Elakadt frissítés
Sziasztok,
Eltávolítás: linux-image-4.15.0-20-generic (4.15.0-20.21) ...
/etc/kernel/postrm.d/initramfs-tools:
update-initramfs: Deleting /boot/initrd.img-4.15.0-20-generic
....és itt elakad.
Tudnátok ebben segíteni?
Melyik Linux Mintet használod
#1
System:
  Host: apa-Aspire-7250G Kernel: 4.15.0-91-lowlatency x86_64 bits: 64
  compiler: gcc v: 7.4.0 Desktop: MATE 1.20.1 info: mate-panel
  wm: marco 1.20.1 dm: LightDM 1.26.0 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
Machine:
  Type: Laptop System: Acer product: Aspire 7250G v: V1.10 serial: <filter>
  Mobo: Acer model: HMA71_BZ serial: <filter> BIOS: Insyde v: 1.10
  date: 11/02/2011
Battery:
  ID-1: BAT0 charge: 24.0 Wh condition: 24.0/48.4 Wh (50%) volts: 12.4/11.1
  model: AS10B75 type: Li-ion serial: <filter> status: Full
CPU:
  Topology: Dual Core model: AMD E-450 APU with Radeon HD Graphics bits: 64
  type: MCP arch: Bobcat L2 cache: 512 KiB
  flags: lm nx pae sse sse2 sse3 sse4a ssse3 svm bogomips: 6585
  Speed: 825 MHz min/max: 825/1650 MHz Core speeds (MHz): 1: 1030 2: 921
Graphics:
  Device-1: AMD Wrestler [Radeon HD 6320] vendor: Acer Incorporated ALI
  driver: radeon v: kernel bus ID: 00:01.0 chip ID: 1002:9806
  Device-2: AMD Seymour [Radeon HD 6400M/7400M Series] driver: radeon
  v: kernel bus ID: 01:00.0 chip ID: 1002:6760
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa compositor: marco v: 1.20.1
  resolution: 1600x900~60Hz
  OpenGL: renderer: AMD PALM (DRM 2.50.0 / 4.15.0-91-lowlatency LLVM 9.0.0)
  v: 3.3 Mesa 19.2.8 compat-v: 3.1 direct render: Yes
Audio:
  Device-1: AMD Wrestler HDMI Audio vendor: Acer Incorporated ALI
  driver: snd_hda_intel v: kernel bus ID: 00:01.1 chip ID: 1002:1314
  Device-2: AMD SBx00 Azalia vendor: Acer Incorporated ALI
  driver: snd_hda_intel v: kernel bus ID: 00:14.2 chip ID: 1002:4383
  Sound Server: ALSA v: k4.15.0-91-lowlatency
Network:
  Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lite-On
  driver: ath9k v: kernel port: 5100 bus ID: 07:00.0 chip ID: 168c:0032
  IF: wlp7s0 state: up mac: <filter>
  Device-2: Qualcomm Atheros AR8152 v2.0 Fast Ethernet
  vendor: Acer Incorporated ALI driver: atl1c v: 1.0.1.1-NAPI port: 2000
  bus ID: 08:00.0 chip ID: 1969:2062
  IF: enp8s0 state: down mac: <filter>
Drives:
  Local Storage: total: 465.76 GiB used: 51.27 GiB (11.0%)
  ID-1: /dev/sda vendor: Hitachi model: HTS547550A9E384 size: 465.76 GiB
  speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: A60A scheme: MBR
Partition:
  ID-1: / size: 127.81 GiB used: 51.27 GiB (40.1%) fs: ext4 dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 57.8 C mobo: N/A gpu: radeon temp: 57 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 1091 Uptime: 1h 59m Memory: 5.55 GiB used: 1.74 GiB (31.3%)
  Init: systemd v: 237 runlevel: 5 Compilers: gcc: 7.3.0 alt: 7 Shell: bash
  v: 4.4.19 running in: mate-terminal inxi: 3.0.27
#2 #3 Mit mutat, ha futtatod?
sudo apt-get upgrade --simulate
A kimenetet az Ubuntu Pastebin segítségével oszd meg.
(Leírás: https://linuxmint.hu/blog/2020/04/a-honlap-mukodese-7-resz-ubuntu-pasteb... )
sudo apt-get update ; sudo apt-get upgrade (ferry hsz-e)
#4 Ferry hozzászólása: https://paste.ubuntu.com/p/TtT7T5JbCb/
Kértelek az Ubuntu Pastebin használatára (ferry). Linkeltem, hogyan kell.
