Szia mindenkinek! Sajnos nekem is TL-WN725N adapterrel van gondom,minden úgy néz ki,hogy működik,csak mégsincs Net-em!
Kipróbáltam a <dmesg> parancso meg,az <inxi -r> hát valami eszméletlen hosszi listát ír ki,ha belefér én bemásolom!?
peti@pin:~$ lsusb
Bus 001 Device 002: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 002 Device 002: ID 1ea7:0064 SHARKOON Technologies GmbH
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
peti@pin:~$ dmesg
[ 0.000000] Linux version 4.19.0-13-amd64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.160-2 (2020-11-28)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-13-amd64 root=UUID=d3595fba-6ad9-48c5-93e7-146ec3e3c85f ro quiet splash
[ 0.000000] x86/fpu: x87 FPU will use FXSAVE
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009f7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e7000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000dffaffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dffb0000-0x00000000dffbffff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000dffc0000-0x00000000dffeffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000dfff0000-0x00000000dfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fff00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000011fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./N68C-S UCC, BIOS P1.60 09/19/2011
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3013.555 MHz processor
[ 0.006010] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.006011] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.011825] AGP: No AGP bridge found
[ 0.011878] last_pfn = 0x120000 max_arch_pfn = 0x400000000
[ 0.011881] MTRR default type: uncachable
[ 0.011882] MTRR fixed ranges enabled:
[ 0.011883] 00000-9FFFF write-back
[ 0.011884] A0000-EFFFF uncachable
[ 0.011884] F0000-FFFFF write-protect
[ 0.011885] MTRR variable ranges enabled:
[ 0.011886] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.011887] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.011888] 2 base 0000C0000000 mask FFFFE0000000 write-back
[ 0.011889] 3 disabled
[ 0.011889] 4 disabled
[ 0.011890] 5 disabled
[ 0.011890] 6 disabled
[ 0.011891] 7 disabled
[ 0.011891] TOM2: 0000000120000000 aka 4608M
[ 0.013022] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.013075] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[ 0.013080] last_pfn = 0xdffb0 max_arch_pfn = 0x400000000
[ 0.016635] found SMP MP-table at [mem 0x000ff780-0x000ff78f]
[ 0.023128] Using GB pages for direct mapping
[ 0.023380] RAMDISK: [mem 0x31547000-0x34a9afff]
[ 0.023389] ACPI: Early table checksum verification disabled
[ 0.023714] ACPI: RSDP 0x00000000000FB580 000014 (v00 ACPIAM)
[ 0.023717] ACPI: RSDT 0x00000000DFFB0000 000040 (v01 A_M_I OEMRSDT 09001119 MSFT 00000097)
[ 0.023721] ACPI: FACP 0x00000000DFFB0200 000084 (v02 A_M_I OEMFACP 12000601 MSFT 00000097)
[ 0.023725] ACPI: DSDT 0x00000000DFFB0460 00495C (v01 AS361 AS361151 00000151 INTL 20051117)
[ 0.023728] ACPI: FACS 0x00000000DFFC0000 000040
[ 0.023730] ACPI: APIC 0x00000000DFFB0390 000090 (v01 A_M_I OEMAPIC 09001119 MSFT 00000097)
[ 0.023732] ACPI: MCFG 0x00000000DFFB0420 00003C (v01 A_M_I OEMMCFG 09001119 MSFT 00000097)
[ 0.023734] ACPI: OEMB 0x00000000DFFC0040 000061 (v01 A_M_I AMI_OEM 09001119 MSFT 00000097)
[ 0.023736] ACPI: SRAT 0x00000000DFFB4DC0 000108 (v03 AMD FAM_F_10 00000002 AMD 00000001)
[ 0.023738] ACPI: AAFT 0x00000000DFFB4ED0 000027 (v01 A_M_I OEMAAFT 09001119 MSFT 00000097)
[ 0.023740] ACPI: SSDT 0x00000000DFFB4F00 000DA4 (v01 A M I POWERNOW 00000001 AMD 00000001)
[ 0.023749] ACPI: Local APIC address 0xfee00000
[ 0.023777] SRAT: PXM 0 -> APIC 0x00 -> Node 0
[ 0.023778] SRAT: PXM 0 -> APIC 0x01 -> Node 0
[ 0.023779] SRAT: PXM 0 -> APIC 0x02 -> Node 0
[ 0.023779] SRAT: PXM 0 -> APIC 0x03 -> Node 0
[ 0.023780] SRAT: PXM 0 -> APIC 0x04 -> Node 0
[ 0.023780] SRAT: PXM 0 -> APIC 0x05 -> Node 0
[ 0.023782] ACPI: SRAT: Node 0 PXM 0 [mem 0x00000000-0x0009ffff]
[ 0.023783] ACPI: SRAT: Node 0 PXM 0 [mem 0x00100000-0xdfffffff]
[ 0.023784] ACPI: SRAT: Node 0 PXM 0 [mem 0x100000000-0x11fffffff]
[ 0.023786] NUMA: Node 0 [mem 0x00000000-0x0009ffff] + [mem 0x00100000-0xdfffffff] -> [mem 0x00000000-0xdfffffff]
[ 0.023787] NUMA: Node 0 [mem 0x00000000-0xdfffffff] + [mem 0x100000000-0x11fffffff] -> [mem 0x00000000-0x11fffffff]
[ 0.023790] NODE_DATA(0) allocated [mem 0x11fff9000-0x11fffdfff]
[ 0.023819] Zone ranges:
[ 0.023820] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.023821] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.023821] Normal [mem 0x0000000100000000-0x000000011fffffff]
[ 0.023822] Device empty
[ 0.023823] Movable zone start for each node
[ 0.023823] Early memory node ranges
[ 0.023824] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.023825] node 0: [mem 0x0000000000100000-0x00000000dffaffff]
[ 0.023825] node 0: [mem 0x0000000100000000-0x000000011fffffff]
[ 0.023831] Zeroed struct page in unavailable ranges: 178 pages
[ 0.023832] Initmem setup node 0 [mem 0x0000000000001000-0x000000011fffffff]
[ 0.023833] On node 0 totalpages: 1048398
[ 0.023834] DMA zone: 64 pages used for memmap
[ 0.023834] DMA zone: 21 pages reserved
[ 0.023835] DMA zone: 3998 pages, LIFO batch:0
[ 0.023917] DMA32 zone: 14271 pages used for memmap
[ 0.023917] DMA32 zone: 913328 pages, LIFO batch:63
[ 0.043623] Normal zone: 2048 pages used for memmap
[ 0.043624] Normal zone: 131072 pages, LIFO batch:31
[ 0.046421] Nvidia board detected. Ignoring ACPI timer override.
[ 0.046422] If you got timer trouble try acpi_use_timer_override
[ 0.046550] ACPI: PM-Timer IO Port: 0x508
[ 0.046551] ACPI: Local APIC address 0xfee00000
[ 0.046566] IOAPIC[0]: apic_id 6, version 17, address 0xfec00000, GSI 0-23
[ 0.046568] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.046568] ACPI: BIOS IRQ0 override ignored.
[ 0.046569] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.046571] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
[ 0.046571] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
[ 0.046573] ACPI: IRQ9 used by override.
[ 0.046573] ACPI: IRQ14 used by override.
[ 0.046574] ACPI: IRQ15 used by override.
[ 0.046575] Using ACPI (MADT) for SMP configuration information
[ 0.046577] smpboot: Allowing 6 CPUs, 0 hotplug CPUs
[ 0.046590] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.046591] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.046592] PM: Registered nosave memory: [mem 0x000a0000-0x000e6fff]
[ 0.046592] PM: Registered nosave memory: [mem 0x000e7000-0x000fffff]
[ 0.046593] PM: Registered nosave memory: [mem 0xdffb0000-0xdffbffff]
[ 0.046594] PM: Registered nosave memory: [mem 0xdffc0000-0xdffeffff]
[ 0.046594] PM: Registered nosave memory: [mem 0xdfff0000-0xdfffffff]
[ 0.046595] PM: Registered nosave memory: [mem 0xe0000000-0xfebfffff]
[ 0.046595] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.046596] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[ 0.046596] PM: Registered nosave memory: [mem 0xfee00000-0xfeefffff]
[ 0.046597] PM: Registered nosave memory: [mem 0xfef00000-0xffefffff]
[ 0.046597] PM: Registered nosave memory: [mem 0xfff00000-0xffffffff]
[ 0.046599] [mem 0xe0000000-0xfebfffff] available for PCI devices
[ 0.046600] Booting paravirtualized kernel on bare hardware
[ 0.046603] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.144340] random: get_random_bytes called from start_kernel+0x93/0x52a with crng_init=0
[ 0.144345] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:6 nr_node_ids:1
[ 0.144944] percpu: Embedded 45 pages/cpu s144536 r8192 d31592 u262144
[ 0.144949] pcpu-alloc: s144536 r8192 d31592 u262144 alloc=1*2097152
[ 0.144950] pcpu-alloc: [0] 0 1 2 3 4 5 - -
[ 0.144968] Built 1 zonelists, mobility grouping on. Total pages: 1031994
[ 0.144969] Policy zone: Normal
[ 0.144970] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-13-amd64 root=UUID=d3595fba-6ad9-48c5-93e7-146ec3e3c85f ro quiet splash
[ 0.159193] AGP: Checking aperture...
