Frissítettem és minden szépen működik, kivéve a HP f4180 nyomtatóm.
Újratelepítettem a Hplip-et a Synaptic-kal, de nem segített.
Ezeket a hibajelentéseket sikerült begyüjteni. Mond ez valamit?
A másik kérdésem az, hogy ha Wine-ban szeretném telepíteni a Windows programot, akkor melyik Windows-verziót válasszam a HP illesztőprogramjai közül a Wine-hoz? Segítene? A Wine hozzáfér az USB-hez?
________________
su -c 'journalctl -u cups.service --since="None" --until="2018-11-01 09:22:00"' > troubleshoot-logs.txt
Page 1 (<troubleshoot.SchedulerNotRunning.SchedulerNotRunning object at 0x7f9189c14dd8>):
{'cups_connection_failure': False}
Page 2 (<troubleshoot.CheckLocalServerPublishing.CheckLocalServerPublishing object at 0x7f9189c14e10>):
{'local_server_exporting_printers': False}
Page 3 (<troubleshoot.ChoosePrinter.ChoosePrinter object at 0x7f9189c14e48>):
{'cups_dest': <cups.Dest Deskjet_F4100>,
'cups_instance': None,
'cups_queue': 'Deskjet_F4100',
'cups_queue_listed': True}
Page 4 (<troubleshoot.CheckPrinterSanity.CheckPrinterSanity object at 0x7f9189c1ed30>):
{'cups_device_uri_scheme': 'hp',
'cups_printer_dict': {'device-uri': 'hp:/usb/Deskjet_F4100_series?serial=CN73J1Y0G904TJ',
'printer-info': 'Deskjet_F4100',
'printer-is-shared': True,
'printer-location': '',
'printer-make-and-model': 'HP Deskjet f4100 Series, '
'hpcups 3.17.10',
'printer-state': 3,
'printer-state-message': 'Filter failed',
'printer-state-reasons': ['none'],
'printer-type': 36892,
'printer-uri-supported': 'ipp://localhost/printers/Deskjet_F4100'},
'cups_printer_remote': False,
'hplip_output': (['',
'\x1b[01mHP Linux Imaging and Printing System (ver. '
'3.17.10)\x1b[0m',
'\x1b[01mDevice Information Utility ver. 5.2\x1b[0m',
'Copyright (c) 2001-15 HP Development Company, LP',
'This software comes with ABSOLUTELY NO WARRANTY.',
'This is free software, and you are welcome to distribute '
'it',
'under certain conditions. See COPYING file for more '
'details.',
'\x1b[01mhp:/usb/Deskjet_F4100_series?serial=CN73J1Y0G904TJ\x1b[0m',
'\x1b[01mDevice Parameters (dynamic data):\x1b[0m',
'\x1b[01m Parameter '
'Value(s) '
'\x1b[0m',
' agent1-ack '
'False ',
' agent1-desc Black '
'cartridge ',
' agent1-dvc '
'0 ',
' agent1-health '
'0 ',
' agent1-health-desc '
'Good/OK ',
' agent1-hp-ink '
'False ',
' agent1-id '
'0 ',
' agent1-kind '
'3 ',
' agent1-known '
'False ',
' agent1-level '
'64 ',
' agent1-level-trigger '
'0 ',
' agent1-sku '
'21(C9153A) ',
' agent1-type '
'1 ',
' agent1-virgin '
'False ',
' agent2-ack '
'False ',
' agent2-desc Tri-color '
'cartridge ',
' agent2-dvc '
'0 ',
' agent2-health '
'0 ',
' agent2-health-desc Very '
'low ',
' agent2-hp-ink '
'False ',
' agent2-id '
'10 ',
' agent2-kind '
'3 ',
' agent2-known '
'False ',
' agent2-level '
'0 ',
' agent2-level-trigger '
'6 ',
' agent2-sku '
'22(C9352A) ',
' agent2-type '
'2 ',
' agent2-virgin '
'False ',
' back-end '
'hp ',
' cups-printers '
"['Deskjet_F4100'] ",
' cups-uri '
'hp:/usb/Deskjet_F4100_series?serial=CN73J1Y0G904TJ ',
'dev-file ',
' device-state '
'1 ',
