Szép napot. szeretném kézzel frissiteni a xfce környezetet. Sokat olvastam erröl. egy tömöritet könyvtárban szedem le ".tar.bz2" ki tömöritem, meg nyitom a kitömöritet mappában a terminált, be irom hogy
./configure
./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether UID '1000' is supported by ustar format... yes
checking whether GID '1000' is supported by ustar format... yes
checking how to create a ustar tar archive... gnutar
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether make supports nested variables... (cached) yes
checking whether make supports the include directive... yes (GNU style)
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for fgrep... /bin/grep -F
checking how to print strings... printf
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking whether NLS is requested... yes
checking for intltool >= 0.35.0... 0.51.0 found
checking for intltool-update... /usr/bin/intltool-update
checking for intltool-merge... /usr/bin/intltool-merge
checking for intltool-extract... /usr/bin/intltool-extract
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for perl... /usr/bin/perl
checking for perl >= 5.8.1... 5.30.0
checking for XML::Parser... ok
checking for perl5... no
checking for perl... perl
checking for a sed that does not truncate output... (cached) /bin/sed
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for ANSI C header files... (cached) yes
checking for stdlib.h... (cached) yes
checking for unistd.h... (cached) yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for string.h... (cached) yes
checking math.h usability... yes
checking math.h presence... yes
checking for math.h... yes
checking for sys/types.h... (cached) yes
checking sys/wait.h usability... yes
checking sys/wait.h presence... yes
checking for sys/wait.h... yes
checking for memory.h... (cached) yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking sys/prctl.h usability... yes
checking sys/prctl.h presence... yes
checking for sys/prctl.h... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking for bind_textdomain_codeset... yes
checking for locale.h... (cached) yes
checking for LC_MESSAGES... yes
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for libintl.h... (cached) yes
checking for ngettext in libc... yes
checking for dgettext in libc... yes
checking for bind_textdomain_codeset... (cached) yes
checking for msgfmt... (cached) /usr/bin/msgfmt
checking for dcgettext... yes
checking if msgfmt accepts -c... yes
checking for gmsgfmt... (cached) /usr/bin/msgfmt
checking for xgettext... (cached) /usr/bin/xgettext
checking for catalogs to be installed... eo en_GB ca zh_CN nb tr en_AU fr eu gl be zh_TW th sr fi pl ast it he et pt_BR ka de sl pa zh_HK nl hy_AM ja hu nn si ar ko es kk ur sk am te hr sq pt cs is uk hye bn ur_PK id vi da ug lv el sv ru ie lt ms ro bg oc
checking for locales directory... ${prefix}/share/locale
checking for additional xgettext flags... --keyword=Q_ --from-code=UTF-8
checking for X... libraries , headers
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for main in -lX11... yes
checking for gdbus-codegen... /usr/bin/gdbus-codegen
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for libxfce4util-1.0 >= 4.15.6... not found
*** The required package libxfce4util-1.0 was not found on your system.
*** Please install libxfce4util-1.0 (atleast version 4.15.6) or adjust
*** the PKG_CONFIG_PATH environment variable if you
*** installed the package in a nonstandard prefix so that
*** pkg-config is able to find it.
le fut és utána be irom hogy
make
És hibát ir ki. Lehet valamit ki hagytam. Vagy nem figyeltem.
make: *** No targets specified and no makefile found. Stop.
Valaki frissitet kézzel cfce környezetet? Nagyon meg kösszönném a segitséget.
tisztelettel: Norbert
Xfce4
Az asztali környezet nem egyetlen csomag.
Találtál belőle egy, az egyben csomagot? Hol?
Az Xfce4 Staging PPA (külső tükör) használatát javaslom, ezét:
https://launchpad.net/~xubuntu-dev/+archive/ubuntu/staging
( https://www.linuxuprising.com/2021/01/how-to-install-xfce-416-on-xubuntu-2004.html )
A Linux Mint 20.x kiadásokra használható, a 19.x kiadás csomagjai nincsenek a tükrön.
A PPA az LMDE 4 kiadásnál nem használható!
Nekem úgy tűnik, jelenleg ez a PPA az, amit ténylegesen és gyakran frissítenek. de a felvétele előtt készíts egy rendszermentést.
És azt is tudnod kell, hogy a Linux Mint saját alkalmazásai lehetséges, hogy nem fognak működni, ugyanis azok nincsenek a PPA-n ..., de megnézheted milyen az eredmény, és, ha nem jó, akkor visszaállsz a rendszermentésre.
Miért frissítenél, milyen újdonság jön be neked?
A forgatás trükkjei
Sok részből áll a csomag, de egy függőség a rendszeremen megvan (-dev csomagokat kell nézni a forgatáskor), viszont ezt csak érdekességként írom!