[ 0.165004] AGP: No AGP bridge found
[ 0.165007] AGP: Node 0: aperture [bus addr 0xd0000000-0xd1ffffff] (32MB)
[ 0.165008] Aperture pointing to e820 RAM. Ignoring.
[ 0.165008] AGP: Your BIOS doesn't leave an aperture memory hole
[ 0.165009] AGP: Please enable the IOMMU option in the BIOS setup
[ 0.165009] AGP: This costs you 64MB of RAM
[ 0.165011] AGP: Mapping aperture over RAM [mem 0xd4000000-0xd7ffffff] (65536KB)
[ 0.165013] PM: Registered nosave memory: [mem 0xd4000000-0xd7ffffff]
[ 0.181825] Memory: 3916008K/4193592K available (10252K kernel code, 1242K rwdata, 3320K rodata, 1596K init, 2264K bss, 277584K reserved, 0K cma-reserved)
[ 0.181948] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.181955] ftrace: allocating 31960 entries in 125 pages
[ 0.191085] rcu: Hierarchical RCU implementation.
[ 0.191087] rcu: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=6.
[ 0.191088] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.193904] NR_IRQS: 33024, nr_irqs: 472, preallocated irqs: 16
[ 0.194202] spurious 8259A interrupt: IRQ7.
[ 0.197919] Console: colour VGA+ 80x25
[ 0.197924] console [tty0] enabled
[ 0.197943] ACPI: Core revision 20180810
[ 0.198032] APIC: Switch to symmetric I/O mode setup
[ 0.198607] ..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1
[ 0.218033] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b704a318ab, max_idle_ns: 440795299904 ns
[ 0.218042] Calibrating delay loop (skipped), value calculated using timer frequency.. 6027.11 BogoMIPS (lpj=12054220)
[ 0.218044] pid_max: default: 32768 minimum: 301
[ 0.218079] Security Framework initialized
[ 0.218080] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.218097] AppArmor: AppArmor initialized
[ 0.219174] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.219702] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.219731] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.219748] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.219969] LVT offset 0 assigned for vector 0xf9
[ 0.219973] Last level iTLB entries: 4KB 512, 2MB 16, 4MB 8
[ 0.219973] Last level dTLB entries: 4KB 512, 2MB 128, 4MB 64, 1GB 0
[ 0.219975] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.219976] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.219977] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.224237] Freeing SMP alternatives memory: 24K
[ 0.333608] smpboot: CPU0: AMD Processor model unknown (family: 0x10, model: 0xa, stepping: 0x0)
[ 0.333723] Performance Events: AMD PMU driver.
[ 0.333727] ... version: 0
[ 0.333727] ... bit width: 48
[ 0.333728] ... generic registers: 4
[ 0.333728] ... value mask: 0000ffffffffffff
[ 0.333729] ... max period: 00007fffffffffff
[ 0.333729] ... fixed-purpose events: 0
[ 0.333729] ... event mask: 000000000000000f
[ 0.333770] rcu: Hierarchical SRCU implementation.
[ 0.334034] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.334034] smp: Bringing up secondary CPUs ...
[ 0.334034] x86: Booting SMP configuration:
[ 0.334034] .... node #0, CPUs: #1 #2 #3 #4 #5
[ 0.344070] smp: Brought up 1 node, 6 CPUs
[ 0.344070] smpboot: Max logical packages: 1
[ 0.344070] smpboot: Total of 6 processors activated (36162.66 BogoMIPS)
[ 0.346428] devtmpfs: initialized
[ 0.346428] x86/mm: Memory block size: 128MB
[ 0.346489] PM: Registering ACPI NVS region [mem 0xdffc0000-0xdffeffff] (196608 bytes)
[ 0.346489] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.346489] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.346489] pinctrl core: initialized pinctrl subsystem
[ 0.346489] NET: Registered protocol family 16
[ 0.346537] audit: initializing netlink subsys (disabled)
[ 0.346542] audit: type=2000 audit(1615310009.148:1): state=initialized audit_enabled=0 res=1
[ 0.346542] cpuidle: using governor ladder
[ 0.346542] cpuidle: using governor menu
[ 0.346542] node 0 link 0: io port [1000, ffffff]
[ 0.346542] TOM: 00000000e0000000 aka 3584M
[ 0.346542] Fam 10h mmconf [mem 0xfc000000-0xfdffffff]
[ 0.346542] node 0 link 0: mmio [fc000000, fdffffff] ==> none
[ 0.346542] node 0 link 0: mmio [e0000000, fbffffff]
[ 0.346542] node 0 link 0: mmio [fe000000, fe0bffff]
[ 0.346542] node 0 link 0: mmio [a0000, bffff]
[ 0.346542] TOM2: 0000000120000000 aka 4608M
[ 0.346542] bus: [bus 00-07] on node 0 link 0
[ 0.346542] bus: 00 [io 0x0000-0xffff]
[ 0.346542] bus: 00 [mem 0xe0000000-0xfbffffff]
[ 0.346542] bus: 00 [mem 0xfe000000-0xffffffff]
[ 0.346542] bus: 00 [mem 0x000a0000-0x000bffff]
[ 0.346542] bus: 00 [mem 0x120000000-0xfcffffffff]
[ 0.346542] ACPI: bus type PCI registered
[ 0.346542] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.346542] PCI: MMCONFIG for domain 0000 [bus 00-1f] at [mem 0xfc000000-0xfdffffff] (base 0xfc000000)
[ 0.346542] PCI: not using MMCONFIG
[ 0.346542] PCI: Using configuration type 1 for base access
[ 0.346542] PCI: Using configuration type 1 for extended access
[ 0.346542] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.346542] mtrr: probably your BIOS does not setup all CPUs.
[ 0.346542] mtrr: corrected configuration.