' device-uri '
' deviceid MFG:HP;MDL:Deskjet '
'F4100 ',
'series;CMD:LDL,MLC,PML,DYN;CLS:PRINTER;1284.4DL:4d,4e,1;SN',
':CN73J1Y0G904TJ;S:0380008000020020002c1481040c2561000;Z:00',
'0A2A20000; ',
' duplexer '
'0 ',
' error-state '
'102 ',
'host ',
' in-tray1 '
'True ',
' in-tray2 '
'False ',
' is-hp '
'True ',
' media-path '
'2 ',
' panel '
'0 ',
'panel-line1 ',
'panel-line2 ',
' photo-tray '
'0 ',
' port '
'1 ',
' r '
'0 ',
' revision '
'3 ',
' rg '
'000 ',
' rr '
'000000 ',
' rs '
'000000000 ',
' scan-uri '
'hpaio:/usb/Deskjet_F4100_series?serial=CN73J1Y0G904TJ ',
' serial '
'CN73J1Y0G904TJ ',
' status-code '
'1502 ',
' status-desc Tri-color cartridge is low '
'on ink ',
' supply-door '
'0 ',
' top-door '
'1 ',
'\x1b[01m',
'Model Parameters (static data):\x1b[0m',
'Value(s) '
'\x1b[0m',
' align-type '
'5 ',
' clean-type '
'2 ',
' color-cal-type '
'0 ',
' copy-type '
'0 ',
' embedded-server-type '
'0 ',
' fax-type '
'0 ',
' fw-download '
'False ',
' icon '
'psc_1100_series.png ',
' io-mfp-mode '
'6 ',
' io-mode '
'1 ',
' io-support '
'2 ',
' job-storage '
'0 ',
' linefeed-cal-type '
'0 ',
' model '
'Deskjet_F4100_series ',
' model-ui HP Deskjet f4100 '
'Series ',
' model1 HP Deskjet F4135 '
'All-in-One Printer ',
' model10 HP Deskjet F4190 '
' model11 HP Deskjet F4194 '
' model2 HP Deskjet F4140 '
' model3 HP Deskjet F4150 '
' model4 HP Deskjet F4172 '
' model5 HP Deskjet F4172 '
' model6 HP Deskjet F4175 '
' model7 HP Deskjet F4180 '
' model8 HP Deskjet F4185 '
' model9 HP Deskjet F4188 '
' monitor-type '
'0 ',
' panel-check-type '
'0 ',
' pcard-type '
'0 ',
' plugin '
'0 ',
' plugin-reason '
'0 ',
' power-settings '
'0 ',
' pq-diag-type '
'0 ',
' r-type '
'1 ',
' r0-agent1-kind '
'3 ',
' r0-agent1-sku '
'21(C9153A) ',
' r0-agent1-type '
'1 ',
' r0-agent2-kind '
'3 ',
' r0-agent2-sku '
'22(C9352A) ',
' r0-agent2-type '
'2 ',
' r0-agent3-kind '
'3 ',
' r0-agent3-sku 58 '
'(C6658x) ',
' r0-agent3-type '
'3 ',
' r1-agent1-kind '
'3 ',
' r1-agent1-sku '
'21(C9351A) ',
' r1-agent1-type '
'1 ',
' r1-agent2-kind '
'3 ',
' r1-agent2-sku '
'22(C9352A) ',
' r1-agent2-type '
'2 ',
' r1-agent3-kind '
'3 ',
' r1-agent3-sku 58 '
'(C6658x) ',
' r1-agent3-type '
'3 ',
' r2-agent1-kind '
'3 ',
' r2-agent1-sku 21 '
'(C9351A) ',
' r2-agent1-type '
'1 ',
' r2-agent2-kind '
'3 ',
' r2-agent2-sku 22 '
'(C9352A) ',
' r2-agent2-type '
'2 ',
' r2-agent3-kind '
'3 ',
' r2-agent3-sku 58 '
'(C6658x) ',
' r2-agent3-type '
'3 ',
' r3-agent1-kind '
'3 ',
' r3-agent1-sku 21 '
'(C9351A) ',
' r3-agent1-type '
'1 ',
' r3-agent2-kind '
'3 ',
' r3-agent2-sku 22 '
'(C9352A) ',
' r3-agent2-type '
'2 ',
' r3-agent3-kind '
'3 ',
' r3-agent3-sku 58 '
'(C6658x) ',
' r3-agent3-type '
'3 ',
' r4-agent1-kind '
'3 ',
' r4-agent1-sku 21 '
'(C9351A) ',
' r4-agent1-type '
'1 ',
' r4-agent2-kind '
'3 ',
' r4-agent2-sku 22 '
'(C9352A) ',
' r4-agent2-type '
'2 ',
' r4-agent3-kind '
'3 ',
' r4-agent3-sku 58 '
'(C6658x) ',
' r4-agent3-type '
'3 ',
' r5-agent1-kind '
'3 ',
' r5-agent1-sku 21 '
'(C9351A) ',
' r5-agent1-type '
'1 ',
