Privacy Policy — ACE Flasher & Disco
Last updated: 2026-09-23
ACE Flasher & Disco ("the app") is a flashlight and disco-light app for Android. This page explains what data the app accesses and what happens to it.
No account, no server
The app does not require sign-up or login, and has no backend server of its own. All of your profiles and settings (Flash profiles, Display profiles, theme, sensitivity settings, etc.) are stored only in the app's local storage on your device, and are never uploaded anywhere.
Microphone
When you enable a sound-reactive (audio-reactive) Flash or Display profile, the app uses the microphone to measure the ambient sound level and detect beats in real time, purely to decide when to flash or change colour. Audio is processed entirely in memory on your device — it is never recorded to a file, stored, or transmitted anywhere, by the app or by us.
Camera flash
The app uses the camera's flash/torch hardware to produce light. It does not access the camera sensor, and never captures photos, video, or images.
Crash and diagnostic reporting (Firebase Crashlytics)
The app uses Firebase Crashlytics (a Google service) to automatically detect and report crashes and non-fatal errors, so we can find and fix bugs. When this happens, the following is sent to Firebase/Google's servers:
- Device model, OS version, and app version
- The crash stack trace
- A short trail of recent internal log messages ("breadcrumbs") to help understand what led to the crash
This data is not used to identify you personally. See Firebase's privacy documentation for how Google handles this data.
Diagnostic log email (user-initiated only)
The Settings screen has a "Send Diagnostic Log" button. If you tap it, the app zips up its local log file together with basic app/device info, and hands that file to your own email app so you can choose to send it — for example, to us, if you're reporting a problem. The app itself does not transmit this automatically or to any address of its own choosing.
Backup / restore files
The "Export profiles" feature lets you save your profiles to a file you choose, and "Import profiles" lets you load one back in. These files stay under your own control (e.g. in a folder or cloud-storage location you pick) — the app does not upload them anywhere on its own.
Advertising and third-party tracking
The app shows no ads and includes no advertising or analytics SDKs other than Firebase Crashlytics described above. We do not sell or share your data with third parties for marketing purposes.
Children's privacy
The app is not directed at children and does not knowingly collect personal information from children.
Disclaimer & limitation of liability
The app is provided "as is" and "as available", without warranty of any kind, express or implied, including but not limited to warranties of merchantability, fitness for a particular purpose, and non-infringement. The camera flash / torch and screen flashing effects the app produces can be intense — do not use them if you or anyone nearby is photosensitive or has a condition that could be triggered by flashing lights, and use strobe-like modes responsibly (e.g. not while driving, and only at volumes/brightness appropriate to your surroundings).
To the maximum extent permitted by applicable law, the developer is not liable for any direct, indirect, incidental, special, consequential, or exemplary damages (including but not limited to device or hardware wear, data loss, personal injury, or any other loss) arising from or related to your use of, or inability to use, the app. You use the app at your own risk.
Changes to this policy
If this policy changes, the "Last updated" date above will be revised. Continued use of the app after a change means you accept the updated policy.
Contact
Questions about this policy? Write e-mail to the author.
Adatvédelmi tájékoztató — ACE Flasher & Disco
Utolsó frissítés: 2026-09-23
Az ACE Flasher & Disco ("az alkalmazás") egy zseblámpa és diszkófény alkalmazás Androidra. Ez az oldal leírja, milyen adatokhoz fér hozzá az alkalmazás, és mi történik velük.
Nincs fiók, nincs szerver
Az alkalmazás használatához nem kell regisztrálni vagy bejelentkezni, és nincs saját háttérszervere. Minden profilod és beállításod (Vaku- és Kijelzőprofilok, téma, érzékenységi beállítások stb.) kizárólag az eszközöd helyi tárhelyén tárolódik, és sosem kerül feltöltésre semmilyen szerverre.
Mikrofon
Amikor bekapcsolsz egy hangérzékeny (zenére reagáló) Vaku- vagy Kijelzőprofilt, az alkalmazás a mikrofonnal valós időben méri a környezeti hangerőt és érzékeli az ütemeket, kizárólag azért, hogy eldöntse, mikor villanjon vagy váltson színt. A hang teljes egészében az eszközödön, memóriában kerül feldolgozásra — sosem kerül fájlba rögzítésre, tárolásra vagy továbbításra sem az alkalmazás, sem általunk.