[ 0.346809] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.346809] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.350107] ACPI: Added _OSI(Module Device)
[ 0.350107] ACPI: Added _OSI(Processor Device)
[ 0.350108] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.350109] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.350109] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.350110] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.352012] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.352890] ACPI: Interpreter enabled
[ 0.352907] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.352908] ACPI: Using IOAPIC for interrupt routing
[ 0.352925] PCI: MMCONFIG for domain 0000 [bus 00-1f] at [mem 0xfc000000-0xfdffffff] (base 0xfc000000)
[ 0.353525] PCI: MMCONFIG at [mem 0xfc000000-0xfdffffff] reserved in ACPI motherboard resources
[ 0.353539] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.353724] ACPI: Enabled 10 GPEs in block 00 to 1F
[ 0.358815] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.358819] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.358822] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.358831] acpi PNP0A03:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-1f] only partially covers this bridge
[ 0.358952] PCI host bridge to bus 0000:00
[ 0.358953] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.358955] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.358956] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.358957] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
[ 0.358958] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xff37ffff window]
[ 0.358959] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.358975] pci 0000:00:00.0: [10de:03e2] type 00 class 0x050000
[ 0.359178] pci 0000:00:01.0: [10de:03e1] type 00 class 0x060100
[ 0.359186] pci 0000:00:01.0: reg 0x10: [io 0x0900-0x09ff]
[ 0.359250] pci 0000:00:01.1: [10de:03eb] type 00 class 0x0c0500
[ 0.359260] pci 0000:00:01.1: reg 0x10: [io 0xdc00-0xdc3f]
[ 0.359272] pci 0000:00:01.1: reg 0x20: [io 0x0600-0x063f]
[ 0.359275] pci 0000:00:01.1: reg 0x24: [io 0x0700-0x073f]
[ 0.359298] pci 0000:00:01.1: PME# supported from D3hot D3cold
[ 0.359348] pci 0000:00:01.2: [10de:03f5] type 00 class 0x050000
[ 0.359411] pci 0000:00:02.0: [10de:03f1] type 00 class 0x0c0310
[ 0.359419] pci 0000:00:02.0: reg 0x10: [mem 0xfbeff000-0xfbefffff]
[ 0.359448] pci 0000:00:02.0: supports D1 D2
[ 0.359449] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.359493] pci 0000:00:02.1: [10de:03f2] type 00 class 0x0c0320
[ 0.359502] pci 0000:00:02.1: reg 0x10: [mem 0xfbefec00-0xfbefecff]
[ 0.359535] pci 0000:00:02.1: supports D1 D2
[ 0.359536] pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.359588] pci 0000:00:04.0: [10de:03f3] type 01 class 0x060401
[ 0.359654] pci 0000:00:05.0: [10de:03f0] type 00 class 0x040300
[ 0.359663] pci 0000:00:05.0: reg 0x10: [mem 0xfbef8000-0xfbefbfff]
[ 0.359697] pci 0000:00:05.0: PME# supported from D3hot D3cold
[ 0.359748] pci 0000:00:06.0: [10de:03ec] type 00 class 0x01018a
[ 0.359767] pci 0000:00:06.0: reg 0x20: [io 0xffa0-0xffaf]
[ 0.359775] pci 0000:00:06.0: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.359776] pci 0000:00:06.0: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.359777] pci 0000:00:06.0: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.359778] pci 0000:00:06.0: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.359829] pci 0000:00:07.0: [10de:03ef] type 00 class 0x068000
[ 0.359836] pci 0000:00:07.0: reg 0x10: [mem 0xfbefd000-0xfbefdfff]
[ 0.359839] pci 0000:00:07.0: reg 0x14: [io 0xd480-0xd487]
[ 0.359865] pci 0000:00:07.0: supports D1 D2
[ 0.359866] pci 0000:00:07.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.359915] pci 0000:00:08.0: [10de:03f6] type 00 class 0x010185
[ 0.359921] pci 0000:00:08.0: reg 0x10: [io 0xd400-0xd407]
[ 0.359924] pci 0000:00:08.0: reg 0x14: [io 0xd080-0xd083]
[ 0.359926] pci 0000:00:08.0: reg 0x18: [io 0xd000-0xd007]
[ 0.359929] pci 0000:00:08.0: reg 0x1c: [io 0xcc00-0xcc03]
[ 0.359931] pci 0000:00:08.0: reg 0x20: [io 0xc880-0xc88f]
[ 0.359934] pci 0000:00:08.0: reg 0x24: [mem 0xfbefc000-0xfbefcfff]
[ 0.359994] pci 0000:00:08.1: [10de:03f6] type 00 class 0x010185
[ 0.360001] pci 0000:00:08.1: reg 0x10: [io 0xc800-0xc807]
[ 0.360003] pci 0000:00:08.1: reg 0x14: [io 0xc480-0xc483]
[ 0.360006] pci 0000:00:08.1: reg 0x18: [io 0xc400-0xc407]
[ 0.360009] pci 0000:00:08.1: reg 0x1c: [io 0xc080-0xc083]
[ 0.360011] pci 0000:00:08.1: reg 0x20: [io 0xc000-0xc00f]
[ 0.360014] pci 0000:00:08.1: reg 0x24: [mem 0xfbef7000-0xfbef7fff]
[ 0.360072] pci 0000:00:09.0: [10de:03e8] type 01 class 0x060400
[ 0.360100] pci 0000:00:09.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.360153] pci 0000:00:0b.0: [10de:03e9] type 01 class 0x060400
[ 0.360175] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.360222] pci 0000:00:0c.0: [10de:03e9] type 01 class 0x060400
[ 0.360244] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.360298] pci 0000:00:18.0: [1022:1200] type 00 class 0x060000
[ 0.360341] pci 0000:00:18.1: [1022:1201] type 00 class 0x060000
[ 0.360383] pci 0000:00:18.2: [1022:1202] type 00 class 0x060000
[ 0.360425] pci 0000:00:18.3: [1022:1203] type 00 class 0x060000
[ 0.360468] pci 0000:00:18.4: [1022:1204] type 00 class 0x060000
[ 0.360524] pci_bus 0000:01: extended config space not accessible
[ 0.360560] pci 0000:00:04.0: PCI bridge to [bus 01] (subtractive decode)
[ 0.360563] pci 0000:00:04.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.360564] pci 0000:00:04.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.360565] pci 0000:00:04.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.360566] pci 0000:00:04.0: bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
[ 0.360568] pci 0000:00:04.0: bridge window [mem 0xe0000000-0xff37ffff window] (subtractive decode)
[ 0.360599] pci 0000:02:00.0: [1002:6779] type 00 class 0x030000
[ 0.360616] pci 0000:02:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.360624] pci 0000:02:00.0: reg 0x18: [mem 0xfbfe0000-0xfbffffff 64bit]
[ 0.360629] pci 0000:02:00.0: reg 0x20: [io 0xe000-0xe0ff]
[ 0.360639] pci 0000:02:00.0: reg 0x30: [mem 0xfbfc0000-0xfbfdffff pref]
[ 0.360643] pci 0000:02:00.0: enabling Extended Tags
[ 0.360675] pci 0000:02:00.0: supports D1 D2
[ 0.360723] pci 0000:02:00.1: [1002:aa98] type 00 class 0x040300
[ 0.360740] pci 0000:02:00.1: reg 0x10: [mem 0xfbfbc000-0xfbfbffff 64bit]
[ 0.360767] pci 0000:02:00.1: enabling Extended Tags
[ 0.360797] pci 0000:02:00.1: supports D1 D2
[ 0.370088] pci 0000:00:09.0: PCI bridge to [bus 02]
[ 0.370098] pci 0000:00:09.0: bridge window [io 0xe000-0xefff]
[ 0.370103] pci 0000:00:09.0: bridge window [mem 0xfbf00000-0xfbffffff]
[ 0.370109] pci 0000:00:09.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.370210] pci 0000:00:0b.0: PCI bridge to [bus 03]
[ 0.370234] pci 0000:00:0c.0: PCI bridge to [bus 04]
[ 0.370699] ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *0, disabled.
[ 0.370755] ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *0, disabled.
[ 0.370808] ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *0, disabled.
[ 0.370861] ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
[ 0.370914] ACPI: PCI Interrupt Link [LNEA] (IRQs 16 17 18 19) *11
[ 0.370966] ACPI: PCI Interrupt Link [LNEB] (IRQs 16 17 18 19) *0, disabled.
[ 0.371019] ACPI: PCI Interrupt Link [LNEC] (IRQs 16 17 18 19) *0, disabled.
[ 0.371071] ACPI: PCI Interrupt Link [LNED] (IRQs 16 17 18 19) *10
[ 0.371124] ACPI: PCI Interrupt Link [LUB0] (IRQs 20 21 22 23) *5
[ 0.371176] ACPI: PCI Interrupt Link [LUB2] (IRQs 20 21 22 23) *10
[ 0.371229] ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22 23) *5
[ 0.371281] ACPI: PCI Interrupt Link [LAZA] (IRQs 20 21 22 23) *11
[ 0.371334] ACPI: PCI Interrupt Link [LACI] (IRQs 20 21 22 23) *0, disabled.
[ 0.371388] ACPI: PCI Interrupt Link [LMC9] (IRQs 20 21 22 23) *0, disabled.
[ 0.371441] ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22 23) *11
[ 0.371494] ACPI: PCI Interrupt Link [LPMU] (IRQs 20 21 22 23) *0, disabled.
[ 0.371546] ACPI: PCI Interrupt Link [LSA0] (IRQs 20 21 22 23) *10
[ 0.371599] ACPI: PCI Interrupt Link [LSA1] (IRQs 20 21 22 23) *10
[ 0.371687] ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22 23) *0, disabled.