Fentebb, amit kértem, megcsináltam helyetted.
A kimenet kéne most (és az Ubuntu Pastebinre...)
#5
ok.. bocs, elnéztem.
https://paste.ubuntu.com/p/N3TKTW7MC7/
#10 A Synaptic bezárva? Valami használja a dpkg-t az APT-on kívül. Két csomagkezelő egyszerre nem működik.
E: Nem sikerült zárolni: /var/lib/dpkg/lock-frontend - open (11: Erőforrás átmenetileg nem érhető el)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
#13 A rendszer újraindítás is megoldás a dpkg zárolásra.
Próbájuk eltávolítani a megmaradt csomagot (linux-image-4.15.0-20-generic):
Kimenet?
A Friisítéskezelőnek is van eltávolítós, takarítós funkciója, de ezt most hagyjuk egyelőre.
#14
Igen, azt már futattam, de az is itt akadt el:
#16 Itt mi van?
ls -1 /boot
#16
a fent említett parancsok szintén idáig futottak:
"Deleting /boot/initrd.img-4.15.0-20-generic".
#17
apa@apa-Aspire-7250G:~$ ls -1 /boot
abi-4.15.0-20-generic
config-4.15.0-20-generic
config-4.15.0-91-lowlatency
grub
initrd.img-4.15.0-91-lowlatency
memtest86+.bin
memtest86+.elf
memtest86+_multiboot.bin
retpoline-4.15.0-20-generic
System.map-4.15.0-20-generic
System.map-4.15.0-91-lowlatency
vmlinuz-4.15.0-91-lowlatency
#17 #19 Másik kernelt használsz: linux-image-4.15.0-91-lowlatency
A problémás csomag telepítésére próba (nincs már vmlinuz, initrd.img fájlja -> boot):
sudo apt-get install linux-image-4.15.0-20-generic
vagy
sudo apt-get install --reinstall linux-image-4.15.0-20-generic
#20
apa@apa-Aspire-7250G:~$ sudo apt-get install linux-image-4.15.0-20-generic
[sudo] apa jelszava:
apa@apa-Aspire-7250G:~$ sudo apt-get install --reinstall linux-image-4.15.0-20-generic
ismét ez jelenik meg, pedig nem nyitottam meg semmit, de ismét csinálok egy újraindítást.
#21 A sikertelen eltávolítás miatt foglalt megint a dpkg. Ilyenkor törölni kell ezt a kimenetben látható lock fájlt (nem bevett megoldás!), de utána még jelentkezhet más, hasonló zárolás hiba. MIndezt a rendszer újraindítás egyszerűbben megoldja. Ha a telepítés nem sikerül, az nem biztos, hogy zárolással jár.
#22 Nem tudom hogy került oda a lowlatency összetevő, de az biztos hogy nem az alaptelepítéssel jött.
Nálam egyébként ma frissült 4.15.0-101 ről 4.15.0-106-ra. https://ibb.co/xqfpX9v
#23 A headers telepítése vélhetóen megoldja.
Kibontás előkészítése: .../linux-image-4.15.0-20-generic_4.15.0-20.21_amd64.deb ...
Kibontás: linux-image-4.15.0-20-generic (4.15.0-20.21) e helyett: 4.15.0-20.21 ...
Beállítás: linux-image-4.15.0-20-generic (4.15.0-20.21) ...
I: /vmlinuz.old is now a symlink to boot/vmlinuz-4.15.0-20-generic
I: /initrd.img.old is now a symlink to boot/initrd.img-4.15.0-20-generic
Aktiválók feldolgozása: linux-image-4.15.0-20-generic (4.15.0-20.21) ...
/etc/kernel/postinst.d/dkms:
Error! echo
Your kernel headers for kernel 4.15.0-20-generic cannot be found at
/lib/modules/4.15.0-20-generic/build or /lib/modules/4.15.0-20-generic/source.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-4.15.0-20-generic
A linux-image-4.15.0-20-generic (4.15.0-20.21) kernelt kiválasztva kell indítani a rendszert, majd:
sudo apt-get install linux-headers-$(uname -r)
Vagy bármelyik kernellel belépve:
sudo apt-get install linux-headers-4.15.0-20-generic
(itt néztem, mi a pontos neve: https://packages.ubuntu.com/search?keywords=4.15.0-20-generic&searchon=n... )
Amíg megvan ez a gond, ezt a kernelt eltávolítani sem lehet. Ez az ok.