Kameravaku
Az alkalmazás a kamera vaku/zseblámpa hardverét használja fényforrásként. Nem fér hozzá a kamera képérzékelőjéhez, és sosem készít fényképet vagy videót.
Hiba- és diagnosztikai jelentés (Firebase Crashlytics)
Az alkalmazás a Firebase Crashlytics-et (egy Google-szolgáltatást) használja a összeomlások és nem végzetes hibák automatikus észlelésére és jelentésére, hogy megtaláljuk és kijavítsuk a hibákat. Ilyenkor a következő adatok kerülnek a Firebase/Google szervereire:
- Eszköz típusa, operációs rendszer verziója, alkalmazás verziója
- A hiba veremkiíratása (stack trace)
- Néhány, a hiba előtt keletkezett belső naplóüzenet ("breadcrumb"), ami segít megérteni, mi vezetett a hibához
Ezeket az adatokat nem használjuk a személyed azonosítására. Részletek a Firebase adatvédelmi dokumentációjában.
Diagnosztikai napló e-mailben (csak felhasználói kezdeményezésre)
A Beállítások képernyőn van egy "Diagnosztikai napló küldése" gomb. Ha megnyomod, az alkalmazás összecsomagolja a helyi naplófájlt alapvető app-/eszközadatokkal együtt, és átadja a saját e-mail alkalmazásodnak, hogy te döntsd el, elküldöd-e — például nekünk, ha hibát jelentesz. Az alkalmazás önmagától nem küldi el ezt sehova.
Biztonsági mentés / visszaállítás fájlok
A "Profilok exportálása" funkcióval egy általad kiválasztott fájlba mentheted a profiljaidat, a "Profilok importálása" funkcióval pedig visszatöltheted azokat. Ezek a fájlok a te irányításod alatt maradnak (pl. egy általad választott mappában vagy felhőtárhelyen) — az alkalmazás önmagától nem tölti fel őket sehova.
Hirdetések és harmadik féltől származó követés
Az alkalmazás nem jelenít meg hirdetéseket, és a fent említett Firebase Crashlytics-en kívül nem tartalmaz hirdetési vagy analitikai SDK-t. Nem adjuk el és nem osztjuk meg az adataidat harmadik féllel marketingcélokra.
Gyermekek adatvédelme
Az alkalmazás nem gyermekeknek szól, és tudatosan nem gyűjt személyes adatot gyermekektől.
Felelősség kizárása és jótállás hiánya
Az alkalmazás "jelen állapotában" ("as is") és "elérhetősége szerint" kerül biztosításra, bárminemű kifejezett vagy vélelmezett garancia nélkül, ideértve többek között az értékesíthetőségre, adott célra való alkalmasságra és jogtisztaságra vonatkozó szavatosságokat is. Az alkalmazás által előállított kameravaku/zseblámpa és képernyővillogás hatások intenzívek lehetnek — ne használd ezeket, ha te vagy a környezetedben lévő bárki fényérzékeny, vagy olyan állapottal rendelkezik, amit a villogó fény kiválthat, és a stroboszkóp-szerű módokat felelősségteljesen használd (pl. ne vezetés közben, és csak a környezetednek megfelelő fényerővel).
Az alkalmazandó jog által megengedett legteljesebb mértékben a fejlesztő nem felelős semmilyen közvetlen, közvetett, véletlenszerű, különleges, következményi vagy példaértékű kárért (ideértve többek között az eszköz vagy hardver elhasználódását, adatvesztést, személyi sérülést vagy bármilyen egyéb veszteséget), amely az alkalmazás használatából vagy használatának ellehetetlenüléséből ered. Az alkalmazást saját felelősségedre használod.
A tájékoztató módosításai
Ha ez a tájékoztató változik, a fenti "Utolsó frissítés" dátum frissül. Az alkalmazás további használata egy módosítás után azt jelenti, hogy elfogadod a frissített tájékoztatót.
Kapcsolat
Kérdésed van a tájékoztatóval kapcsolatban? Írj a készítő e-mail címére.
