Beküldte lolka1980 -
Volna itthon egy mediacenterem amin win10 fut.
Van onnan file megosztásom is,amit a család többi pcje el is ér.(win10 illetve win7). Bekéri a felhasználó nevet illetve a jelszót és már tudom is kezelni a mappákat.
Az én pcémen viszont Linux mint 18.3 cinnamon került.
Hogyan tudom elérni a mediacenterem által megosztott mappákat?
Nemo-val próbáltam de ez fogad:
http://www.kepfeltoltes.eu/view.php?filename=549K_perny_337_k_p_2018_0.png
Illetve:
Átírtam "WORKGROUP"-ra
http://www.kepfeltoltes.eu/view.php?filename=343K_perny_337_k_p_2018_0.png
Mit is kellene tennem hogy elérjem?
Vagy kellene valami plusz csomagot telepíteni?
A megoldás nem workgroup se
A megoldás nem workgroup se network hanem "smb"
Vagyis pl:
smb://192.168.0.100
Köszönöm.
Your antivirus package is crying wolf?
@#2 Röptében nem sokat találtam, ezeket:
https://en.wikipedia.org/wiki/Monero_(cryptocurrency)
https://thehackernews.com/2017/10/coinhive-cryptocurrency-miner.html
https://malwaretips.com/blogs/remove-coin-hive-miner/
https://www.thepolyglotdeveloper.com/2018/01/mine-monero-xmr-cryptocurre...
vagy
This is neither a virus nor a trojan, and it does not make the site unsafe to visit in any way whatsoever. Your antivirus package is crying wolf.
Coinhive is a Javascript plugin which implements a cryptocurrency miner. While you view a web site which uses this script, your browser will perform calculations to mine cryptocurrency for the owner of the web site.
Some users find this script annoying and inappropriate, as it will increase CPU usage (and, hence, power consumption) on your web browser while you have the web site open. However, this will end as soon as you leave the site.
https://security.stackexchange.com/questions/170459/what-is-coin-hive-virus
While the cryptocurrency miners for websites is a very new thing, there is nothing new in approaches that hackers use to abuse it. If something can be installed on a web site and monetized, hackers will do it on websites they compromise. Thus one of the best security practices for webmasters is to monitor integrity of their sites.
https://blog.sucuri.net/2017/09/hacked-websites-mine-crypocurrencies.html
Összegezve én arra jutottam, hogy rossz célra is lehet használni,
https://jonathanmh.com/testing-coin-hive-crowd-source-monero-mining/
de ez még nem a végső összegzés.
Szerinted? Pontosítanál?
@#4 Én csak valami bővebbet szerettem volna megtudni, mert őszintén szólva, a témában még nem igazán mélyedtem el. Például, hogy van-e egy lista a átírányítós oldalakról. És én úgy olvastam néhol, a Java script maga nem veszélyes, de ebben tévedhetek. De most olvastam egy másik hírt:
https://itcafe.hu/hir/rapid_2_0_ransomware_oroszokat_nem_bant.html
Engedély kérés:
