Beküldte xacx -
Egy wines játék van amit szeretnék használni. 14,04-es alapon ugyan ezzel a driverrel és gépel működött.
Jelenleg:
Telepítés lefutott. Login képernyőig jutok. Offline módban betudok lépni és telepíteni.
Bejelentkezni nem tudok.
Rendszer Linux mint 18 Xfce
gép: hp Elitebook 8540p
Log fájl:
http://pastebin.com/HQikTQvh
RE: PlayOnLinux - hearthstone
@#0 Nem ismerem a játékot, de látok egy ilyet
http://eu.battle.net/hearthstone/en/forum/topic/8427012767
-- Sally #2
add dbghelp to your librarys Disabled group under wine config
**added**
Below are steps to disable dbghelp in wine. The following applies to wine 1.6. YMMV:
1) Run winecfg. (If you have multiple prefixes, make sure it is the correct prefix)
2) In the 'Libraries' tab, type dbghelp into the 'New override for library' box.
3) Click 'Add', then 'Yes'.
4) Click on 'dbghelp' in the 'Existing_overrides' list.
5) Click 'Edit'.
6) Set to 'disabled'.
7) Click 'OK', then 'OK'.
8) Battle.net Client should now run. Edited by Sally on 16/10/2013 17:00 BST
-- 'megerősítik', illetve az indításra ad tippeket a kolléga
(félkövérrel jelöltem, ahonnan fontos, nos, aztán .. szét is szedtem lépésekre)
https://www.playonlinux.com/en/app-1950-Hearthstone.html
# sbrdste -- Monday 11 July 2016 at 12:33
Message
The Battle.net Helper keeps crashing unless I disable the "dbghelp" DLL, but when it's disabled the Battle.net login form does not load so I can't play the game. Though I could download and install Hearthstone by going on offline mode
Replies
# mauer01
Friday 15 July 2016 at 0:12 -
Have you found a solution of this Problem, because i have the same problem that i can't login.
# nullvoid
Friday 15 July 2016 at 0:58 -
Hi Guys. I stumbled across this post while looking for a solution. I've managed to find a temporary work around. If you
-- open up PlayOnLinux,
-- left click on Hearthstone,
-- then click "Open the directory" (in the left pane).
-- This will open up the Hearthstone folder. Then open up Battle.net and the login form should render correctly.
-- It appears that sessions created in the Battle.net client initiated this way,
-- do not persist through to the versioned opened by hitting the "Run" button.
This should at least allow you to play until someone finds a better solution.
Wiki/FAQ
https://github.com/HearthSim/Hearthstone-Deck-Tracker/wiki/FAQ
Lefordítsam? Szerintem mások is be tudnak szállni a tanácsadásba.
Látszólag ellentmondás van a két javaslat között, de mindkét helyen azt írják működik. Tehát az elsővel próba, aztán a másodikkal. A 'winecfg' viszont nem tudom, hogy magától frissül vagy frissíteni kell. A Wine-od új verzió (manapság megfelelő), náluk régebbi van.
kb értem, bár lehet hogy
Beküldte xacx -
kb értem, bár lehet hogy valami felet elsiklottam.
Nem igazán találtam olyat hogy dbghelp
RE:kb értem, bár lehet hogy
http://askubuntu.com/questions/39347/after-i-install-program-with-wine-i...
'winecfg' sem ('gksudo'-val sem). A 'winetricks'-ben telepíteni sem tudom, de
https://www.playonlinux.com/en/topic-13401-Blizzard_Games__Wine_secondar...
http://gaming.stackexchange.com/questions/236160/battle-net-launcher-on-...
a 'Függvénykönytárak'-nál hozzáadtam, és a 'Native' beállításra állt be amúgy alapból,ezt javasolják fentebb is. Talán így átverjük.
Mert létezik nálam is (csak gond van),
https://www.winehq.org/pipermail/wine-users/2015-May/107276.html
nézd meg te is .. mi a kimenet?
Terminálban indítva az alkalmazást, van e hibaüzenet, pl. ilyesmi;
https://bugs.winehq.org/show_bug.cgi?id=39261
Itt írják,
https://forums.gentoo.org/viewtopic-t-706299.html
hogy a -csak személyes könyvtáradban- a beállítási könyvtárak átnevezése, és a teljes uninstall (teljes eltávolítás, majd újratelepítés) segít.
Valahol olvastam, hogy a wine-stagging PPA nem egészen jó, amúgy teszt verzió .. nekem is ez van (nem használom semmire amúgy, át is kapcsolom a tárolót stabilra),
http://www.linuxquestions.org/questions/linux-games-33/wine-can't-find-txc_dxtn-and-dbghelp-dll-4175543523/
a 'winecfg' ezt nekem ki is írja. Nálad teszt Wine van (a kérdés törölve, és a bekezdésnek sincs értelme, miután megismertem a POL hogyan működik)? A Playonlinux beállításait nem ismerem, de most megnézem ...
Telepítettem a POL-t, sokkal okosabb nem lettem :). Amit észrevettem, hogy a Wine verzióm nem ismeri fel, a bal oldali ablakban a lehetségesek.
A Heartbeat
https://www.playonlinux.com/en/supported_apps.html
ezzel a számítógéppel nem működik, alább nálam is tapasztalható telepítési hiba oka többféle lehet
https://us.battle.net/support/en/article/BLZBNTBTS0000005C?utm_source=ap...
Flash Player vagy más (nálam). Próbálkozz a korábban általam említett másik módszer szerint, illetve a 'Natív' beállítással.
Mára ennyit tudtam tenni (e kérdésben).