' r5-agent2-kind '
'3 ',
' r5-agent2-sku 22 '
'(C9352A) ',
' r5-agent2-type '
'2 ',
' r5-agent3-kind '
'3 ',
' r5-agent3-sku 58 '
'(C6658x) ',
' r5-agent3-type '
'3 ',
' r6-agent1-kind '
'3 ',
' r6-agent1-sku 21 '
'(C9351A) ',
' r6-agent1-type '
'1 ',
' r6-agent2-kind '
'3 ',
' r6-agent2-sku 22 '
'(C9352A) ',
' r6-agent2-type '
'2 ',
' r6-agent3-kind '
'3 ',
' r6-agent3-sku 58 '
'(C6658x) ',
' r6-agent3-type '
'3 ',
' r7-agent1-kind '
'3 ',
' r7-agent1-sku 816 '
'(C8816A/B/G) ',
' r7-agent1-type '
'1 ',
' r7-agent2-kind '
'3 ',
' r7-agent2-sku 817 '
'(C8817A/C8817G) ',
' r7-agent2-type '
'2 ',
' r7-agent3-kind '
'3 ',
' r7-agent3-sku 58 '
'(C6658x) ',
' r7-agent3-type '
'3 ',
' r816-agent1-kind '
'3 ',
'r816-agent1-sku ',
' r816-agent1-type '
'1 ',
' r816-agent2-kind '
'3 ',
'r816-agent2-sku ',
' r816-agent2-type '
'2 ',
' scan-src '
'1 ',
' scan-type '
'1 ',
' status-battery-check '
'0 ',
' status-dynamic-counters '
'0 ',
' status-type '
'2 ',
' support-released '
'True ',
' support-subtype '
'2202411 ',
' support-type '
'2 ',
' support-ver '
'1.7.4 ',
' tech-class '
"['DJ3600'] ",
' tech-subclass '
"['Normal'] ",
' tech-type '
'2 ',
' usb-pid '
'32260 ',
' usb-vid '
'1008 ',
' wifi-config '
'0 ',
'\x1b[01m',
'Status History (most recent first):\x1b[0m',
'\x1b[01m Date/Time Code Status '
'Description User Job ID '
'\x1b[0m',
' 11/01/18 09:20:51 1502 Tri-color cartridge is low '
'on ink ivan 0 ',
' 11/01/18 09:20:51 1000 '
'Idle ivan '
'0 ',
' 11/01/18 09:20:02 501 Print job has '
'completed ivan 199 ',
' 11/01/18 09:20:01 701 Printer queue '
'started ivan 0 ',
' 11/01/18 09:20:01 500 Started a print '
'job ivan 199 ',
' 11/01/18 09:19:25 703 Printer is accepting '
'jobs ivan 0 ',
' 11/01/18 09:16:49 1005 '
'Canceling ivan '
'0 ',
' 11/01/18 09:11:22 700 Printer queue '
'stopped ivan 0 ',
' 11/01/18 09:10:49 702 Printer is rejecting '
'jobs ivan 0 ',
' 11/01/18 09:08:24 5012 Device communication '
'error ivan 0 ',
'Done.',
['\x1b[35;01mwarning: No display found.\x1b[0m',
'\x1b[31;01merror: hp-info -u/--gui requires Qt4 GUI '
'support. Entering interactive mode.\x1b[0m',
0),
'is_cups_class': False,
'local_cups_queue_attributes': {'charset-configured': 'utf-8',
'charset-supported': ['us-ascii', 'utf-8'],
'color-supported': True,
'compression-supported': ['none', 'gzip'],
'copies-default': 1,
'copies-supported': (1, 9999),
'cups-version': '2.2.7',
'document-format-default': 'application/octet-stream',
'document-format-supported': ['application/octet-stream',
'application/pdf',
'application/postscript',
'application/vnd.adobe-reader-postscript',
'application/vnd.cups-pdf',
'application/vnd.cups-pdf-banner',
'application/vnd.cups-postscript',
'application/vnd.cups-raster',
'application/vnd.cups-raw',
'application/x-cshell',
'application/x-csource',
'application/x-perl',
'application/x-shell',
'image/gif',
'image/jpeg',
'image/png',
'image/pwg-raster',
'image/tiff',
'image/urf',
'image/x-bitmap',
'image/x-photocd',
'image/x-portable-anymap',
'image/x-portable-bitmap',
'image/x-portable-graymap',
