: 50.0 C mobo: 34.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 0
Repos:
  Packages: apt: 2143
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
    1: deb http: //packages.linuxmint.com virginia main upstream import backport
    2: deb http: //archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
    3: deb http: //archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
    4: deb http: //archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
    5: deb http: //security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
Info:
  Processes: 220 Uptime: 5m wakeups: 1 Memory: 7.64 GiB used: 1.02 GiB (13.4%) Init: systemd
  v: 249 runlevel: 5 Compilers: gcc: 11.4.0 alt: 11/12 Client: Unknown python3.10 client
  inxi: 3.3.13
Ami most rajta van
Azzal mi a baj?  Elvileg ez a legoptimálisabb eset, ha ennél kisebb igényű (ami egyre kevesebb van) rendszer kerülne rá, akkor az további kompromisszumokat jelentene a használhatóságot illetően.
Azért kérdem, hogy a jelenlegi rendszerrel mi a baj, mert lehet az olyan jellegű, amit a kisebb igényű rendszer sem oldana meg.
öreg0503 képe
Ami most rajta van
#1 Szia.
Kicst lassúnak találom, főleg Firefox betöltés közben. Meg úgy álltalánosságban is gondolkodik a kattintás és a megjelenés közt 1-2-pár másodpercet. De ez lehet az én hibám az asztali LM 21.3 Cinnamon után ami 8/16 magos AMD Apu proci, és 16 GB DDR4 3200MHc Ram, 2TB SSD. Köszönöm hogy próbálsz segíteni.
Hát ez gyanús
Nyilván az asztali géped jóval erősebb, ha azt akarod elérni, hogy azonos élmény legyen ahhoz erősebb noti kellene, de ezen nem segít könnyebb rendszer sem, mert ami most rajta van, az sem maxolja ki teljesen.
Egy ilyen kategóriájú gépen írok én is most, ezen Cinnamon van, semmiféle késlekedést nem érzékelek, sőt ezen írtam meg a több mint 100 oldalas könyvet, ami csurig van nagy felbontású képekkel.
Illetve most szúrt szemet, hogy a venti nem pörög, és 50 fokos a CPU, annál azért már működnie kellene.
Vidd  el szervizbe a gépet, takarítsák ki, pasztázzák újra amit kell, vélhetően masszívan tele van porral, annyira, hogy a venti nem bír forogni, vagy nem működik egyáltalán, akkor cseréljék ki. Ettől fel fog gyorsulni, és lehet így olcsóbb, mint egy erősebb, használt laptop, mert mostanában ezeknek is egekben az ára.
öreg0503 képe
Hát ez gyanús
#2 Köszi.
Hát igen, nálam van a lapi 4-5 éve és hozzá sem lett nyúlva, csak memória bővítés és merevlemez-ssd-re cserélve. Akkor lesz egy nagy "generál" Köszi szépen a segítséget.
öreg0503 képe
Hát ez gyanús
#2 Feltettem a LM 21.3 Cinnamont. Úgy érzem ez gyorsabb, és nincs "annyi" gondolkodási idő. Ez lehetséges, hisz ez nem egy könnyű fajsúlyú rendszer?  Mindegy, marad ez. Az asztalin teljesen meg vagyok vele elégedve. Köszi a segítséget.
Hát ez gyanús
#2.2 A Cinnamon már elég régen nem számít nagy igényűnek. Ettől függetlenül a generál karbantartást nem kellene elhanyagolni, mert akár tönkre is mehet idővel emiatt a gép.
csuhas32 képe
Megvan még a Mint 21.3 Xfce?
#2.2 Megvan még a Mint 21.3 Xfce vagy a helyére telepítetted a Cinnamon felületűt?
Ha még megvan, akkor kíváncsiságból próbálj meg benne egy új felhasználót létrehozni és azzal kipróbálni.
Ez egy viszonylag erős gép, normális esetben ezen nem szabadna akadoznia egyetlen felületnek sem.
öreg0503 képe
#2.2.2 A helyére telepítettem.
Szia,
Szia,
Nekem legjobban a Cinnamon jött be a mintek közül. Ha van kedved akkor esetleg próbálj ki egy Mabox linuxot, vagy ha bátrabb vagy akkor egy Bunsenlab-t.
öreg0503 képe
Szia,
#3 Köszi, jó nekem a mint is.
Nekem i5-3210M van a
Nekem i5-3210M van a Samsungban. Durván pörög a hűtés bármit is indítok. Néha szülinapokon erről megy a zene. Alig győzi már. Van az a pont, amikor a hardver már nem győzi tartani a lépést a szoftverrel. És az abba feccelt energia hogy még üzemben tartsd több mint amit kiveszel belőle. Szóval egy karaoke partyt is nehezen visz szaggatás nélkül. Sajnálom mert nagyon szeretem ezt a laptopot. Az egyik legbstrapabíróbb laptop amit valaha legyártottak. Azért az Intel 3000-es széria az már nem mai gyerek. Esetleg képernyő nélkül valamilyen szervernek jó lenne, csak nem gigabites a hálókártya rajta, és nem igazán arra lett tervezve hogy 24 órán át be legyen kapcsolva... Addig fogom néha néha elővenni, míg bekapcsol. Aztán kuka.
i3 M 390, 8 GB RAM
LM 21.3, Cinna, és jól megy, persze, rendszeresen évente szétkapva, portalanítva, pasztázva.