#24 Itt a Linux Mint 19.1-ről van szó, és lehet, nem szeretne a 19.3-ra frissíteni (mintupdate). Kernel más lehet.
#29 Neki újabb: https://linuxmint.hu/comment/38682#comment-38682
Vélhetően a 18.3-ról frissített a 19.0-ra, majd a 19.1-re, így maradt benne ez a kernel.
csak egy "hátha" próba
Menü->Adminsztráció->Szoftverforrások
  • Lista-összevonási problémák javítása
  • Hátramaradt beállítófájlok tisztítása
  • Többszörös bejegyzések eltávolítása
Köszönöm István, ezt már
Köszönöm István, ezt már futattam és most újra megtettem, de nem változtat.
ezt a fájl úgy beékelődött, hogy nem lehet elmozdítani, -
- futtatás itt elakad.
 - tudnál erre valamit ajánlani?
#32 Zárj be minden futó alkalmazást - csak a terminál legyen nyitva - és futtasd egymás után
a "Takarítás" címszó alatt lévő parancsokat. http://ubuntu.hu/node/27859
Ha valamelyik hibát dob, állj meg és mutasd.
#32 Meddig vársz itt?
Mert ami elakadásnak látszik, sokszor „pár perc” gondolkodás is lehet.
De eltávolítani csak a headers telepítése után lehet. Itt írtam:
https://linuxmint.hu/comment/38714#comment-38714
Telepítve lett a headers valamelyik ajánlott módszerrel, vagy esetleg a Synaptic segítségével?
Ha nem, akkor először a headerst telepítsd, indítsd újra a rendszert, lépj be a lowlatency kernellel, majd próbáld a kérdéses kernel eltávolítását. Érdemes lenne a folyamatot megosztani. Ha a Synapticot használod a headers telepítésére, az a kimenet is másolható. Kérdés az is, mi történik a headers telepítésekor. Itt biztosan várnod kell, ugyanis az ablak csak akkor záródik be, ha a telepítés sikeres vagy hibára fut, azaz, valamilyen eredménye van.
A hibaüzenet headers hiányra utal (a modult a headers teszi be oda):
Error! echo
A közölt kimenet is azt mondja, a headers alkalmazás nem található:
Az én rendszeremen telepítve van a headers, a „build” és a „source” könyvtárak láthatóak:
ls -1 /lib/modules/4.19.0-9-amd64/
build
kernel
misc
modules.alias
modules.alias.bin
modules.builtin
modules.builtin.bin
modules.dep
modules.dep.bin
modules.devname
modules.order
modules.softdep
modules.symbols
modules.symbols.bin
source
A telepítés sem Syanaptic
A telepítés sem Syanaptic segítségével, sem máshogy nem lehetséges, nem fut végig - ugyan az a folyamat -  vagy e hibából vagy egyébből kifolyólag.
A várakozási időt húsz percre kitoltam.
#35 Értem. Próbálok megoldást keresni erre.
#36 Esetleg ezt próbáld:
sudo apt autoremove linux-image-4.15.0-20-generic
Forrás: https://keskustelu.suomi24.fi/t/15291737/vanhan-kernelin-poistaminen
Ha nem megy...
Itt mi van nálad?
ls -1 /var/lib/initramfs-tools/
Ha látod a listában az eltávolítandó kernelt, akkor ezt kéne csinálni:
cd /boot
sudo update-initramfs -d -k 4.15.0-20-generic
MIután megvolt, kimenet?
ls -1 /boot
Forrás: https://blog.khmersite.net/2020/04/getting-rid-of-old-initrd-files-on-ub...
A harmadik parancssor magyarázata:
https://www.systutorials.com/docs/linux/man/8-update-initramfs/
Még lehet, hogy lesz teendő... . Ennek érdekében kéne a kimenet:
ls -1 /var/lib/dpkg/info/ | grep linux-image
A postrm script lesz érdekes.