'image/x-portable-pixmap',
'image/x-sgi-rgb',
'image/x-sun-raster',
'image/x-xbitmap',
'image/x-xpixmap',
'image/x-xwindowdump',
'text/css',
'text/html',
'text/plain'],
'finishings-default': 3,
'finishings-supported': [3],
'generated-natural-language-supported': ['hu-hu'],
'ipp-features-supported': ['subscription-object'],
'ipp-versions-supported': ['1.0',
'1.1',
'2.0',
'2.1'],
'ippget-event-life': 15,
'job-cancel-after-default': 10800,
'job-cancel-after-supported': (0, 2147483647),
'job-creation-attributes-supported': ['copies',
'finishings',
'ipp-attribute-fidelity',
'job-hold-until',
'job-name',
'job-priority',
'job-sheets',
'media',
'media-col',
'multiple-document-handling',
'number-up',
'output-bin',
'orientation-requested',
'page-ranges',
'print-color-mode',
'print-quality',
'printer-resolution',
'sides'],
'job-hold-until-default': 'no-hold',
'job-hold-until-supported': ['no-hold',
'indefinite',
'day-time',
'evening',
'night',
'second-shift',
'third-shift',
'weekend'],
'job-ids-supported': True,
'job-k-limit': 0,
'job-k-octets-supported': (0, 236211968),
'job-page-limit': 0,
'job-priority-default': 50,
'job-priority-supported': [100],
'job-quota-period': 0,
'job-settable-attributes-supported': ['copies',
'finishings',
'job-hold-until',
'job-name',
'job-priority',
'media',
'media-col',
'number-up',
'output-bin',
'page-ranges',
'print-color-mode',
'print-quality',
'sides'],
'job-sheets-default': ('none', 'none'),
'job-sheets-supported': ['none',
'classified',
'confidential',
'form',
'secret',
'standard',
'topsecret',
'unclassified'],
'jpeg-k-octets-supported': (0, 236211968),
'jpeg-x-dimension-supported': (0, 65535),
'jpeg-y-dimension-supported': (1, 65535),
'marker-change-time': 0,
'media-bottom-margin-supported': [1270,
0,
1482,
1446],
'media-col-default': '(unknown IPP value tag '
'0x34)',
'media-col-supported': ['media-bottom-margin',
'media-left-margin',
'media-right-margin',
'media-size',
'media-source',
'media-top-margin',
'media-type'],
'media-default': 'iso_a4_210x297mm',
'media-left-margin-supported': [635,
318,
0,
343],
'media-right-margin-supported': [635,
318,
0,
343],
'media-size-supported': ['(unknown IPP value '
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)',
'tag 0x34)'],
'media-source-supported': ['auto',
'photo',
'top',
'bottom',
'envelope',
'large-capacity',
'manual',
'by-pass-tray'],
'media-supported': ['oe_card-3x-5_3x5in',
'om_hagaki_100.19x148.17mm',
'om_hagaki-fb_103.72x151.69mm',
'oe_photo-4x-6_4x6in',
'om_photo-4x-6-fb_105.13x155.93mm',
'iso_a6_105x148mm',
'oe_photo-5x-7_5x7in',
'oe_card-5x-8_5x8in',
'om_oufuku_200.03x148.17mm',
'iso_a5_148x210mm',
'jis_b5_182x257mm',
'om_jb-5_182.12x257.05mm',
'na_executive_7.25x10.5in',
'oe_16k_7.75x10.75in',
'na_letter_8.5x11in',
'iso_a4_210x297mm',
'oe_executive-jis_8.5x13in',
'na_legal_8.5x14in',
'na_a2_4.375x5.75in',
'iso_c6_114x162mm',
'jpn_chou4_90x205mm',
'na_monarch_3.875x7.5in',
'iso_dl_110x220mm',
'na_number-10_4.125x9.5in',
'jpn_chou3_120x235mm',
'iso_c5_162x229mm',
'om_env-b-5_176.04x250.12mm',