[ 0.371820] pci 0000:02:00.0: vgaarb: setting as boot VGA device
[ 0.371820] pci 0000:02:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.371820] pci 0000:02:00.0: vgaarb: bridge control possible
[ 0.371820] vgaarb: loaded
[ 0.371820] pps_core: LinuxPPS API ver. 1 registered
[ 0.371820] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.371820] PTP clock support registered
[ 0.371820] EDAC MC: Ver: 3.0.0
[ 0.371820] PCI: Using ACPI for IRQ routing
[ 0.371820] PCI: pci_cache_line_size set to 64 bytes
[ 0.371820] e820: reserve RAM buffer [mem 0x0009f800-0x0009ffff]
[ 0.371820] e820: reserve RAM buffer [mem 0xdffb0000-0xdfffffff]
[ 0.371820] clocksource: Switched to clocksource tsc-early
[ 0.379813] VFS: Disk quotas dquot_6.6.0
[ 0.379831] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.379956] AppArmor: AppArmor Filesystem Enabled
[ 0.379978] pnp: PnP ACPI init
[ 0.380045] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.380347] pnp 00:01: [dma 3]
[ 0.380425] pnp 00:01: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.380684] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.380685] system 00:02: [io 0x0500-0x057f] has been reserved
[ 0.380686] system 00:02: [io 0x0580-0x05ff] has been reserved
[ 0.380687] system 00:02: [io 0x0800-0x087f] has been reserved
[ 0.380688] system 00:02: [io 0x0880-0x08ff] has been reserved
[ 0.380689] system 00:02: [io 0x0d00-0x0d7f] has been reserved
[ 0.380690] system 00:02: [io 0x0d80-0x0dff] has been reserved
[ 0.380691] system 00:02: [io 0x1100-0x117f] has been reserved
[ 0.380692] system 00:02: [io 0x1180-0x11ff] has been reserved
[ 0.380693] system 00:02: [mem 0x000d0000-0x000d3fff window] has been reserved
[ 0.380695] system 00:02: [mem 0x000d4000-0x000d7fff window] has been reserved
[ 0.380696] system 00:02: [mem 0x000de000-0x000dffff window] has been reserved
[ 0.380697] system 00:02: [mem 0xfec80000-0x1fd93ffff] could not be reserved
[ 0.380698] system 00:02: [mem 0xfefe0000-0xfefe01ff] has been reserved
[ 0.380699] system 00:02: [mem 0xfefe1000-0xfefe1fff] has been reserved
[ 0.380700] system 00:02: [mem 0xfee01000-0xfeefffff] has been reserved
[ 0.380704] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.380843] system 00:03: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.380844] system 00:03: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.380847] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.380881] pnp 00:04: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.381030] pnp 00:05: [dma 0 disabled]
[ 0.381073] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.381152] system 00:06: [io 0x0280-0x028f] has been reserved
[ 0.381153] system 00:06: [io 0x0290-0x029f] has been reserved
[ 0.381156] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.381205] system 00:07: [mem 0xfc000000-0xfdffffff] has been reserved
[ 0.381208] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.381351] system 00:08: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.381352] system 00:08: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.381353] system 00:08: [mem 0x00100000-0xdfffffff] could not be reserved
[ 0.381354] system 00:08: [mem 0xff380000-0xffffffff] could not be reserved
[ 0.381356] system 00:08: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.381541] pnp: PnP ACPI: found 9 devices
[ 0.387385] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.387397] pci 0000:00:04.0: PCI bridge to [bus 01]
[ 0.387404] pci 0000:00:09.0: PCI bridge to [bus 02]
[ 0.387405] pci 0000:00:09.0: bridge window [io 0xe000-0xefff]
[ 0.387407] pci 0000:00:09.0: bridge window [mem 0xfbf00000-0xfbffffff]
[ 0.387408] pci 0000:00:09.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.387410] pci 0000:00:0b.0: PCI bridge to [bus 03]
[ 0.387413] pci 0000:00:0c.0: PCI bridge to [bus 04]
[ 0.387418] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.387419] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.387420] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.387421] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.387421] pci_bus 0000:00: resource 8 [mem 0xe0000000-0xff37ffff window]
[ 0.387423] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7 window]
[ 0.387423] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff window]
[ 0.387424] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.387425] pci_bus 0000:01: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.387426] pci_bus 0000:01: resource 8 [mem 0xe0000000-0xff37ffff window]
[ 0.387427] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.387428] pci_bus 0000:02: resource 1 [mem 0xfbf00000-0xfbffffff]
[ 0.387429] pci_bus 0000:02: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.387483] NET: Registered protocol family 2
[ 0.387624] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[ 0.387643] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.387725] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.387864] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.387923] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.387946] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.388008] NET: Registered protocol family 1
[ 0.388012] NET: Registered protocol family 44
[ 0.388187] PCI Interrupt Link [LUB0] enabled at IRQ 23
[ 0.483296] pci 0000:00:02.0: quirk_usb_early_handoff+0x0/0x6c1 took 93007 usecs
[ 0.483410] PCI Interrupt Link [LUB2] enabled at IRQ 22
[ 0.483505] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.483545] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.483592] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.483636] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.483680] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.483727] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.483775] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.483826] pci 0000:00:00.0: Found enabled HT MSI Mapping
[ 0.483841] pci 0000:02:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.483847] pci 0000:02:00.1: Linked as a consumer to 0000:02:00.0
[ 0.483848] pci 0000:02:00.1: D0 power state depends on 0000:02:00.0
[ 0.483853] PCI: CLS 64 bytes, default 64
[ 0.483920] Unpacking initramfs...
[ 1.166325] Freeing initrd memory: 54608K
[ 1.166796] PCI-DMA: Disabling AGP.
[ 1.166907] PCI-DMA: aperture base @ d4000000 size 65536 KB
[ 1.166907] PCI-DMA: using GART IOMMU.
[ 1.166909] PCI-DMA: Reserving 64MB of IOMMU area in the AGP aperture
[ 1.169884] LVT offset 1 assigned for vector 0x400
[ 1.169891] LVT offset 1 assigned
[ 1.170095] perf: AMD IBS detected (0x0000001f)
[ 1.170749] Initialise system trusted keyrings
[ 1.170759] Key type blacklist registered
[ 1.170841] workingset: timestamp_bits=40 max_order=20 bucket_order=0
[ 1.172012] zbud: loaded
[ 1.340777] Key type asymmetric registered
[ 1.340778] Asymmetric key parser 'x509' registered
[ 1.340790] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.340870] io scheduler noop registered
[ 1.340871] io scheduler deadline registered
[ 1.340902] io scheduler cfq registered (default)
[ 1.340903] io scheduler mq-deadline registered
[ 1.341170] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.341613] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.362046] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.362413] Linux agpgart interface v0.103
[ 1.362438] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.362439] AMD IOMMUv2 functionality not available on this system
[ 1.363012] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.363012] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.363689] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.363787] mousedev: PS/2 mouse device common for all mice
[ 1.363826] rtc_cmos 00:00: RTC can wake from S4
[ 1.364012] rtc_cmos 00:00: registered as rtc0
[ 1.364025] rtc_cmos 00:00: alarms up to one year, y3k, 114 bytes nvram
[ 1.364183] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.364479] NET: Registered protocol family 10
[ 1.371374] Segment Routing with IPv6
[ 1.371395] mip6: Mobile IPv6
[ 1.371397] NET: Registered protocol family 17
[ 1.371494] mpls_gso: MPLS GSO support
[ 1.372038] mce: Using 6 MCE banks
[ 1.372053] microcode: microcode updated early to new patch_level=0x010000dc
[ 1.372086] microcode: CPU0: patch_level=0x010000dc
[ 1.372098] microcode: CPU1: patch_level=0x010000dc
[ 1.372109] microcode: CPU2: patch_level=0x010000dc
[ 1.372113] microcode: CPU3: patch_level=0x010000dc
[ 1.372123] microcode: CPU4: patch_level=0x010000dc
[ 1.372132] microcode: CPU5: patch_level=0x010000dc
[ 1.372174] microcode: Microcode Update Driver: v2.2.
