Véletlenszerűen lefagy a képernyő és semmire nem reagál
 varga@varga-Aspire-A315-31 ~ $ inxi -Fxxx
System: Host: varga-Aspire-A315-31 Kernel: 4.13.0-38-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3) dm: lightdm
Distro: Linux Mint 18.3 Sylvia
Machine: System: Acer product: Aspire A315-31 v: V1.09 Chassis: type: 10
Mobo: APL model: Ivysaur_AP v: V1.09
Bios: Insyde v: V1.09 date: 10/17/2017
CPU: Dual core Intel Celeron N3350 (-MCP-) cache: 1024 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 4377
clock speeds: min/max: 800/2400 MHz 1: 804 MHz 2: 1067 MHz
Graphics: Card: Intel Device 5a85 bus-ID: 00:02.0 chip-ID: 8086:5a85
Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa)
Resolution: 1366x768@60.02hz
GLX Renderer: Mesa DRI Intel HD Graphics 500 (Broxton 2x6)
GLX Version: 3.0 Mesa 17.2.8 Direct Rendering: Yes
Audio: Card Intel Device 5a98
driver: snd_hda_intel bus-ID: 00:0e.0 chip-ID: 8086:5a98
Sound: Advanced Linux Sound Architecture v: k4.13.0-38-generic
Network: Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: 1000
bus-ID: 02:00.1 chip-ID: 10ec:8168
IF: enp2s0f1 state: down mac: d8:c4:97:0f:6a:83
Card-2: Qualcomm Atheros Device 0042
driver: ath10k_pci bus-ID: 03:00.0 chip-ID: 168c:0042
IF: wlp3s0 state: up speed: N/A duplex: N/A mac: e8:2a:44:93:eb:65
Drives: HDD Total Size: 500.1GB (5.4% used)
ID-1: /dev/sda model: TOSHIBA_MQ01ABF0 size: 500.1GB serial: X7E5S8BCS
Partition: ID-1: / size: 455G used: 22G (6%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 4.13GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
RAID: System: supported: N/A
No RAID devices: /proc/mdstat, md_mod kernel module present
Unused Devices: none
Sensors: System Temperatures: cpu: 38.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 179 Uptime: 15 min Memory: 919.6/3785.5MB
Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.4.0
Client: Shell (bash 4.3.481 running in gnome-terminal-) inxi: 2.2.35
Sziasztok segítséget
Sziasztok segítséget szeretnék kapni, egyszerűen csak véletlenszerűen lefagy a képernyő és semmire nem reagál. Filmnézés közben a kép megáll és a hang megy tovább és a gép nem reagál semmire.
köszönöm
#1 Milyen filmet nézel, lemezről DVD-t? Próbáltál más filmet, filmeket? Melyik lejátszó?
Szia, pendrive-ról néztem, de simán netezés közben is lefagy, mindegy milyen oldalon olvasok vagy nézem egy videot.
#1 árpi-erre a laptopra,hogy raktal mintet???hmmm ez engem érdekelne...kosz
#3 A
dmesg tail
parancs kimenetét megosztanád a https://paste.ubuntu.com/ oldal segítségével? A bemásolt szöveget linkeld a mentés után.
Memóriák rendben? MEMTEST-et néztél?
#6 beutom a terminalba a dmesg tail-t, oszt semmi-dmesg--bad usage...nemkell megoldani,csak érdekes...
meglatom huszonhatodikan mit fog válaszolni......
#7 Sajnos, itt nem sokat látni, hibát nemigen. Fagyás után újraindított rendszeren kéne a
/var/log/syslog
és a
/var/log/kern.log
szövegfájlok tartalma, remélem, a paste.ubuntu oldalra felfér.
Azt nézd meg még, hogy mi a fájlok dátuma. A fagyás előtti nap legyen legalább, mert időszakonként backup fájlok készülnek, és a fagyás utáni időpontban készült log fájl értelemszerűen nem lesz kiértékelhető.
Gyanakodnék még a videókártya, vagy hűtésének koszolódására, tápfeszültség hibára (kevés). ... ki van takarítva a gép?
#9  lazlo@lazlo-Aspire-A315-31:~$ sensors
acpitz-virtual-0
Adapter: Virtual device
temp1: +42.0°C (crit = +104.0°C)
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +43.0°C (high = +105.0°C, crit = +105.0°C)
Core 0: +41.0°C (high = +105.0°C, crit = +105.0°C)
Core 1: +41.0°C (high = +105.0°C, crit = +105.0°C)
Core 2: +42.0°C (high = +105.0°C, crit = +105.0°C)
Core 3: +42.0°C (high = +105.0°C, crit = +105.0°C)
-ez van,ha nemcsinalok semmit,ha igen a ventillator nonsztop zug,utana kidobja a jatekot...ezt csak megjegyzem az aszpirehoz...eléggé szornyu laptop ez az acer...