És ez a kimenet is kéne:
dpkg --list | egrep -i 'linux-image|linux-headers'
A probléma másik része (ami nem headers) az, hogy a párja nincs meg (eltávolítandó kernel):
initrd.img-4.15.0-91-lowlatency -> ?
vmlinuz-4.15.0-91-lowlatency -> ?
retpoline-4.15.0-20-generic <- csak ez van! (a linux-modules csomag része)
apa@apa-Aspire-7250G:~$ ls -1 /var/lib/initramfs-tools/
4.15.0-20-generic
apa@apa-Aspire-7250G:~$ cd /boot
apa@apa-Aspire-7250G:/boot$ sudo update-initramfs -d -k 4.15.0-20-generic
Úgy tűnik valami alakul..
4.15.0-20-generic
apa@apa-Aspire-7250G:/boot$ ls -1 /var/lib/dpkg/info/ | grep linux-image
linux-image-4.15.0-20-generic.list
linux-image-4.15.0-20-generic.md5sums
linux-image-4.15.0-20-generic.postinst
linux-image-4.15.0-20-generic.postrm
linux-image-4.15.0-20-generic.preinst
linux-image-4.15.0-20-generic.prerm
linux-image-4.15.0-20-generic.triggers
linux-image-4.15.0-91-lowlatency.list
linux-image-4.15.0-91-lowlatency.md5sums
linux-image-4.15.0-91-lowlatency.postinst
linux-image-4.15.0-91-lowlatency.postrm
linux-image-4.15.0-91-lowlatency.preinst
linux-image-4.15.0-91-lowlatency.prerm
linux-image-4.15.0-91-lowlatency.triggers
apa@apa-Aspire-7250G:/boot$ dpkg --list | egrep -i 'linux-image|linux-headers'
iF  linux-image-4.15.0-20-generic                               4.15.0-20.21                           amd64        Signed kernel image generic
ii  linux-image-4.15.0-91-lowlatency                            4.15.0-91.92                           amd64        Signed kernel image lowlatency
#34 És még kettő próba:
sudo apt-get install --reinstall linux-headers-4.15.0-20 linux-headers-4.15.0-20-generic linux-image-4.15.0-20-generic linux-headers-4.15.0-91-lowlatency linux-modules-4.15.0-91-lowlatency
A második:
sudo apt-get install --reinstall linux-headers-4.15.0-20 linux-headers-4.15.0-20-generic linux-image-4.15.0-20-generic linux-image-4.15.0-20-lowlatency linux-headers-4.15.0-20-lowlatency linux-headers-4.15.0-91-lowlatency linux-modules-4.15.0-91-lowlatency
#40 Akkor most ez jön, az előbbit még ne csináld.
sudo update-initramfs -uk all
#42 Esetleg ezt kell telepíteni (az előbbiek után, ha a probléma még fennáll):
sudo apt-get install linux-image-4.15.0-91-generic
Elakadt frissítés...
#45 Sziasztok!
Nekem már nagyon sokszor bevált ez a szkript. Feltétele, hogy a rendszer elinduljon egy jól bevált kernel verzióval. Indítása esetén automatikusan sorban leveszi az összes kernelt minden hozzátartozó fájljával egyetemben az aktív kivételével. A régebbieket és az újabbakat is, ha esetleg valaki vissza szeretne lépni (rolling release pl.)! (sudo nem kell, benne van a szövegben ott, ahol kell)
dpkg-query -W -f '${Version}\n' 'linux-image-[^g]*'|sort -u|sed -e '/^$/d' -e 's/\~[^~]*$//' -e 's/\.[^.]*$//' -e "/$(uname -r|sed 's/-generic\|-lowlatency//')/d" -e 's/.*/linux-*-&*/'|tr '\n' ' '|xargs -r sudo apt-get remove --purge -y
Forrás (kicsit lejjebb görgetve): https://forum.peppermintos.com/index.php/topic,8828.0.html
#46 Köszi. Hát igen... . Jó, de más a gond. Őszinte voltam. :)
Az aláírásod alatt van (is) „rengeteg Enter”. Gondolom, felesleges. Ennyi üres terület a fejben is veszélyes! .. lenne. ;)
#47 Én is teljesen őszintén azt hittem, hogy ha feláll a rendszer és nem nyomunk semmilyen upgrade-t, hanem helyette a belinkelt cuccot, akkor újraindítás után csont nélkül (remélhetőleg) menni fog az upgrade. Úgy látszik, elsiklottam a lényeg fölött. enterek kiirtva thnx
#48 Kipróbáltam. Hibára futott:
Removing linux-image-4.19.0-9-amd64 ├──────────────────┐
  │ You are running a kernel (version 4.19.0-9-amd64) and attempting to      │
  │ remove the same version.                                                 │
  │ This can make the system unbootable as it will remove                    │
  │ /boot/vmlinuz-4.19.0-9-amd64 and all modules under the directory         │
  │ /lib/modules/4.19.0-9-amd64. This can only be fixed with a copy of the   │
  │ kernel image and the corresponding modules.                              │
  │ It is highly recommended to abort the kernel removal unless you are      │
  │ prepared to fix the system after removal.                                │
  │ Abort kernel removal?                                                    │
  │                    <Igen>                      <Nem>
#49 Gondolom, azt szeretted volna hozzátenni, amikor kérdez,
│ Abort kernel removal? | Megszakítja a használatban lévő kernel eltávolítását? │
│                    <Igen>                      <Nem>
akkor az Igent kell kiválasztani, és a kiválasztás után Entert kell ütni.
