Segítséget szereznék kérni a tárgyban szereplő processzor integrált grafikájának felélesztéséhez.
Jelenleg szoftver renderingel fut, ezért nagyon leterheli a procit.
Van valakinek valami ötlete indulásképp?
inxi -Fxz
System:    Kernel: 5.10.4-051004-generic x86_64 bits: 64 compiler: N/A Desktop: Cinnamon 4.8.6 Distro: Linux Mint 20.1 Ulyssa
           base: Ubuntu 20.04 focal
Machine:   Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0 serial: <filter>
           UEFI: American Megatrends v: 2.50 date: 12/04/2020
CPU:       Topology: 8-Core model: AMD Ryzen 7 PRO 4750G with Radeon Graphics bits: 64 type: MT MCP arch: Zen rev: 1
           L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 115200
           Speed: 3001 MHz min/max: 1400/3600 MHz Core speeds (MHz): 1: 3000 2: 1591 3: 3000 4: 1333 5: 1400 6: 1400 7: 1400
           8: 1400 9: 3002 10: 1332 11: 1399 12: 1398 13: 1399 14: 1400 15: 2998 16: 2251
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: N/A bus ID: 30:00.0
           Display: x11 server: X.Org 1.20.9 driver: ati,fbdev unloaded: modesetting,radeon,vesa resolution: 1920x1200~77Hz
           OpenGL: renderer: llvmpipe (LLVM 11.0.0 256 bits) v: 4.5 Mesa 20.2.6 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 30:00.1
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           bus ID: 30:00.6
           Sound Server: ALSA v: k5.10.4-051004-generic
Network:   Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel bus ID: 29:00.0
           IF: wlo1 state: down mac: <filter>
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
           port: f000 bus ID: 2a:00.0
           IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 7.51 TiB used: 5.24 TiB (69.8%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB256HAHQ-00000 size: 238.47 GiB
           ID-2: /dev/sda type: USB vendor: Seagate model: Expansion Desk size: 5.46 TiB
           ID-3: /dev/sdb vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
           ID-4: /dev/sdc vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
Partition: ID-1: / size: 114.85 GiB used: 92.32 GiB (80.4%) fs: ext4 dev: /dev/nvme0n1p5
           ID-2: /home size: 915.89 GiB used: 746.94 GiB (81.6%) fs: ext4 dev: /dev/sdb1
Sensors:   System Temperatures: cpu: 47.2 C mobo: N/A
           Fan Speeds (RPM): N/A
Info:      Processes: 364 Uptime: 9m Memory: 13.63 GiB used: 2.72 GiB (20.0%) Init: systemd runlevel: 5 Compilers: gcc: 9.3.0
           Shell: bash v: 5.0.17 inxi: 3.0.38
Izé...
Mi a túró renderelése izzaszthatja meg ezt a procit? Valami 8K 16 órás film?
Egyébként, meg, ha a prociba integrált VGA rész renderel, akkor az nem a procit terheli? Jó, tudom vannak esetek, ahol van némi értelme, meg vannak, akiknek ez nagyon is számít, hogy mi kódolja a videót.
Egyébként olyan szoftvert kell használni, amelyik támogatja ezt. Amit most nem tudok most hirtelen mondani, lehet hogy van már, de nem hallottam róla. De előbb-utóbb lesz. Bízzunk benne. Szerintem türelem.
Amúgy a Core i vonal esetén sincs egetverő nyereség, ha annak a VGA hardveres kódolását használják, u.a. proci melegszik, u.a. proci ventije pörög, és nem sokkal hamarabb lesz kész, de lehet, hogy az eremény nem is olyan jó.
Manjaro 20.2.1
Csak ötlet: Próbáld ki a legújabb Manjaro 20.2.1-et live-ban - hogy az alatt mit csinál ?
https://osdn.net/projects/manjaro/storage/xfce/20.2.1/manjaro-xfce-20.2....
Manjaro 20.2.1
Hát nem tudom - Manjaro nem bejövős. Arch-on 5.10.7-1 a z aktuális kernel. Ez csak pár héttel újabb az övénél, persze attól még lehetséges.
Manjaro 20.2.1
Igen ... azt láttam hogy a telepítéssel kapott kernelt kicserélte egy újabbra - de ott van pl, a
mesa - ennek a cseréje egy újabbra - talán segíthet.
Közben találtam ezt: https://forums.linuxmint.com/viewtopic.php?t=328862
Az utolsó előtti hozzászólás lehet az érdekes.
Azért ajánlottam a Manjarot, mert live-ban könnyen ki lehet próbálni - és újabb verziójú
csomagok vannak benne mint a Mint 20(.1)-ben.
Manjaro 20.2.1
Igazad van, vesztenivaló nincs.
Izé...