A jelzés:
A hiányzó függőség keresése:
A találat (létezik csomag):
A találat verziószámára keresés és a keresés kimenete (Debian rendszer, te más kimenetet kapsz):
apt-cache policy libxfce4util-dev libxfce4util-dev: Telepítve: (nincs) Jelölt: 4.12.1-3 Verziótáblázat: 4.12.1-3 500 500 http://httpredir.debian.org/debian buster/main amd64 PackagesA kimenet az, ami, de ugye, kisebb a verziószáma, mint amit kér a forgatandó csomag.
>= 4.15.6 --> legalább ez vagy nagyobb legyen a verziószám.
Valaki frissitet kézzel Xfce
Valaki frissitet kézzel Xfce környezetet? Nagyon meg kösszönném a segitséget.
A PPA lehet a megoldás, mivel - ahogy említettem, az asztali környezet nem egy csomagból áll (elképzelésnek jó :), hanem sokból - és egy-egy csomag egymásnak is függősége, azaz többet kéne leforgatnod, abban a sorrendben, ahogy azt kell. A PPA fejlesztői megoldják helyetted.
Viszont a Linux Mint saját Xfce-s alkalmazásai, ismétlem, nem fognak frissülni. A PPA elsősorban az Ubuntu kiadásokra készül, és az Ubuntu-val korántsem egyezik meg a Linux Mint, pl. saját alkalmazások vannak a Mintnél, melyek - az alkalmazások és az alkalmazások függőségei is - a Mint tükrökről frissülnek. Ennek ellenére érdemes próbálkoznod, már csak az eredmény miatt (egy rendszer-visszaállítási pont birtokában tedd). A próbálkozással is sokat tanulsz, érdekes felfedezéseket tehetsz.
Nem egyedi a viselkedés, a Cinnamon asztali környezete is így volt frissíthető egykoron egy újabb verzióra (mint próba, szerencse változat, saját felelősségre). A bejegyzést nem találom, de az volt, hogy Clem (a Cinnamon vezető fejlesztője) csomagokat hozott létre, illetőleg egy telepítő scriptet is. Enélkül (script) igen nehéz és hosszadalmas csomag forgatással asztai környezetet frissíteni. Erre van pl. a PPA (vagy az AppImage, a Flatpak, a Snap) a Linux Mintre, az LMDE 4 kiadásnál pedig a Debian Backports. Kisebb alkalmazásokat könnyebb forgatni..., viszont a forgatás az utolsó megoldás, érdemes olyan megoldást keresni, ahol a csomag frissül. Forgatásnál a csomag nem frissül.
Beküldte Norbert31 -
./configure
make
Miből gondolod, ha kétszer felteszed ugyanabban a formában ugyanazt a kérdést, akkor hatékonyabban kérdezel?
Egyszer itt,
https://linuxmint.hu/forum/xfce-kornyezet-kezi-frissitese
egyszer itt
https://linuxmint.hu/comment/47422#comment-47422
kérdezted ugyanazt:
És hibát ir ki.
Választ is kaptál a kérdésedre. Valamit nem értesz a válaszokból és mi lenne az?
A válaszok elolvasását hagytad ki! Pótolható! :) Szép napot!
Pedig ezt írod a kérdésre:
Milyen céllal regisztrálsz az oldalra? Kérünk, írj egy-két mondatot!
Olvasni
Nagyon köszönöm a segitséget.
Nagyon köszönöm a segitséget. :) Régota használok linuxot. ugy kb 5 éve. És örülök hogy meg szabadultam a windowstol
Véleltlen volt. Azt hittm nem
Véleltlen volt. Azt hittm nem mentette el. Bent ragadtam és késön vettem észre.
Vágólapon ragadt a szöveg, előfordul.
Szeretni is lehet.
Az eredményről számolj be (Xfce4)! :)
@# fel vettem a tároloba. és frissitettem.hibát nem tapasztalok. Talán annyit hogy kicsit gyorsabb lett. Meg letisztultabb
Innen adtam hozzá, ami ajálva lett.
alkalmazások el indulnak.
alkalmazások el indulnak. Minden rendben van.
A Szoftverkezelő is? Majd ilyeneket is nézz meg.
Egyébként: ujjé, ujjé!
Igen, igen. Nagyon gyors lett. szép is.
https://kepkuldes.com/image/97lRFi
https://kepkuldes.com/image/97lEoc
Szuper! :)
Kérlek, a jövőben a képmegosztáshoz az Imgur vagy az imgBB oldalak egyikét használd (érdemes regisztrálni is). Mert ahol most megosztottad, egy-két év múlva törli a tartalmat, és szeretnénk mindig látni.
Javitva. :)
Javitva. :)
https://ibb.co/4tQnp8p
https://ibb.co/Ws5HXkg
Javitva. :)
Köszi. :)