Ha nem így tesz a parancssort futtató felhasználó, akkor az van, amit ír is a CLI felületen olvasható tájékoztatás,
│ This can make the system unbootable | ha a használatban lévő kernelt is eltávolítja, akkor a rendszer indíthatatlanná válik.
hogy nem fog elindulni a rendszer, ha azt egyszer leállítja, vagy kijelentkezik.
Nem mindenki tud angolul... . Sokan nem tudnak.
Ezzel együtt ki lehet próbálni, vagyis csak ezzel együtt lehet próbálni. ;)
De ..., ha nem ment a mi eltávolítási parancsainkkal, akkor ami ugyanaz lényegében,
miért menne? Ez, amit eltávolít a parancssorban. A többi csak keres.
Mi a purge-t, továbbá a Synaptic-ot is próbáltuk. A szokásos módon nem lehet eltávolítani, sem újratelepíteni a kernelt. Összekavarodott a rendszer, más gond van.
Valami van a videó lejátszáskor a gépemmel, a CLI le is fagyott. A megszakadt folyamatot (senki ne csinálja utánam, egyedi), így tudtam javítani (egy sorba sűrítve):
sudo rm -f /var/lib/dpkg/lock-frontend ; sudo rm -f /var/lib/dpkg/lock ; sudo dpkg --configure -a ; sudo apt-get -f install ; sudo rm -f /var/cache/apt/archives/lock ; sudo apt-get -f install ; sudo apt-get autoremove --purge
Most jó:
update-initramfs: Generating /boot/initrd.img-4.19.0-9-amd64
live-boot: core filesystems devices utils memdisk udev blockdev dns.
ls -1 /boot
config-4.19.0-9-amd64
grub
System.map-4.19.0-9-amd64
... de az egérgörgő nem működik a terminálban. Javítanivaló. Tegnap kezdődött.
Tényleg zavaró a sok felesleges Enter. Köszi
off
#50 A reddszer felhasználói felületének fagyása oka videó lejátszás lehet. Kiderül.
#32 Live rendszerről kéne indítani a gépet, és ellenőrizni a gépben levő lemezt. (Kellékek, lemezek, kiválasztani a vizsgálandó lemezt, és a fogaskerék ikon alatt a lemez ellenőrzését választani - telepítő felületen Accessories -> Disks, fogaskerék -> Check Filesystem...)
Hátha lemezhibáról van szó...
Itt a vége fuss el véle..
Tehát, végigfutattam a fent leírt parancsokat és a folyamatok rendszeresen ezzel a végződéssel -
Error! echo
 - megszakadtak.
Így marad, az op. rendszer használható,  - ameddig így képes futni, -  aztán ha kifullad, majd telepítem újra.
Minden résztvevőnek köszönöm a hozzászólásokat.
További szép napot!
#53 Valamilyen bug lehet az okat, vélhetően, mert fő verzió frissítés történt a Linux Mint 18 kiadásról a 19 kiadásra. Ezt nem kérdeztük, de érintettük. Így történt?
Jó lett volna látni a parancssorok kimenetét, mi történik közben.
A 19.1 kiadás telepítsd friss telepítéssel, így nem jelentkezik a hiba.
#53 Valószínű napokon belül kiadásra kerül a Mint 20 Beta verziója - ez után kb. 1.5-2 hét
múlva a végleges kiadás. Ments le minden fontosat a jelenlegi rendszeredről, és ha megjelenik
a 20, próbáld ki live-ban - mielőtt telepíted.
A vele kapott kernelt pedig nem kéne piszkálni - ha maga a rendszer és a csatlakoztatott
eszközök jól működnek.