[ 1.372183] sched_clock: Marking stable (1368315876, 3853880)->(1382683765, -10514009)
[ 1.372364] registered taskstats version 1
[ 1.372365] Loading compiled-in X.509 certificates
[ 1.390233] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.411798] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[ 1.411813] Loaded X.509 cert 'Debian Secure Boot Signer 2020: 00b55eb3b9'
[ 1.411834] zswap: loaded using pool lzo/zbud
[ 1.412025] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.412468] rtc_cmos 00:00: setting system clock to 2021-03-09 17:13:31 UTC (1615310011)
[ 1.694331] Freeing unused kernel image memory: 1596K
[ 1.714132] Write protecting the kernel read-only data: 16384k
[ 1.715838] Freeing unused kernel image memory: 2028K
[ 1.716175] Freeing unused kernel image memory: 776K
[ 1.723896] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.723898] Run /init as init process
[ 1.840373] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 1.840386] ACPI: Power Button [PWRB]
[ 1.840452] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 1.840465] ACPI: Power Button [PWRF]
[ 1.853449] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
[ 1.853646] PCI Interrupt Link [LMAC] enabled at IRQ 21
[ 1.854347] i2c i2c-0: nForce2 SMBus adapter at 0x600
[ 1.854365] i2c i2c-1: nForce2 SMBus adapter at 0x700
[ 1.856434] ACPI: bus type USB registered
[ 1.856455] usbcore: registered new interface driver usbfs
[ 1.856463] usbcore: registered new interface driver hub
[ 1.856498] usbcore: registered new device driver usb
[ 1.860070] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.860248] SCSI subsystem initialized
[ 1.862453] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.863145] ehci-pci: EHCI PCI platform driver
[ 1.864174] ehci-pci 0000:00:02.1: EHCI Host Controller
[ 1.864181] ehci-pci 0000:00:02.1: new USB bus registered, assigned bus number 1
[ 1.864189] ehci-pci 0000:00:02.1: debug port 1
[ 1.864222] ehci-pci 0000:00:02.1: cache line size of 64 is not supported
[ 1.864244] ehci-pci 0000:00:02.1: irq 22, io mem 0xfbefec00
[ 1.870953] libata version 3.00 loaded.
[ 1.872754] pata_amd 0000:00:06.0: version 0.4.1
[ 1.873562] scsi host0: pata_amd
[ 1.873693] scsi host1: pata_amd
[ 1.873744] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.873745] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.873790] sata_nv 0000:00:08.0: version 3.5
[ 1.873956] PCI Interrupt Link [LSA0] enabled at IRQ 20
[ 1.874456] scsi host2: sata_nv
[ 1.874543] scsi host3: sata_nv
[ 1.874596] ata3: SATA max UDMA/133 cmd 0xd400 ctl 0xd080 bmdma 0xc880 irq 20
[ 1.874598] ata4: SATA max UDMA/133 cmd 0xd000 ctl 0xcc00 bmdma 0xc888 irq 20
[ 1.874769] PCI Interrupt Link [LSA1] enabled at IRQ 23
[ 1.875171] scsi host4: sata_nv
[ 1.875259] scsi host5: sata_nv
[ 1.875294] ata5: SATA max UDMA/133 cmd 0xc800 ctl 0xc480 bmdma 0xc000 irq 23
[ 1.875295] ata6: SATA max UDMA/133 cmd 0xc400 ctl 0xc080 bmdma 0xc008 irq 23
[ 1.878100] ehci-pci 0000:00:02.1: USB 2.0 started, EHCI 1.00
[ 1.878148] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.878150] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.878151] usb usb1: Product: EHCI Host Controller
[ 1.878152] usb usb1: Manufacturer: Linux 4.19.0-13-amd64 ehci_hcd
[ 1.878153] usb usb1: SerialNumber: 0000:00:02.1
[ 1.878289] hub 1-0:1.0: USB hub found
[ 1.878295] hub 1-0:1.0: 10 ports detected
[ 1.879415] ohci-pci: OHCI PCI platform driver
[ 1.879524] ohci-pci 0000:00:02.0: OHCI PCI host controller
[ 1.879532] ohci-pci 0000:00:02.0: new USB bus registered, assigned bus number 2
[ 1.879551] ohci-pci 0000:00:02.0: irq 23, io mem 0xfbeff000
[ 1.936687] [drm] radeon kernel modesetting enabled.
[ 1.937111] PCI Interrupt Link [LNED] enabled at IRQ 19
[ 1.937271] [drm] initializing kernel modesetting (CAICOS 0x1002:0x6779 0x1043:0x03DA 0x00).
[ 1.937306] resource sanity check: requesting [mem 0x000c0000-0x000dffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000dffff window]
[ 1.937309] caller pci_map_rom+0x6a/0x1b0 mapping multiple BARs
[ 1.937884] ATOM BIOS: 6779.13.12.0.0.AS06
[ 1.938379] radeon 0000:02:00.0: VRAM: 1024M 0x0000000000000000 - 0x000000003FFFFFFF (1024M used)
[ 1.938381] radeon 0000:02:00.0: GTT: 1024M 0x0000000040000000 - 0x000000007FFFFFFF
[ 1.938383] [drm] Detected VRAM RAM=1024M, BAR=256M
[ 1.938384] [drm] RAM width 64bits DDR
[ 1.938471] [TTM] Zone kernel: Available graphics memory: 2020496 kiB
[ 1.938472] [TTM] Initializing pool allocator
[ 1.938480] [TTM] Initializing DMA pool allocator
[ 1.938495] [drm] radeon: 1024M of VRAM memory ready
[ 1.938496] [drm] radeon: 1024M of GTT memory ready.
[ 1.938501] [drm] Loading CAICOS Microcode
[ 1.938524] radeon 0000:02:00.0: firmware: direct-loading firmware radeon/CAICOS_pfp.bin
[ 1.938538] radeon 0000:02:00.0: firmware: direct-loading firmware radeon/CAICOS_me.bin
[ 1.938549] radeon 0000:02:00.0: firmware: direct-loading firmware radeon/BTC_rlc.bin
[ 1.938569] radeon 0000:02:00.0: firmware: direct-loading firmware radeon/CAICOS_mc.bin
[ 1.938587] radeon 0000:02:00.0: firmware: direct-loading firmware radeon/CAICOS_smc.bin
[ 1.938589] [drm] Internal thermal controller without fan control
[ 1.944834] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 4.19
[ 1.944835] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.944836] usb usb2: Product: OHCI PCI host controller
[ 1.944837] usb usb2: Manufacturer: Linux 4.19.0-13-amd64 ohci_hcd
[ 1.944837] usb usb2: SerialNumber: 0000:00:02.0
[ 1.944883] [drm] radeon: dpm initialized
[ 1.944972] radeon 0000:02:00.0: firmware: direct-loading firmware radeon/SUMO_uvd.bin
[ 1.944988] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 1.954444] hub 2-0:1.0: USB hub found
[ 1.954451] hub 2-0:1.0: 10 ports detected
[ 1.956340] [drm] PCIE GART of 1024M enabled (table at 0x0000000000162000).
[ 1.956440] radeon 0000:02:00.0: WB enabled
[ 1.956442] radeon 0000:02:00.0: fence driver on ring 0 use gpu addr 0x0000000040000c00 and cpu addr 0x(____ptrval____)
[ 1.956444] radeon 0000:02:00.0: fence driver on ring 3 use gpu addr 0x0000000040000c0c and cpu addr 0x(____ptrval____)
[ 1.957186] radeon 0000:02:00.0: fence driver on ring 5 use gpu addr 0x0000000000072118 and cpu addr 0x(____ptrval____)
[ 1.957188] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.957189] [drm] Driver supports precise vblank timestamp query.
[ 1.957190] radeon 0000:02:00.0: radeon: MSI limited to 32-bit
[ 1.957225] radeon 0000:02:00.0: radeon: using MSI.
[ 1.957253] [drm] radeon: irq initialized.
[ 1.973473] [drm] ring test on 0 succeeded in 3 usecs
[ 1.973482] [drm] ring test on 3 succeeded in 6 usecs
[ 2.149245] [drm] ring test on 5 succeeded in 2 usecs
[ 2.149252] [drm] UVD initialized successfully.