'custom_min_1x4in',
'custom_max_8.5x14in'],
'media-top-margin-supported': [318, 0],
'media-type-supported': ['stationery',
'photographic-glossy'],
'multiple-document-handling-supported': ['separate-documents-uncollated-copies',
'separate-documents-collated-copies'],
'multiple-document-jobs-supported': True,
'multiple-operation-time-out': 300,
'multiple-operation-time-out-action': 'process-job',
'natural-language-configured': 'hu-hu',
'notify-attributes-supported': ['printer-state-change-time',
'notify-lease-expiration-time',
'notify-subscriber-user-name'],
'notify-events-default': ['job-completed'],
'notify-events-supported': ['job-completed',
'job-config-changed',
'job-created',
'job-progress',
'job-state-changed',
'job-stopped',
'printer-added',
'printer-changed',
'printer-config-changed',
'printer-deleted',
'printer-finishings-changed',
'printer-media-changed',
'printer-modified',
'printer-restarted',
'printer-shutdown',
'printer-state-changed',
'printer-stopped',
'server-audit',
'server-restarted',
'server-started',
'server-stopped'],
'notify-lease-duration-default': 86400,
'notify-lease-duration-supported': (0,
2147483647),
'notify-max-events-supported': [100],
'notify-pull-method-supported': ['ippget'],
'notify-schemes-supported': ['dbus',
'mailto',
'rss'],
'number-up-default': 1,
'number-up-supported': [1, 2, 4, 6, 9, 16],
'operations-supported': [2,
4,
5,
6,
8,
9,
10,
11,
12,
13,
16,
17,
18,
19,
20,
21,
22,
23,
24,
25,
26,
27,
28,
34,
35,
37,
38,
56,
57,
59,
16385,
16386,
16387,
16388,
16389,
16390,
16391,
16392,
16393,
16394,
16395,
16396,
16397,
16398,
16399,
16423,
14],
'orientation-requested-default': None,
'orientation-requested-supported': [3,
4,
5,
6],
'output-bin-default': 'face-down',
'output-bin-supported': ['face-down'],
'page-ranges-supported': True,
'pages-per-minute': 1,
'pages-per-minute-color': 1,
'pdf-k-octets-supported': (0, 236211968),
'pdf-versions-supported': ['adobe-1.2',
'adobe-1.3',
'adobe-1.4',
'adobe-1.5',
'adobe-1.6',
'adobe-1.7',
'iso-19005-1_2005',
'iso-32000-1_2008',
'pwg-5102.3'],
'pdl-override-supported': ['attempted'],
'port-monitor': 'none',
'port-monitor-supported': ['none'],
'print-color-mode-default': 'color',
'print-color-mode-supported': ['monochrome',
'color'],
'print-quality-default': 4,
'print-quality-supported': [4],
'printer-commands': 'none',
'printer-config-change-date-time': '(IPP_TAG_DATE)',
'printer-config-change-time': 1540911324,
'printer-current-time': '(IPP_TAG_DATE)',
'printer-device-id': 'MFG:HP;MDL:deskjet '
'f4100 '
'series;DES:deskjet '
'f4100 series;',
'printer-dns-sd-name': None,
'printer-error-policy': 'abort-job',
'printer-error-policy-supported': ['abort-job',
'retry-current-job',
'retry-job',
'stop-printer'],
'printer-geo-location': '(unknown IPP value '
'tag 0x12)',
'printer-get-attributes-supported': ['document-format'],
'printer-icons': 'http://localhost/icons/Deskjet_F4100.png',
'printer-is-accepting-jobs': True,
'printer-is-temporary': False,
'printer-make-and-model': 'HP Deskjet f4100 '