Beküldte Thinky -
Szia! A Netflix UHD felbontásban nagyon megterheli szegénykét, de azért lejátsza. :-)
Egyébkényt nyivánvalóan szoftver renderindel bármi megterhelő lehet FHD felett H.265 kódolással.
Nomeg videó átkódolásnál is jól jönne egy kis HW demux.
DRI_PRIME=1 glxinfo | grep -i "opengl renderer"
Kimenetek, ha ezeket a parancssorokat futtatod (terminálban)?
Izé...
Hát egyelőre csak a remény van, hátha lesz valami lépés az AMD részéről. Kutakodtam az oldalukon de ehhez csak procihoz csak W10-hez van driver. Ugyanakkor láttam, hogy kiadták a Radeon 20.20 driverkollekciót pl. Ubuntu 20.04-hez is (LM 20.1), amit nem is értek, mert arról volt szó, hogy már csak kernel támogatás lesz. (Ezt nem jó a Renoir-hoz, nem kell vele próbálkozni.)
Az x.org oldalán azt olvastam, hogy már támogatja a Renoir-t, szerintem Synaptic-ban rá kellene keresni az AMDGPU szóra, megnézni a találatokat, képet róla.... ill. dmesg-et pasztázni, hátha van abban valami nyomravezető üzenet.
Izé...
mondjuk ez itt már több, mint egy éves, nem is értem, miért nincs benne a csomagban:
https://lists.freedesktop.org/archives/amd-gfx/2019-August/039229.html
Vagy csak az 5.10-es kernelben nincs? Ha 5.8.4-es kernellel próbálod, akkor mi a helyzet?
AMD Ryzen™ 7 PRO 4750G Drivers & Support
Elméletileg támogatva:
https://www.amd.com/en/support/apu/amd-ryzen-pro-processors/amd-ryzen-7-...
*OS Support
Windows 10 - 64-Bit Edition
RHEL x86 64-Bit
Ubuntu x86 64-Bit
*Operating System (OS) support will vary by manufacturer.
Szerintem nincs fent a
Beküldte kami911 -
Szerintem nincs fent a megfelelő mesa driverek, ebből gondolom:
Esetleg nézd meg, hogy fent vannak-e ezek a csomagok:
apt install mesa-utils mesa-utils-extra libdrm-amdgpu1
Nekem a kimarite által adott parancsok kimenete:
root@mint:/home/kami# DRI_PRIME=1 glxinfo | grep -i "opengl renderer"
OpenGL renderer string: AMD Radeon HD 8600M Series (HAINAN, DRM 3.40.0, 5.10.0-1008-oem, LLVM 11.0.0)
root@mint:/home/kami# DRI_PRIME=0 glxinfo | grep -i "opengl renderer"
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 4600 (HSW GT2)
Érdekes, hogy automatikusan nincsenek telepítve.
Izé...
Csak néhány lépés választ el a sikertől, ezt csináld (olvasd végig, mielőtt belevágnál):
Először tedd fel az OIBAF PPA-t (ez biztosítja a legújabb drivereket):
Aztán installáld a a git-et (ha még nincs):
Majd:
A fentebbi parancs a Documents mappába letölt majdnem 1 GB cuccot, ebből neked a Documents/linux-firmware/amdgpu folder kell.
Root-ként megnyitod a /lib/firmware foldert és ebből letörlöd a komplett amdgpu foldert.
Ezután a letörölt folder helyére bemásolod a komplett amdgpu foldert a Documents/linux-firmware folderből (tulajdonképpen csak a renoir-os cuccok kellenének, de a git-es folderben az újabb verziók vannak mindenből, így jó ötlet lehet az egészet átemelni).
A végén jöhet egy reboot.
Végül kernel upgrade minimum az 5.8-ra. Az 5.9 teljesen jó. Látom, neked már fenn van a 5.10-es, talán célszerű lenne ezt eltávolítani először, aztán megcsinálni a fentebbieket, majd a legvégén felrakni az 5.9-es kernelt.
Desszertként pedig célszerű feltenni a Vulkan-t is, leírás itt: link
git/firmware/linux-firmware.git
Törlés helyett jobb átnevezni, például „.ORIG” végződésre (mentésnek megmarad).
Ha az átnevezés terminálban történne, akkor így:
Én például a régi fotókat is szívesen nézegetem olykor, ha rossz, ha jó emlék fűz hozzá.
Ellenőrzésnek pedig:
... megtetszett-e a kernelnek az összes modul, vagy problémázik?
Ha nem problémázik, jöhet a rendszer újraindítás.
Oibaf PPA: a Linux MInt 20.x kiadás támogatott jelen pillanatban:
https://launchpad.net/~oibaf/+archive/ubuntu/graphics-drivers
Igaz, a kérdező is ezt használja, de mások kedvéért ideteszem az információt.