[ 2.149396] [drm] ib test on ring 0 succeeded in 0 usecs
[ 2.149466] [drm] ib test on ring 3 succeeded in 0 usecs
[ 2.153252] random: fast init done
[ 2.178116] tsc: Refined TSC clocksource calibration: 3013.709 MHz
[ 2.178122] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b70dbc6039, max_idle_ns: 440795243804 ns
[ 2.299401] clocksource: Switched to clocksource tsc
[ 2.309670] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.338575] ata1.00: HPA detected: current 312579695, native 312581808
[ 2.338578] ata1.00: ATA-6: ST3160021A, 3.04, max UDMA/100
[ 2.338579] ata1.00: 312579695 sectors, multi 16: LBA48
[ 2.338584] ata1.01: ATAPI: HL-DT-ST DVDRAM GSA-4163B, A106, max UDMA/33
[ 2.338588] ata1: nv_mode_filter: 0x3f39f&0x3f39f->0x3f39f, BIOS=0x3f000 (0xc6c00000) ACPI=0x3f01f (20:60:0x15)
[ 2.338591] ata1: nv_mode_filter: 0x739f&0x739f->0x739f, BIOS=0x7000 (0xc6c00000) ACPI=0x701f (20:60:0x15)
[ 2.386766] forcedeth 0000:00:07.0: ifname eth0, PHY OUI 0x732 @ 1, addr 00:25:22:eb:ee:3a
[ 2.386768] forcedeth 0000:00:07.0: highdma pwrctl mgmt lnktim msi desc-v3
[ 2.387639] forcedeth 0000:00:07.0 enp0s7: renamed from eth0
[ 2.389578] scsi 0:0:0:0: Direct-Access ATA ST3160021A 3.04 PQ: 0 ANSI: 5
[ 2.393643] scsi 0:0:1:0: CD-ROM HL-DT-ST DVDRAM GSA-4163B A106 PQ: 0 ANSI: 5
[ 2.428214] ata2: port disabled--ignoring
[ 2.428242] sd 0:0:0:0: [sda] 312579695 512-byte logical blocks: (160 GB/149 GiB)
[ 2.428260] sd 0:0:0:0: [sda] Write Protect is off
[ 2.428264] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.428286] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.458142] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.460632] ata3.00: ATA-8: WDC WD5000AAKX-22ERMA0, 17.01H17, max UDMA/133
[ 2.460634] ata3.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.465380] ata3.00: configured for UDMA/133
[ 2.465457] scsi 2:0:0:0: Direct-Access ATA WDC WD5000AAKX-2 1H17 PQ: 0 ANSI: 5
[ 2.465626] sd 2:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 2.465631] sd 2:0:0:0: [sdb] Write Protect is off
[ 2.465633] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.465639] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.474493] sdb: sdb1 sdb2 sdb3 sdb4
[ 2.474956] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 2.482959] sr 0:0:1:0: [sr0] scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.482963] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.483268] sr 0:0:1:0: Attached scsi CD-ROM sr0
[ 2.489226] sda: sda1 sda2 < sda5 >
[ 2.538111] usb 1-4: new high-speed USB device number 2 using ehci-pci
[ 2.568580] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.702905] usb 1-4: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
[ 2.702906] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.702907] usb 1-4: Product: 802.11n NIC
[ 2.702908] usb 1-4: Manufacturer: Realtek
[ 2.702909] usb 1-4: SerialNumber: 00E04C0001
[ 2.818149] [drm] ib test on ring 5 succeeded
[ 2.818582] [drm] Radeon Display Connectors
[ 2.818583] [drm] Connector 0:
[ 2.818583] [drm] HDMI-A-1
[ 2.818583] [drm] HPD1
[ 2.818584] [drm] DDC: 0x6460 0x6460 0x6464 0x6464 0x6468 0x6468 0x646c 0x646c
[ 2.818585] [drm] Encoders:
[ 2.818585] [drm] DFP1: INTERNAL_UNIPHY1
[ 2.818586] [drm] Connector 1:
[ 2.818586] [drm] DVI-D-1
[ 2.818587] [drm] HPD4
[ 2.818588] [drm] DDC: 0x6450 0x6450 0x6454 0x6454 0x6458 0x6458 0x645c 0x645c
[ 2.818588] [drm] Encoders:
[ 2.818588] [drm] DFP2: INTERNAL_UNIPHY
[ 2.818589] [drm] Connector 2:
[ 2.818589] [drm] VGA-1
[ 2.818590] [drm] DDC: 0x6430 0x6430 0x6434 0x6434 0x6438 0x6438 0x643c 0x643c
[ 2.818590] [drm] Encoders:
[ 2.818591] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 2.877907] [drm] fb mappable at 0xE0363000
[ 2.877908] [drm] vram apper at 0xE0000000
[ 2.877908] [drm] size 8294400
[ 2.877909] [drm] fb depth is 24
[ 2.877909] [drm] pitch is 7680
[ 2.877973] fbcon: radeondrmfb (fb0) is primary device
[ 2.930675] Console: switching to colour frame buffer device 240x67
[ 2.934086] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.936176] radeon 0000:02:00.0: fb0: radeondrmfb frame buffer device
[ 2.936458] ata4.00: HPA detected: current 156247887, native 156250000
[ 2.936461] ata4.00: ATA-7: WDC WD800JD-75MSA3, 10.01E04, max UDMA/133
[ 2.936462] ata4.00: 156247887 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.939005] ata4.00: configured for UDMA/133
[ 2.939109] scsi 3:0:0:0: Direct-Access ATA WDC WD800JD-75MS 1E04 PQ: 0 ANSI: 5
[ 2.939277] sd 3:0:0:0: [sdc] 156247887 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 2.939282] sd 3:0:0:0: [sdc] Write Protect is off
[ 2.939283] sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2.939289] sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.950162] sdc: sdc1 sdc2
[ 2.950436] sd 3:0:0:0: [sdc] Attached SCSI disk
[ 2.954187] [drm] Initialized radeon 2.50.0 20080528 for 0000:02:00.0 on minor 0
[ 3.162111] usb 2-9: new full-speed USB device number 2 using ohci-pci
[ 3.263585] ata6: SATA link down (SStatus 0 SControl 300)
[ 3.396115] usb 2-9: New USB device found, idVendor=1ea7, idProduct=0064, bcdDevice= 2.00
[ 3.396123] usb 2-9: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.396127] usb 2-9: Product: 2.4G Mouse
[ 3.403901] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.412378] usbcore: registered new interface driver usbhid
[ 3.412379] usbhid: USB HID core driver
[ 3.413752] input: 2.4G Mouse as /devices/pci0000:00/0000:00:02.0/usb2/2-9/2-9:1.0/0003:1EA7:0064.0001/input/input3
[ 3.413778] input: 2.4G Mouse Mouse as /devices/pci0000:00/0000:00:02.0/usb2/2-9/2-9:1.0/0003:1EA7:0064.0001/input/input4
[ 3.413916] hid-generic 0003:1EA7:0064.0001: input,hiddev0,hidraw0: USB HID v1.10 Mouse [2.4G Mouse] on usb-0000:00:02.0-9/input0
[ 3.925771] device-mapper: uevent: version 1.0.3
[ 3.925937] device-mapper: ioctl: 4.39.0-ioctl (2018-04-03) initialised: dm-devel@redhat.com
[ 4.177636] random: crng init done
[ 4.462050] raid6: sse2x1 gen() 4239 MB/s
[ 4.530030] raid6: sse2x1 xor() 4502 MB/s
[ 4.598042] raid6: sse2x2 gen() 6522 MB/s
[ 4.666030] raid6: sse2x2 xor() 7661 MB/s
[ 4.734039] raid6: sse2x4 gen() 7782 MB/s
[ 4.802060] raid6: sse2x4 xor() 3752 MB/s
[ 4.802066] raid6: using algorithm sse2x4 gen() 7782 MB/s
[ 4.802067] raid6: .... xor() 3752 MB/s, rmw enabled
[ 4.802084] raid6: using intx1 recovery algorithm
[ 4.809996] xor: measuring software checksum speed
[ 4.846031] prefetch64-sse: 13230.000 MB/sec
[ 4.886030] generic_sse: 12562.000 MB/sec
[ 4.886031] xor: using function: prefetch64-sse (13230.000 MB/sec)
[ 4.938103] Btrfs loaded, crc32c=crc32c-generic
[ 5.631367] PM: Image not found (code -22)
[ 5.766481] cryptd: max_cpu_qlen set to 1000
[ 5.917207] EXT4-fs (sdc2): mounted filesystem with ordered data mode. Opts: (null)
[ 7.814440] systemd[1]: Inserted module 'autofs4'
[ 7.973099] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 7.990230] systemd[1]: Detected architecture x86-64.
[ 8.002481] systemd[1]: Set hostname to <pin>.
[ 10.986273] systemd[1]: Reached target Remote File Systems.
[ 10.986343] systemd[1]: Reached target User and Group Name Lookups.
[ 10.986427] systemd[1]: Listening on udev Control Socket.
[ 10.986495] systemd[1]: Listening on Journal Socket.