'Series, hpcups '
'3.17.10',
'printer-more-info': 'http://localhost/printers/Deskjet_F4100',
'printer-name': 'Deskjet_F4100',
'printer-op-policy': 'default',
'printer-op-policy-supported': ['authenticated',
'default'],
'printer-organization': '',
'printer-organizational-unit': '',
'printer-resolution-default': (300, 300, 3),
'printer-resolution-supported': [(300,
300,
3)],
'printer-settable-attributes-supported': ['printer-geo-location',
'printer-info',
'printer-location',
'printer-organization',
'printer-organizational-unit'],
'printer-state': 3,
'printer-state-change-date-time': '(IPP_TAG_DATE)',
'printer-state-change-time': 1541060402,
'printer-up-time': 1541060451,
'printer-uri-supported': ['ipp://localhost/printers/Deskjet_F4100'],
'printer-uuid': 'urn:uuid:7aab0573-2000-3b19-74a5-d3557a9073ba',
'pwg-raster-document-resolution-supported': [(300,
300,
3)],
'pwg-raster-document-sheet-back': 'normal',
'pwg-raster-document-type-supported': ['black_1',
'sgray_8',
'srgb_8'],
'queued-job-count': 1,
'server-is-sharing-printers': False,
'sides-default': 'one-sided',
'sides-supported': ['one-sided',
'two-sided-long-edge',
'two-sided-short-edge'],
'uri-authentication-supported': ['requesting-user-name'],
'uri-security-supported': ['none'],
'which-jobs-supported': ['completed',
'not-completed',
'aborted',
'all',
'canceled',
'pending',
'pending-held',
'processing',
'processing-stopped']}}
Page 5 (<troubleshoot.CheckPPDSanity.CheckPPDSanity object at 0x7f9189c1ee48>):
{'cups_printer_ppd_defaults': {'General': {'Duplex': 'None',
'InputSlot': 'Auto',
'InstalledCartridge': 'BlackAndTriColor',
'MediaType': 'Plain',
'OutputMode': 'NormalRGB',
'PageRegion': 'A4',
'PageSize': 'A4'},
'InstallableOptions': {'OptionDuplex': 'False'}},
'cups_printer_ppd_valid': True,
'missing_pkgs_and_exes': ([], [])}
Page 6 (<troubleshoot.LocalOrRemote.LocalOrRemote object at 0x7f9189c1eeb8>):
{'printer_is_remote': False}
Page 7 (<troubleshoot.PrinterStateReasons.PrinterStateReasons object at 0x7f9183110828>):
{'printer-state-message': 'Filter failed', 'printer-state-reasons': ['none']}
Page 8 (<troubleshoot.Locale.Locale object at 0x7f91831349b0>):
{'printer_page_size': 'A4',
'system_locale_lang': None,
'user_locale_ctype': 'hu_HU',
'user_locale_messages': 'hu_HU'}
Nem tudom, nekem kellemes
Beküldte fecameca -
Nem tudom, nekem kellemes csalódás volt, hogy az helyett, hogy a terminálba beírom: sh hplip-3.17.4.run és kivárom, amíg órákon át végigcsinálja a sok száz oldal csuda dolgot, amit ilyenkor szokott, ez egyszerűen az egyik y után simán kilépett belőle, ( Amikor rákérdez, hogy folytassa, vagy valami ilyesmi a jelszókérés után, már nem emlékszem. ) Rákerestem a google-ben, és egy Linux Mintes külföldi fórumon ezt a négy sort ajánlották a terminálba, és csodák csodája, még fél perc se kellett, és lett HPLIP -em, minden működik, a két nyomtatómat is simán felismerte, még újra indítást se kért.
sudo apt-get install xsane hplip-gui hplip
hp-setup
hp-plugin
Nem segít
Beküldte Hymer -
Kösz, de sajnos ez nekem nem segített.
