Apróbb gondom támadt Xfce-n. A Whisker menü jobb gombos alkalmazása esetén lehetőség nyilik a menük szerkesztésére. A menulibre programot alkalmazza. Most azonban nem nyitja meg. Terminálból inditva pedig ez a kimenet:
[andrea@andrea-pc ~]$ menulibre
(menulibre:2245): Gtk-WARNING **: 09:01:37.505: gtk_menu_attach_to_widget(): menu already attached to GtkMenuButton
(menulibre:2245): Gtk-WARNING **: 09:01:37.675: gtk_menu_attach_to_widget(): menu already attached to GtkMenuButton
Traceback (most recent call last):
File "/usr/lib/python3.7/site-packages/menulibre/MenulibreApplication.py", line 2217, in do_activate
self.win = MenulibreWindow(self, headerbar)
File "/usr/lib/python3.7/site-packages/menulibre/MenulibreApplication.py", line 250, in __init__
self.configure_application_treeview(builder)
File "/usr/lib/python3.7/site-packages/menulibre/MenulibreApplication.py", line 589, in configure_application_treeview
self.treeview = MenulibreTreeview.Treeview(self, builder)
File "/usr/lib/python3.7/site-packages/menulibre/MenulibreTreeview.py", line 48, in __init__
self._configure_treeview(builder)
File "/usr/lib/python3.7/site-packages/menulibre/MenulibreTreeview.py", line 59, in _configure_treeview
treestore = MenuEditor.get_treestore()
File "/usr/lib/python3.7/site-packages/menulibre/MenuEditor.py", line 123, in get_treestore
return menu_to_treestore(treestore, None, menu)
File "/usr/lib/python3.7/site-packages/menulibre/MenuEditor.py", line 100, in menu_to_treestore
tooltip = escapeText(item[2]['comment'])
File "/usr/lib/python3.7/site-packages/menulibre/util.py", line 99, in escapeText
return GLib.markup_escape_text(text, len(text))
File "/usr/lib/python3.7/site-packages/gi/overrides/GLib.py", line 415, in markup_escape_text
return GLib.markup_escape_text(text, length)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xc3 in position 21: unexpected end of data
Hol lehet a hiba?
UnicodeDecodeError UTF-8
Emiatt a sor miatt omlik össze a MenuLibre:
Bizonyos helyzetekben, mint például most, az alkalmazás indításnál az összeomlás elött közvetlen jelentkezö (utolsó sor) hiba az ok.
Úton vagyok, de úgy vélem, valami Python gond lehet. Átmenetileg át kéne állítani a jelenleg használt Python nyelvet egy másikra. Több is telepítve van. Paranccsorból lehet megcsinálni.
Esetleg a valami ismeretlen betü kódolású karakter kerülhetett be valamelyik alkalmazáshoz a MenuLibre legutóbbi használata alkalmával. Ilyesmi akkor fordul elö leginkább, ha másolod a szöveget a netröl.
Python 3.7 ?
Gondolom, a rendszer nem Linux Mint, mert nálam nincs is 3.7-es verziójú Python:
Ez van használatban:
Ezek a lehetőségek:
Van, aki így oldotta meg:
https://stackoverflow.com/questions/12468179/unicodedecodeerror-utf8-cod...
Ezt:
Nem tudni miért, de a te Python verziód gondokat okoz.
A használt verziót nem a szokásos módon lehet átállítani:
https://unix.stackexchange.com/questions/410579/change-the-python3-defau...
https://linuxconfig.org/how-to-change-from-default-to-alternative-python...
https://help.dreamhost.com/hc/en-us/articles/115000702772-Installing-a-c...
A kép forrása: https://itsfoss.com/python-setup-linux/
Python 3.7 ?
Ezt a sort:
betettem az /etc/locale.conf fájlba, újrainditottam a rendszert, de nem változott a hiba. Sebaj, majd kijavítják. Mint-en és Ubuntu-n a régebbi python verzióval megy ugyanez a verziójú Menulibre.
Python 3.7 ?
Innen telepítettem (az imént):
https://www.libreoffice.org/download/download/
Mert a PPA tükör nem stable, de nemcsak beta, hanem alpha is:
https://launchpad.net/~libreoffice/+archive/ubuntu/libreoffice-prereleases
A dpkg-val, de hasonló leírást írtam csak, más alkalmazásról.