[ 10.988700] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 11.022792] systemd[1]: Starting Load Kernel Modules...
[ 11.023549] systemd[1]: Starting Availability of block devices...
[ 11.427287] EXT4-fs (sdc2): re-mounted. Opts: (null)
[ 11.997387] systemd-journald[279]: Received request to flush runtime journal from PID 1
[ 12.394299] lp: driver loaded but no devices found
[ 12.482508] ppdev: user-space parallel port driver
[ 12.543458] parport_pc 00:01: reported by Plug and Play ACPI
[ 12.543520] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[ 12.638259] lp0: using parport0 (interrupt-driven).
[ 12.770568] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 12.770617] sr 0:0:1:0: Attached scsi generic sg1 type 5
[ 12.770651] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 12.770681] sd 3:0:0:0: Attached scsi generic sg3 type 0
[ 15.435264] audit: type=1400 audit(1615310025.518:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=351 comm="apparmor_parser"
[ 15.448345] audit: type=1400 audit(1615310025.530:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/ippusbxd" pid=352 comm="apparmor_parser"
[ 15.462253] audit: type=1400 audit(1615310025.546:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=354 comm="apparmor_parser"
[ 15.462257] audit: type=1400 audit(1615310025.546:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=354 comm="apparmor_parser"
[ 15.550318] audit: type=1400 audit(1615310025.634:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=353 comm="apparmor_parser"
[ 15.618551] audit: type=1400 audit(1615310025.702:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=369 comm="apparmor_parser"
[ 15.618970] audit: type=1400 audit(1615310025.702:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=364 comm="apparmor_parser"
[ 15.618973] audit: type=1400 audit(1615310025.702:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=364 comm="apparmor_parser"
[ 15.618975] audit: type=1400 audit(1615310025.702:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=364 comm="apparmor_parser"
[ 15.707673] audit: type=1400 audit(1615310025.790:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=355 comm="apparmor_parser"
[ 16.819454] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 16.829207] acpi_cpufreq: overriding BIOS provided _PSD data
[ 17.759341] kvm: Nested Virtualization enabled
[ 17.759344] kvm: Nested Paging enabled
[ 17.960966] MCE: In-kernel MCE decoding enabled.
[ 18.261613] EDAC amd64: Node 0: DRAM ECC disabled.
[ 18.261619] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
(Note that use of the override may cause unknown side effects.)
[ 18.298947] EDAC amd64: Node 0: DRAM ECC disabled.
[ 18.298950] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 18.331555] EDAC amd64: Node 0: DRAM ECC disabled.
[ 18.331561] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 18.391496] EDAC amd64: Node 0: DRAM ECC disabled.
[ 18.391501] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 18.431447] EDAC amd64: Node 0: DRAM ECC disabled.
[ 18.431452] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 18.479401] EDAC amd64: Node 0: DRAM ECC disabled.
[ 18.479407] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[ 18.917545] lib80211: common routines for IEEE802.11 drivers
[ 18.917551] lib80211_crypt: registered algorithm 'NULL'
[ 19.214490] PCI Interrupt Link [LAZA] enabled at IRQ 22
[ 19.214509] snd_hda_intel 0000:00:05.0: Disabling MSI
[ 19.215098] PCI Interrupt Link [LNEA] enabled at IRQ 18
[ 19.215174] snd_hda_intel 0000:02:00.1: Handle vga_switcheroo audio client
[ 19.311959] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 19.315397] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 19.350480] usbcore: registered new interface driver r8188eu
[ 19.356398] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:09.0/0000:02:00.1/sound/card1/input6
[ 19.388698] r8188eu 1-4:1.0 wlx18d6c71c26c4: renamed from wlan0
[ 19.604749] Adding 4199420k swap on /dev/sdc1. Priority:-2 extents:1 across:4199420k FS
[ 20.146137] snd_hda_codec_via hdaudioC0D0: autoconfig for VT1705: line_outs=1 (0x1c/0x0/0x0/0x0/0x0) type:line
[ 20.146145] snd_hda_codec_via hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 20.146150] snd_hda_codec_via hdaudioC0D0: hp_outs=1 (0x1d/0x0/0x0/0x0/0x0)
[ 20.146153] snd_hda_codec_via hdaudioC0D0: mono: mono_out=0x0
[ 20.146156] snd_hda_codec_via hdaudioC0D0: inputs:
[ 20.146160] snd_hda_codec_via hdaudioC0D0: Rear Mic=0x1a
[ 20.146165] snd_hda_codec_via hdaudioC0D0: Front Mic=0x1e
[ 20.146168] snd_hda_codec_via hdaudioC0D0: Line=0x1b
[ 20.146171] snd_hda_codec_via hdaudioC0D0: CD=0x1f
[ 21.523730] input: HDA NVidia Rear Mic as /devices/pci0000:00/0000:00:05.0/sound/card0/input7
[ 21.523951] input: HDA NVidia Line as /devices/pci0000:00/0000:00:05.0/sound/card0/input8
[ 21.524155] input: HDA NVidia Line Out as /devices/pci0000:00/0000:00:05.0/sound/card0/input9
[ 21.524359] snd_hda_intel 0000:00:05.0: device 1849:0397 is on the power_save blacklist, forcing power_save to 0
[ 33.803830] IPv6: ADDRCONF(NETDEV_UP): enp0s7: link is not ready
[ 33.804418] forcedeth 0000:00:07.0 enp0s7: MSI enabled
[ 33.804635] forcedeth 0000:00:07.0 enp0s7: no link during initialization
[ 33.804952] IPv6: ADDRCONF(NETDEV_UP): enp0s7: link is not ready
[ 33.811340] IPv6: ADDRCONF(NETDEV_UP): wlx18d6c71c26c4: link is not ready
[ 33.987362] r8188eu 1-4:1.0: firmware: direct-loading firmware rtlwifi/rtl8188eufw.bin
[ 34.794637] MAC Address = 18:d6:c7:1c:26:c4
[ 34.798692] IPv6: ADDRCONF(NETDEV_UP): wlx18d6c71c26c4: link is not ready
[ 35.453888] IPv6: ADDRCONF(NETDEV_UP): wlx18d6c71c26c4: link is not ready
[ 37.880656] R8188EU: assoc success
[ 37.890586] IPv6: ADDRCONF(NETDEV_CHANGE): wlx18d6c71c26c4: link becomes ready
[ 39.041551] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 39.301079] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 42.676479] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 54.388684] input: BRLTTY 5.6 Linux Screen Driver Keyboard as /devices/virtual/input/input10
[ 56.178795] fuse init (API version 7.27)
[ 63.503183] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC= SRC=fe80:0000:0000:0000:898e:ecb8:49dd:7528 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=919872 PROTO=UDP SPT=8612 DPT=8612 LEN=24
[ 63.503264] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC= SRC=fe80:0000:0000:0000:898e:ecb8:49dd:7528 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=432436 PROTO=UDP SPT=8612 DPT=8610 LEN=24
[ 63.513615] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC= SRC=fe80:0000:0000:0000:898e:ecb8:49dd:7528 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=919872 PROTO=UDP SPT=8612 DPT=8612 LEN=24
[ 63.513681] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC= SRC=fe80:0000:0000:0000:898e:ecb8:49dd:7528 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=1 FLOWLBL=432436 PROTO=UDP SPT=8612 DPT=8610 LEN=24
[ 113.676619] R8188EU: indicate disassoc
[ 114.116055] R8188EU: indicate disassoc
[ 119.161355] IPv6: ADDRCONF(NETDEV_UP): wlx18d6c71c26c4: link is not ready
[ 119.171037] r8188eu 1-4:1.0: firmware: direct-loading firmware rtlwifi/rtl8188eufw.bin
[ 120.034496] IPv6: ADDRCONF(NETDEV_UP): wlx18d6c71c26c4: link is not ready
[ 124.359412] R8188EU: indicate disassoc
[ 126.890576] R8188EU: assoc success
[ 126.903738] IPv6: ADDRCONF(NETDEV_CHANGE): wlx18d6c71c26c4: link becomes ready
[ 128.003388] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 155.261743] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead.