Remélem, lesz még más javaslat.
CUPS
A CUPS látja a nyomtatót?
http://localhost:631/admin
Fut a CUPS folyamat?
CUPS
('printer-more-info': 'http://localhost/printers/Deskjet_F4100',)
Lámpa:
Megkérlek a https://paste.ubuntu.com/ használatára a hosszú szövegeknél.
A képeket képmegosztó oldal segítségével oszthatod meg.
A Cups nem látja.
Beküldte Hymer -
A Cups nem látja.
A státusz:
cups.service - CUPS Scheduler
Loaded: loaded (/lib/systemd/system/cups.service; enabled; vendor preset: ena
Active: active (running) since Thu 2018-11-01 09:21:43 CET; 2h 32min ago
Docs: man:cupsd(8)
Main PID: 4659 (cupsd)
Tasks: 4 (limit: 4532)
CGroup: /system.slice/cups.service
├─4659 /usr/sbin/cupsd -l
├─4663 /usr/lib/cups/notifier/dbus dbus://
├─8043 /usr/lib/cups/notifier/dbus dbus://
└─8044 /usr/lib/cups/notifier/dbus dbus://
nov 01 09:21:43 ivan-HP-250-G1-Notebook-PC systemd[1]: Stopped CUPS Scheduler.
nov 01 09:21:43 ivan-HP-250-G1-Notebook-PC systemd[1]: Started CUPS Scheduler.
nov 01 09:31:10 ivan-HP-250-G1-Notebook-PC hpcups[8047]: prnt/hpcups/HPCupsFilte
nov 01 11:19:50 ivan-HP-250-G1-Notebook-PC hp[8087]: prnt/backend/hp.c 919: ERRO
nov 01 11:20:50 ivan-HP-250-G1-Notebook-PC hpcups[13986]: prnt/hpcups/HPCupsFilt
nov 01 11:20:50 ivan-HP-250-G1-Notebook-PC hp[13987]: prnt/backend/hp.c 919: ERR
nov 01 11:20:51 ivan-HP-250-G1-Notebook-PC hpcups[13993]: prnt/hpcups/HPCupsFilt
nov 01 11:20:51 ivan-HP-250-G1-Notebook-PC hp[13994]: prnt/backend/hp.c 919: ERR
lines 1-20/20 (END)
Az utolsó kérdésedre a válasz: "A webhely nem érhető el"
A Cups nem látja.
Szerk.: ezt nézted?
https://sites.google.com/site/easylinuxtipsproject/14
Továbbra se
Beküldte Hymer -
Újraindítottam, aztán csatlakoztattam. A webhely továbbra se érhető el, a terminál szövege így változott:
● cups.service - CUPS Scheduler
Active: active (running) since Thu 2018-11-01 12:09:48 CET; 7min ago
Docs: man:cupsd(8)
Main PID: 791 (cupsd)
Tasks: 3 (limit: 4532)
├─ 791 /usr/sbin/cupsd -l
├─1088 /usr/lib/cups/notifier/dbus dbus://
└─1089 /usr/lib/cups/notifier/dbus dbus://
nov 01 12:09:48 ivan-HP-250-G1-Notebook-PC systemd[1]: Started CUPS Scheduler.
nov 01 12:12:09 ivan-HP-250-G1-Notebook-PC /hpfax[2122]: [2122]: error: Failed t
lines 1-13/13 (END)
Továbbra se
https://h30434.www3.hp.com/t5/Scanning-Faxing-and-Copying/Fax-failed-the...