Megtaláltam a Sytemback leírást:
https://linuxmint.hu/sugo/a-systemback-rendszermento-es-rendszer-visszaa...
Kell majd egy gép, amin kipróbálom az új verziót, mert a noteszgépen nem találta a boot zászlót a telepítő, amit a Systemback alkalmazással készítettem. De a noteszgéppel gond van.
Azért olyan nagy gondot nem
Azért olyan nagy gondot nem jelent a menüszerkesztő: mint Alfonzónál van másik... (Alacarte) A whiskermenu.rc-t sem olyan nagy művészet átfabrikálni arról erre. Meghagytam, kiváncsi leszek mikor lesz jó. A Systemback készült Mintes mentést kiírtam és visszaolvastam, ezt
[andrea@andrea-pc home]$ ls -la
összesen 4747428
drwxr-xr-x 4 root root 4096 márc 12 11.06 .
drwxr-xr-x 23 root root 4096 márc 12 11.12 ..
drwxr-xr-x 23 andrea andrea 4096 márc 18 08.46 andrea
drwxr-xr-x 2 root andrea 4096 márc 12 10.39 Systemback
-rw-rw-rw- 1 root root 2431647744 márc 12 11.06 systemback_live_2019-03-12.iso
-rw-rw-rw- 1 root root 2430412800 márc 12 10.56 systemback_live_2019-03-12.sblive
Teljesen jó volt.
Gondolom, az Arch Linux viszonylag hamar javítja a MATE-s MenuLibre-t. Van más erre, igen. :-)
Lemaradt a van másik: https:/
Lemaradt a van másik: https://www.youtube.com/watch?v=q3lQYIKMEt8
Menulibre hiba
Új fejlemény, a hamarosan kiadásra kerülő Xubuntu 19.04-ben a frissités után ugyancsak összeomlik a Menulibre, pedig az alapértelmezett Whiskermenu-ben ő az alapértelmezett menüszerkesztő. (Hiba várható a Mint Xfce-ben is?)
Menulibre hiba
Menulibre hiba
andrea@andrea-350V5C-351V5C-3540VC-3440VC:~$ uname -a
Linux andrea-350V5C-351V5C-3540VC-3440VC 5.0.0-8-generic #9-Ubuntu SMP Tue Mar 12 21:58:11 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
andrea@andrea-350V5C-351V5C-3540VC-3440VC:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu Disco Dingo (development branch)
Release: 19.04
Codename: disco
andrea@andrea-350V5C-351V5C-3540VC-3440VC:~$ menulibre
(menulibre:1423): Gtk-WARNING **: 19:58:55.920: gtk_menu_attach_to_widget(): menu already attached to GtkMenuButton
(menulibre:1423): Gtk-WARNING **: 19:58:56.010: gtk_menu_attach_to_widget(): menu already attached to GtkMenuButton
File "/usr/lib/python3/dist-packages/menulibre/MenulibreApplication.py", line 2217, in do_activate
File "/usr/lib/python3/dist-packages/menulibre/MenulibreApplication.py", line 250, in __init__
File "/usr/lib/python3/dist-packages/menulibre/MenulibreApplication.py", line 589, in configure_application_treeview
File "/usr/lib/python3/dist-packages/menulibre/MenulibreTreeview.py", line 48, in __init__
File "/usr/lib/python3/dist-packages/menulibre/MenulibreTreeview.py", line 59, in _configure_treeview
File "/usr/lib/python3/dist-packages/menulibre/MenuEditor.py", line 123, in get_treestore
File "/usr/lib/python3/dist-packages/menulibre/MenuEditor.py", line 111, in menu_to_treestore
treestore = menu_to_treestore(treestore, treeiter, item[3])
File "/usr/lib/python3/dist-packages/menulibre/MenuEditor.py", line 100, in menu_to_treestore
File "/usr/lib/python3/dist-packages/menulibre/util.py", line 99, in escapeText
File "/usr/lib/python3/dist-packages/gi/overrides/GLib.py", line 415, in markup_escape_text
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xc3 in position 44: unexpected end of data
^C
Menulibre hiba
Menulibre hiba
Menulibre hiba
https://bugs.launchpad.net/menulibre/+bug/1817885
Itt látok egy foltozást:Értékelés:
Igen! Ez egy nagyon jó tipp!
Igen! Ez egy nagyon jó tipp! Működik Archon és Ubuntun is. Nagyon köszönöm.
Menulibre hiba
Menulibre hiba