[ 167.669970] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 292.663461] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 300.029711] forcedeth 0000:00:07.0 enp0s7: link up
[ 300.030042] IPv6: ADDRCONF(NETDEV_CHANGE): enp0s7: link becomes ready
[ 309.613014] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 309.613392] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 309.976905] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 309.977263] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 417.656556] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 417.656927] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 542.650107] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 542.650421] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 667.643596] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 667.643904] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 728.761175] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 728.764976] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 728.765420] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 728.766157] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 752.699487] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 752.699693] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 760.914920] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 760.915194] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 762.495315] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 762.496927] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 792.637124] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 792.637412] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 799.537116] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 917.630567] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 917.630865] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 922.236011] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 922.236290] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1042.624110] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1042.624503] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1043.610890] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1043.611123] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1167.617662] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1167.617981] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1174.593853] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1174.594109] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1292.611155] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1292.611477] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1296.109252] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1296.109477] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1417.604672] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1417.604967] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1425.672609] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1425.672872] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1542.598220] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1542.598573] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1545.932380] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1545.932579] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1667.591740] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1667.592382] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1673.264407] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1673.264682] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1792.585237] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1792.585626] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1802.251690] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1802.251927] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1917.578774] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1917.579175] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1917.998302] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 1917.998742] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2042.572307] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2044.820115] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2044.820300] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2167.565826] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2167.566144] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2174.527613] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2174.527926] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2292.559342] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2292.559789] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2301.659885] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2301.663647] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2417.552840] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2417.553261] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2422.775816] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2422.775980] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2542.546453] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2542.546712] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2545.796097] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2545.796260] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2667.539884] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2667.540242] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2668.277133] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2668.281246] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2792.533588] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2792.538449] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2795.244212] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2795.244439] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2917.526967] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2917.527295] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2927.400214] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 2927.400429] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3042.520480] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3042.520834] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3045.348552] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3045.348810] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3167.513948] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3167.514675] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3170.689083] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3170.689549] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3292.507505] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3292.510539] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:01:f8:d1:11:42:95:76:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3301.217843] [UFW BLOCK] IN=enp0s7 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 3301.218047] [UFW BLOCK] IN=wlx18d6c71c26c4 OUT= MAC=01:00:5e:00:00:fb:64:e7:d8:75:2c:06:08:00 SRC=192.168.0.101 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
peti@pin:~$ inxi -Fzxxx
System:
Host: pin Kernel: 4.19.0-13-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0
Desktop: Cinnamon 4.8.6 wm: muffin 4.8.1 dm: LightDM 1.26.0
Distro: LMDE 4 Debbie base: Debian 10.2 buster
Machine:
Type: Desktop Mobo: ASRock model: N68C-S UCC serial: <filter>
BIOS: American Megatrends v: P1.60 date: 09/19/2011
CPU:
Topology: 6-Core model: AMD model unknown bits: 64 type: MCP arch: K10
L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 36162
Speed: 804 MHz min/max: 800/3000 MHz boost: enabled Core speeds (MHz):
1: 804 2: 803 3: 804 4: 804 5: 804 6: 804
Graphics:
Device-1: AMD Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM]
vendor: ASUSTeK driver: radeon v: kernel bus ID: 02:00.0 chip ID: 1002:6779
Display: x11 server: X.Org 1.20.4 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: AMD CAICOS (DRM 2.50.0 / 4.19.0-13-amd64 LLVM 7.0.1)
v: 3.3 Mesa 18.3.6 compat-v: 3.1 direct render: Yes
Audio:
Device-1: NVIDIA MCP61 High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus ID: 00:05.0 chip ID: 10de:03f0
Sound Server: ALSA v: k4.19.0-13-amd64
Network:
Device-1: NVIDIA MCP61 Ethernet vendor: ASRock 939NF6G-VSTA Board
type: network bridge driver: forcedeth v: kernel port: d480 bus ID: 00:07.0
chip ID: 10de:03ef
IF: enp0s7 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus ID: 1-4:2 chip ID: 0bda:8179 serial: <filter>
IF: wlx18d6c71c26c4 state: up mac: <filter>
Drives:
Local Storage: total: 689.32 GiB used: 7.10 GiB (1.0%)
ID-1: /dev/sda vendor: Seagate model: ST3160021A size: 149.05 GiB
speed: <unknown> serial: <filter> rev: 3.04 scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WD5000AAKX-22ERMA0
size: 465.76 GiB speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: 1H17 scheme: MBR
ID-3: /dev/sdc vendor: Western Digital model: WD800JD-75MSA3
size: 74.50 GiB speed: 3.0 Gb/s serial: <filter> rev: 1E04 scheme: MBR
Partition:
ID-1: / size: 68.89 GiB used: 7.10 GiB (10.3%) fs: ext4 dev: /dev/sdc2
ID-2: swap-1 size: 4.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdc1
Sensors:
System Temperatures: cpu: 0.0 C mobo: N/A gpu: radeon temp: 54 C
Fan Speeds (RPM): N/A
Info:
Processes: 211 Uptime: 57m Memory: 3.85 GiB used: 1.12 GiB (29.1%)
Init: systemd v: 241 runlevel: 5 Compilers: gcc: 8.3.0 alt: 8 Shell: bash
v: 5.0.3 running in: gno
Repos:me-terminal inxi: 3.0.32
peti@pin:~$ inxi -r
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http://packages.linuxmint.com debbie main upstream import backport #id:linuxmint_main
2: deb https://deb.debian.org/debian buster main contrib non-free
3: deb https://deb.debian.org/debian buster-updates main contrib non-free
4: deb http://security.debian.org buster/updates main contrib non-free
5: deb https://deb.debian.org/debian buster-backports main contrib non-free
peti@pin:~$
Kérlek segítsetek,köszönettel Tandem
R8188EU
Ott van:
Blokkolva esetleg a WiFi? Kimenet?
A Debian a non-free (nem szabad) csomagok között tárolja a firmware-realtek csomagot.
Ebben is más, mint a Linux Mint vagy más, Ubuntu-alapú terjesztések.
Ha telepíted,
és újraindítod a hálózatot?
Egyáltalán nem működik, vagy mi pontosabban a probléma?
minden úgy néz ki,hogy működik,csak mégsincs Net-em!
Azaz, pontosítanád, mire utal a mondat? Úgy néz ki? Mi a jele ennek?
A hosszű szöveges kimeneteket így oszd meg:
A honlap működése 7. rész: Ubuntu Pastebin | szöveg megosztása
Itt írtam: https://linuxmint.hu/comment/45754#comment-45754
Hát ö.
Először is, a tűzfalat meg kellene nézni, miket blokkol, mert az is gyanús.
Másodsorban: A Wifi adapterhez lehet más driverrel foglalkozni, bár ehhez a TP-Link csak Ubuntu / Kali linuxhoz adott ki drivert, és ebből is csak a V3-hoz, és régebbi kernelekhez. Elvileg a wifi adapter támogatott kernelből, de valami gubanc van vele, az látszik a riportból. Persze, vannak patkolt driverek, amik lehet, hogy működésre bírják, de mivel Debian, itt átadnám a szót Kimarite-nak.
patkolt driver itt: https://github.com/quickreflex/rtl8188eus
Én megpróbálkoznék másik, újabb adapterrel, gyorsabbak is, biztonságosabbak is. Lehet akár újabb TP-Link is, sőt, az aktuálisak nagyon támogatottak.
TL-Wn725N
Beküldte Tandem -
Köszönöm a gyors választ!
"minden úgy néz ki,hogy működik,csak mégsincs Net-em!" Elöttem van az adapter,és pontosan úgy villog a led,mintha adatot töltene le.KIválasztottam a wireless hálózatot,a vezetékest leválasztöttam ,és megnyitottam a Firefox-ot,és azt írta "HMM probléma az oldallal" Kénytelen voltam a vezetékes hálózatot bekapcsolni,hogy pl.neked írjak ,segítségért.Ezalatt persze hagytam a frissítést
Mikor végeztem,az írással,-a gép kérte az újraindítást,-újraindítottam,és LÁSS csodát működik a wi-fi !!!
Mégegyszer is köszönöm a gyors választ,szia Tandem.
TL-Wn725N
TL-Wn725N
És most jó?
TL-Wn725N
Beküldte Tandem -
Igen jó,rendesen működik! Köszönöm a figyelmet,és a segítséget.
TL-Wn725N
Beküldte Tandem -
Az első kérdésedre nem válaszoltam,-bocs.Nem telepítettem ,hanem a frissítés után kérte az újraindítást,és mikor újraindult
minden OK volt,ennyi.Most is ezen keresztül írok neked.
TL-Wn725N
